Proportioning valve - Chevy Nova Forum
Old 16th-November-2011, 02:31 PM   #1
nova64000
(OP)
nova64000's Avatar
Nova(s): 64 2 door Sedan
Proportioning valve
I haven't been able to get a decent pedal after installing the new discs from CPP. I have a corvette master cylinder and a new rear brake line that connects to the original rear brake line through a Jegs Prop Valve...
http://www.jegs.com/i/JEGS-Performan...63020/10002/-1
I plumbed it this way only because a member advised me to do it this way when I originally converted to a Dual Master Cylinder. I'm not sure if its the correct way or the best way to run a proportioning valve but I'm willing to redo it if necessary as I don't want to cut any corners. I can't help but notice that most cars with Disk brakes have a prop valve under the Master Cylinder which may be a better setup (?) Also I didnt install a check valve which I understand may be needed depending upon the bore of the master cylinder as I have drum brakes in the rear.
I'm wondering if I should keep the adjustable prop valve or go with a different setup?
Nick
Old 16th-November-2011, 05:07 PM   #2
Rotorbolt
Nova(s): 1964 Chevy II 400 4dr sed
Typically, a corvette master cylinder is for front and rear disks. mine has disk front, drum rear and a early to mid 70's GM mid size disk brake master cyl. I'm using the proprtioning valve from a late 80's S10.
Old 16th-November-2011, 05:26 PM   #3
603 chevy II
Nova(s): 63 HT
So with the Vette M/C that is made for Disk/Disks would you need a prop valve if you had Disk/Disk set up. I'm doing a Disk/Disk set up with the Vette M/C and read something about using an adjustable valve just for the rear brakes. I was thinking about getting a combo distribution/prop valve. any thoughts on that.
Old 16th-November-2011, 06:16 PM   #4
Vin63
Vin63's Avatar
Nick
I think what you might be experiencing is due to the lack of a residual pressure valve from the master cylinder to the rear brakes.
Old 16th-November-2011, 07:12 PM   #5
nova64000
(OP)
nova64000's Avatar
Thats what I thought. I was told that it depends on the bore of the master cylinder... I'm going to try that first before anything else
Old 16th-November-2011, 08:41 PM   #6
Vin63
Vin63's Avatar
...I was told that it depends on the bore of the master cylinder...
No, the disk/disk brake master cylinder does not have the residual pressure valve like the drum master cylinders. I would try a 10 lbs. residual pressure valve.
Old 16th-November-2011, 09:03 PM   #7
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
I installed a residual pressure valve when I did my 71 disc brake conversion. I have heard you don't need one as long as your master cylinder is up on the fiewall. I didn't do anything at all with a proportioning valve.
Old 16th-November-2011, 09:32 PM   #8
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
I run a disc/disc setup, but when I was putting my setup together I was told the same as above, the Vett master would require a residual pressure valve, when used with a disc/drum setup. They come in a few different increments, but I would say a 10lbs is a good starting point too. We also use a similar adjustable prop valve as the one you posted too.
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
proportioning valve nick72nova Steering, Suspension, and Chassis 0 21st-June-2010 01:49 PM
Proportioning valve? Scimitar 7 Steering, Suspension, and Chassis 11 7th-March-2010 10:12 PM
Proportioning valve? gr8ride_71 Drag Racing Forum 10 5th-March-2009 10:13 PM
Proportioning valve? Newbie Steering, Suspension, and Chassis 5 12th-February-2009 09:52 AM
proportioning valve shawner Steering, Suspension, and Chassis 2 18th-April-2007 09:57 AM
