starter spins but not engaging flywheel - Chevy Nova Forum
Old 16th-November-2011, 05:38 PM   #1
nick72nova
(OP)
nick72nova's Avatar
Nova(s): 72 nova,406,4spd,12bolt
not sure if this is the correct spot to post this, but heres the story, i have a 406sbc with new ram clutch and a new flywheel which was said to be the correct one for the engine..when i go to turn the ignition, i can hear the starter spinning but not engaging,, i tried 2 starters that i had lying around, and the same problem for both of them,,,could it be the starters are bad, they havent been used in almost 3 years,,,, thanks for any info you guys have
Old 16th-November-2011, 05:46 PM   #2
65Coupe
65Coupe's Avatar
Nova(s): Gone, but not forgotten.
There is a solenoid mounted on the starter that, when energized, engages the rotating gear with the ring on the flywheel. You can bench test this with a 12V battery to make sure this solenoid is working, and the gear is extending/retracting.
If this is working, then you need to check the clearance between the starter and flywheel.
Old 16th-November-2011, 07:55 PM   #3
Nova_Guy
Nova_Guy's Avatar
Nova(s): 68 Chevy II SS
Are the starter and flywheel size matched? There are two sized 153 and 168. I'm not sure how it all works, if the starters are different or the holes are in different places. Did your starter use two long bolts or a long and short?
James
1968 Chevy II National Nostalgic Nova Member
Old 16th-November-2011, 08:02 PM   #4
tubbed73
tubbed73's Avatar
try rotating the engine by hand a few degrees. its possible it stopped on a spot where theres a couple of damaged flexplate teeth.
Old 16th-November-2011, 09:35 PM   #5
65Coupe
65Coupe's Avatar
He said it was a new flywheel, so. I'd hope it wouldn't be missing teeth already.
Old 16th-November-2011, 09:56 PM   #6
tubbed73
tubbed73's Avatar
My bad. I have selective reading skills...
Old 16th-November-2011, 10:37 PM   #7
nick72nova
(OP)
nick72nova's Avatar
I'm pretty sure its a 168 tooth flywheel, I have an 11 inch clutch disc, I tried 2 starters, one used long bolts and the other used short bolts, nothing grinding or getting stuck, when I bolt the starter up, there's a little space between the starter and the block, is this normal or do I have the wrong starter, thanks for the info guys
Old 16th-November-2011, 10:43 PM   #8
65Coupe
65Coupe's Avatar
While the starter is mounted to the block, you can pry the starter pinion gear forward towards the flywheel ring gear to check proper clearance.
Old 17th-November-2011, 08:09 AM   #9
Paul Wright
Paul Wright's Avatar
There are different nose pieces for the starter motors that allow the basic Delco motor to fit all the variations. Somewhere I have a chart that shows the different types and what they fit. I think the staggered bolt pattern is for the 168 tooth and straight across is for the smaller flywheel.
I've come across rebuilt starters with really poor fitting nose pieces.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 17th-November-2011, 12:57 PM   #10
Ashman101
Ashman101's Avatar
Nova(s): 1967 Pontiac Acadian
Garage
Pics??
Most likely but, Do you have the flywheel bolted to the crank the correct way?
Also, what style starters have you been trying?
The staggered bolt type or billet block style?
'67 Acadian
388sbc
10.48 @ 125
on a fat 150 shot!
Old 17th-November-2011, 01:37 PM   #11
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
If you have the 11 inch clutch you have the 168 tooth flywheel, no exception.
We are assuming you are using a GM factory starter and not a aftermarket starter.
Need to give complete information.
The GM starter you need will use 2 long bolts. And they will be staggered, I don't believe you can used a starter with bolt straight across because most 400 block are drilled for staggered only.
You should be using the starter pictured on the right.
Left is a 153 tooth right is the stagger 168 tooth aluminum nose starter.
(Note: there is a GM HD cast iron nose starter that has a dual pattern for 168 tooth only, rare)
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 17th-November-2011, 02:33 PM   #12
balljoint
balljoint's Avatar
Nova(s): 1978 chevy nova
Got the wrong style starter?
Old 20th-November-2011, 12:26 AM   #13
nick72nova
(OP)
nick72nova's Avatar
the bolt holes are staggered like the one on the right, i have to check it out tomorow and take pics,,its just a car, ill figure it out lol
Old 11th-December-2011, 04:49 PM   #14
nick72nova
(OP)
nick72nova's Avatar
ok so i finally made it to my garage and had my friend crank the engine while i was under the car, what i see is the solenoid drive coming out, but it looks like the flywheel is sitting to far away, not sure whats going on here loll, any help would be great again loll
Old 11th-December-2011, 04:55 PM   #15
balljoint
balljoint's Avatar
Try putting the right starter in it ,like the previous posts said........
Mini Starter Not Engaging Flywheel- Question PldBryan Drivetrain & Performance 1 25th-June-2011 02:32 AM
Starter flywheel teeth ? bleedchevyorange Drivetrain & Performance 1 20th-September-2009 01:44 PM
starter/flywheel trouble burningsquirrels Drivetrain & Performance 21 4th-September-2009 09:41 PM
starter/flywheel issues 74Nova-cain Drivetrain & Performance 10 10th-February-2009 02:47 PM
starter/flywheel JR Electrical 8 31st-July-2008 07:42 PM
