Fast EZ EFI Driveability Problems ? - Chevy Nova Forum
Old 13th-December-2011, 11:33 PM   #1
plumrat
(OP)
plumrat's Avatar
Nova(s): In boxes :)
My first EFI install. Went on a new crate 383, broken in on the dyno by the builder with all the parts from the same FAST kit.
Cam is flat tappet with .490/.490 lift, 230/236 duration at .050.
Fuel system is the FAST kit with their pump and regulator coming off the stock pickup with pump mounted slightly lower than tank.
Went through the normal setup wizard and was having a lot of trouble with the engine stalling at every stop.
I spent several sessions on the phone with FAST tech rep and after his suggested adjustments, mainly getting the IAC adjusted to the high teens, low 20's at idle, it is better, but still dies on about 1 out of 5 stops while driving. I thought it might be a fuel slosh problem uncovering the pickup and losing fuel pressure, so I added about half a tank of gas and still have the same problem.The FAST rep that I have been dealing with seems to out of answers. During the stops when the engine dies, it seems to dip way below the set idle speed and doesn't recover. Starts right back up.
Anyone here have simalar issues? Any help would be greatly appreciated.
Plumrat
1970 SS396 350HP 4spd (sold)
The Longroof Project (the band and ?)
THE SAWZALL SYNDICATE
Old 14th-December-2011, 12:02 AM   #2
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
Poor electrical connection??Vacuum leak at booster when braking?RF interference from other components?have you tried watching various sensor readings when the idle dips? Does the IAC count go up or down? meaning is it trying to correct or is it actually closing down?Chucks had issues but not what your describing.
Member of the NorCal Brotherhood!
Old 14th-December-2011, 12:10 AM   #3
plumrat
(OP)
plumrat's Avatar
Thanks for the suggestions Bryan. It does have power brakes. I will check that first.
It does the same thing at times while it is parked and idling when you blip the throttle, but not every time.
Plumrat
Old 14th-December-2011, 11:43 AM   #4
nova656567
Nova(s): 65 coupe 65 SS 67 Wagon
As Brian said (& probably the tech), they are real critical for clean power and interference. Only done two with a third waiting in the shop, but haven't had that, or a problem with the ones I've done.
Old 14th-December-2011, 10:29 PM   #5
plumrat
(OP)
plumrat's Avatar
Thanks Walt, I am using their RPM module which they kind of advise against. I am going to block the brake booster tomorrow and try again. Power wires to ECM are #12 direct to battery, so I don't think that is the problem. If I had an MSD laying around I would try that because it is the prefered source for the RPM signal.
Plumrat
Old 14th-December-2011, 10:37 PM   #6
Rantnrave1969
Nova(s): 67 hardtop in need of TLC
Remove any un-used wires in the FAST harness. meaning pull them out and cut them off at the computer. They act like antennas and cause interference within the harness and cause erratic signals to be interpreted. I've been through it before with FAST XFI, I work at a speed/restoration shop. Also disconnect the IAC, set your TPS to the recommended voltage (somewhere around .5) at idle and drive it. See if that helps. Holley has a similar problem with their Avenger system and we've had to eliminate the IAC. I might wait to cut your harness but i'd pull out any un-used circuits for sure. also, according to a couple of our local tuners the further you stray away from stock engines the IAC usually gets deleted, it's not uncommon.
Old 14th-December-2011, 10:40 PM   #7
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
hey Ken, Dave had a FAST unit on his '67 before switching to the LS... he went through a few diagnostic sessions with his, if you holler at him to look at this thread he might have something for ya... hopefully/maybe
the Flyer Special
'64 411 377-Tko600-3:73's
Old 14th-December-2011, 10:41 PM   #8
Rantnrave1969
And all that IAC, harness stuff doesn't mean anything if you're losing fuel psi. If you can monitor psi on your stops with a guage taped to the winshield that would help
Old 14th-December-2011, 10:49 PM   #9
David&Melissa_h
you need to see what the IAC count is when this is happening. it is real easy to miss adjust the IAC and have this problem.
