67 ladder bar car wont hook up - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 24th-September-2011, 02:44 PM   #1
just chevy
Thumbs down 67 ladder bar car wont hook up
67 ladder bar car, new 30x 10.5 hoosier slicks went from the softest compound #5 to #7 still wont hook up, slicks still spend as if your still in the wet box, 1100hp nitrous, 3 hole adjustment n ladder bar cross member, moved bar all the way down still spins the tires but not as if u where n a water box, car runs 5.90 moved bar all the way up car runs 6.06 still spins both runs where after taking timing out, so put the power back n the car, an car is up on the whellie bars and spining like its on ice with ladder bar all the way up. single adjustable strange shocks set at 5 clicks clockwise, car ways 2953LB with driver with 52% of weight of on nose.
Old 24th-September-2011, 06:41 PM   #2
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Not sure how to help with a ladder bar car, but I think your missing a couple hundred horsepower somewhere. 5.90-6.00 needs a lot less than 1100 h.p.
My old 500+? h.p. 406 ran 6.12 using a 200 shot on a 9" street tire at about 3200 lbs.
What kind of MPH are you running?
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
bowtie0069.fotki.com/
Old 24th-September-2011, 07:04 PM   #3
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova -383
I agree, my buddy ran some 5.80 -590's with a 408 sbc plus a 250 shot. I figure he was around 800 hp with the spray. I think his ride weighed in at 2700 lbs. maybe more.
Old 24th-September-2011, 07:46 PM   #4
just chevy
hp
let me guess, u dident dident spin the tires the 1st 50 ft
Old 24th-September-2011, 08:00 PM   #5
hot66
hot66's Avatar
What kind of front end?
Are you getting enough travel to get good weight transfer?
Maybe you should have someone shoot a video to get a better idea.
Just thinkin' out loud....
Jeff
Old 24th-September-2011, 08:00 PM   #6
just chevy
spin
john force spun his tires an ran a 12.31 a while back, he makes over 8000hp
Last edited by Professor Fate; 24th-September-2011 at 10:30 PM. Reason: removed unneeded comment
Old 24th-September-2011, 08:14 PM   #7
just chevy
spun
Jeff
stock front end with coil overs an rack an pinoin, yea a video might help, im thinking about going to a softer rear spring to help transfer weight,i was told on the last pass it lifted the rear when it hit the whillie bars so thinking about shorting the top bars on whillie bars so i can raise them more they where raised up all the way on last pass
Old 24th-September-2011, 08:18 PM   #8
66 BADBOY
66 BADBOY's Avatar
Title: Moderator
Nova(s): 5 all in 1
What color is the car? That might help us help you.
SHE'S ALIVE!!!
Old 24th-September-2011, 09:55 PM   #9
just chevy
spun
if u no what color it should be let us no.
Old 24th-September-2011, 10:13 PM   #10
bowtie0069
bowtie0069's Avatar
Nova(s): 69
No, mid 1.3 60's with slapper bars and E.T. Street's--it used to get loose down track and slowed to 9.80's, but that was a pretty tired engine after a couple Power Tours.
So, what was the MPH?
Old 24th-September-2011, 10:25 PM   #11
just chevy
spun
we arent even instrested n the mph until we can get the car to hook up an not spin should be run n 20s an 30s
Old 24th-September-2011, 11:10 PM   #12
jer66nova
jer66nova's Avatar
Nova(s): '75 nova best1/4 mile 13.
hey Larry,tire pressure? you sprayin on the launch? 60 foot? try getting it to hook off the nitrous and adjust suspension little at a time to get best hook how hot you getting the slicks are they radials or regular slicks, I f you plan on sprayin all that juice de tuning the car to make it hook defeats using the spray ...right?? just my 2.... hope you get it figured out. Jerry
66 chevy IIsedan
PROSTREET FRATERNITY MEMBER
http://s156.photobucket.com/home/jer66nova/index
Old 24th-September-2011, 11:15 PM   #13
TuBaDuB
TuBaDuB's Avatar
Nova(s): 1972 Pro Street Nova/383/
Are you running screws or beadlocks? That would be the first place I'd look to make sure your tires are not slipping on the rims.
And try a different pressure in your tires. Track prep could be lousy to.
Old 24th-September-2011, 11:37 PM   #14
just chevy
spun
running screws, 9lb tire pressure, all the pro mods where hooking up, ran this same motor tranny an converter n my vega with same tire size never had any problems hook n up, so the nova is longer wheel base so i supect its a weight tranfer issue
Old 25th-September-2011, 06:58 AM   #15
bracketchev1221
bracketchev1221's Avatar
Nova(s): 70 SS 350
I'll be honest here. I have a ladder bar car, but you are so far out of my league that I wouldn't even make a guess without reading up on this one. My car is an 850-875 hp 16X32 tire car. My bars are 5 degrees down at rest. The car weighs 3160 with me in it and I use 130 lbs springs in the rear.
TKO VSS hook up David&Melissa_h LSx Forum 14 6th-July-2011 05:40 PM
Ladder bar ? TuBaDuB Drag Racing Forum 18 7th-March-2009 06:50 PM
Ladder Bar Set-up TooManyReels Steering, Suspension, and Chassis 1 23rd-September-2008 09:36 PM
63 ladder bar car?? 63chevyII Drag Racing Forum 0 30th-July-2007 12:25 PM
My 72 Won't Hook Up - Why? leejoy Drag Racing Forum 32 21st-July-2007 10:41 PM
