Hurst saginaw 3 speed shifter - Chevy Nova Forum
Old 15th-January-2012, 08:57 PM   #1
tx71nova
(OP)
tx71nova's Avatar
Nova(s): 71 Nova
Since there has been a overwhelming demand for hurst 3 speed saginaw shifter info, here it is.
I recently built a 355 SBC for my 71 and the 3 speed saginaw was whining bad so i decided to rebuild it. The rebuild was fairly straight forward. The mystery shifter that was in the car was in bad shape along with the linkage. so i decided to replace it with a Hurst mastershift 3 speed shifter
http://www.summitracing.com/parts/HUU-3667271/
and the linkage
http://www.summitracing.com/parts/HUU-3670010/
if you follow the instructions its an easy install (i did the install with the trans sitting on the work bench so i dont know how hard it would be to do with the tranny in the car
When i installed it in the car, i took the shifter handle off to make it a lot easier to install.
The shifter hole
When i bought the car the people that had the car before me moved the shifter from the column to the floor. and if you dont have a hole in your car here are the measurements for the shifter hole i have:
I measured from the face of the heater box to the front of the shifter hole and from the passenger side door shell to the passenger side of the shifter hole
The hole for the shifter i have is more then big enough
Bench seat clearance
in all the pics the shifter was in 1st
Here are some pics of the shifter with my beach seat moved all the way up:
as you can see the shifter just barely hits the seat, i have not driven the car with the seat all the up cause im to tall (5'11'') but i dont think the seat would push the shifter into neutral
and with the bench seat moved all the way back (the way i have it when i drive):
I hope this helps you guy out
1971 Nova 6.0 LQ9, Carb, Saginaw 3 speed
Old 15th-January-2012, 09:12 PM   #2
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
i'd like to add a couple comments which may further the assistance offered by this fantastic write up...
looking at these two images... if the shifter handle is left off of the transmission, go ahead and install the trans. the engine will be tilted back and the transmission hanging down in back...
jack it up so the shift handle "nub" is as close to the floor as possible. now, mark the 4 corners of the shifter, lower trans again, you can use a hammer and a punch and mark the 4 corners on the floor for the shifter to pass through. {mark them heavily}
lower trans. you can see the witness marks made by the hammer & punch. cut the hole in the floor from mark to mark. you now have a nice, tight fitting hole for the shifter. you can also trim a little here or there to accommodate the shifter for shifter to floor clearance.
you can use a 1/4" drill bit on the 4 corners and cut from hole to hole with a die grinder w/cutoff wheel, or a sawsall from hole to hole... whatever suitable panel cutting equipment you have on hand.
hopefully this will assist further...
the Flyer Special
'64 411 377-Tko600-3:73's
Old 16th-January-2012, 10:18 PM   #3
71Nova383
71Nova383's Avatar
Title: Nova Newbie
Nova(s): 71 Nova 383
Sorry for the late reply texas. This is a nice post tho. I will refer back to this page after i get my floor pans in and some other work done. Ohh yea anybody know how to get the molding with the air vents by the kicker panels out without having to take the dash apart?
Old 16th-January-2012, 10:58 PM   #4
tx71nova
(OP)
tx71nova's Avatar
Nova(s): 71 Nova
if you mean the pull vents, you just take the 6? screws out around the vent and it comes out kinda hard, be gentle the plastic is probably old and will break easily. on the driver side you need to take the parking break assembly out
Old 16th-May-2013, 01:35 PM   #5
jason 68 L78
and the linkage
The shifter hole
Wow just found this post. This is what I want to put in my 68 L79 but it has the borg warner heavy duty M13 transmission. They say it won't work for my tranny. The only thing that may be different is the tale housing bolts. Can you measure the center distance of the bolts where the bracket bolts to the tail hosing for me? I would like to try this set up...
Also maybe measure the mounting bracket front to back if possible?
"Challenge Yourself"
Old 18th-December-2014, 05:53 PM   #6
nightgrider
nightgrider's Avatar
Title: Nova Newbie
Nova(s): 1974 Nova 1979 Trans AM
Garage
Hi, I was wondering how your Saginaw is holding up? I'm planning to swap a 3 speed Saginaw into my '74 when I do the rebuild on the engine (right now it has a TH350). Do you know about how much torque your 355 is making? Thanks
Old 19th-December-2014, 11:25 PM   #7
tx71nova
(OP)
tx71nova's Avatar
Nova(s): 71 Nova
It makes around 400 ft/lbs, im not easy on it either. the syncros are going but other then that its good
Old 20th-December-2014, 03:49 AM   #8
nightgrider
Title: Nova Newbie
Garage
Ok good, that's what I'm hoping to get out of my 355 I'm building this winter. I've heard a lot of guys ragging on the saginaw, but i think for a street application it will hold up fine. I want to do some hard shifting, but I'm planning on staying away from doing holeshots.
What is the length of your shifter stick? Was given a hurst mastershift but the stick is for a truck and is 14in tall. I feel that would be awkward in the nova.
ID:	130578   Click image for larger version
Old 21st-December-2014, 09:36 PM   #9
tx71nova
(OP)
tx71nova's Avatar
Nova(s): 71 Nova
The shifter i got is about 11 inches. Saginaw also makes a 4 speed trans that is in the same case as the 3 speed. Those 4 speeds are extremely weak, iv heard of 307 breaking them haha
reverse lockout w/ hurst on saginaw 4 speed? OldBlue72 Drivetrain & Performance 4 18th-October-2011 12:13 PM
Anybody run a Hurst Shifter with Saginaw? kimrobertson Drivetrain & Performance 8 12th-April-2011 11:05 PM
Hurst Competition Linkage for Saginaw 4-speed? KeithMartin Drivetrain & Performance 0 19th-April-2010 02:07 AM
hurst shifter for saginaw 4 speed troys toys 3rd Generation Chevy II/Nova's 3 24th-December-2008 01:03 PM