Old 14th-December-2011, 11:24 PM   #10
plumrat
(OP)
plumrat's Avatar
That was the techs suggestion. I may have to try that.
Plumrat
Old 14th-December-2011, 11:28 PM   #11
plumrat
(OP)
plumrat's Avatar
IAC has been all over the place. I have it where the tech suggested, about 20 at idle but will have to see where it is going during the problem occurances.
Is it normal for it to increase as you open the throttle? This stuff is all new to me.
Plumrat
Old 14th-December-2011, 11:49 PM   #12
Rantnrave1969
to simplify, think of the IAC like this... its job is to control the engine rpm in small increments. when you put a lil load on the engine at idle like a/c or when the fans kick on, in order to keep the rpm up and have a "seamless" operation of those accessories, the IAC lets air in. the counts should go up on a scan tool.
Old 15th-December-2011, 12:39 AM   #13
Pragmatist
Pragmatist's Avatar
Garage
An IAC is like an idle circuit on a carburetor. Once you are firmly in the throttle it should be closed.
66 & 67 hard top,
My 1980 avatar pic.
Old 2nd-January-2012, 01:15 AM   #14
shano
Title: Nova Newbie
Nova(s): 68 two door ls2 6 speed
I have a ls2 with ezi efi very similar size cam and had the same problems the first thing i suggest is reset to a new tune, stick with the 13.5 idle 14 cruise and 12.8 wot and accell on 00 , then when the engine is running ckeck your load percentage in the live data, with a large cam and low vacumm signal your load percentage at low idle will be very close to 50% and thats when the ECU changes from the idle map to cruise map and the ECU has problems staying in the idle section of the tune, the best way to fix this and get it down near 40% is to lift the idle a little higher, you will notice the load percentage will come down lower as idle goes higher and this will keep it away from that 50%. What happens is when you sit ther idling its all fine but when you drive the car and you deaccellerate the load percentage drops into and out of the 50% load range and has trouble coming back to the idle map, this is why ezi efi doesnt work that well with camshafts that have low vacum as they dont recommend anything under 8 inchs of vacum, my camshaft runs between 5 and 6 inchs at idle. Another thing that helps is timing i have the msd 6010 and can map the timing map via lap top if the timing is very erratic at idle it wont help keep a steady idle i have kept mine at around 17 to 20 degrees at idle and set the vacum advance map to keep a far bit of advance when you deaccelerate and helps the idle from dipping right down when your back off the throttle. My idle is set at 850 a little high than i would like but the only way to keep around 42% load at idle. after you drive for a while you will probably find that you accell works best at -2 or -3. I hope this helps and makes sense i have spent a massive amount of time with this ezi efi as i feel its a great product and was determined to make it work.ecub
Old 8th-April-2016, 09:49 AM   #15
Newty-Newt
Newty-Newt's Avatar
Nova(s): 1972
Even though this is an old thread, I have had similar problems with my Fast EZ EFI 2.0 unit. When I purchased my unit I had little time to install it due to my job. So I paid a local speed shop to install it on my 1972 stock big block Nova. It ran good about 30 miles. The next day it was cold and the Nova would not start. It gave a code of Map power. I called the speed shop and they called Fast. Fast said to send them the old map sensor and they would send the new and improved sensor. ( I had to pay shipping). Changed the map sensor and it runs again. Now occasionally the Nova gets a pop back in the EFI base. ( or carburetor looking unit). Now I am installing the FAST Dual sync distributor because I feel that maybe at times the EFI is out of phase with the MSD ignition and box. I like solving puzzles but this puzzle is irritating. Does anybody else that runs FAST EZ EFI have trouble besides me and plumrat?
How fast? 72RallyNovaRon Drag Racing Forum 9 9th-March-2008 04:06 PM
converter, gears and driveability 1quik69 Drivetrain & Performance 9 26th-November-2006 07:08 PM
