990 heads what the deal - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 4th-September-2011, 09:16 PM   #1
aqua750
(OP)
aqua750's Avatar
Nova(s): 1971 SS Big Block
hello guys I cant figure out what up with the 990 heads do you guys like them or hate them?? some people think there to big some people think there to old . What did the people at chevy put them on?? I got a 468 motor sitting in my garage its brand new its a 4 bolt 10.5 je pistons990 heads a solid roller crane gold rockers stud girdle weiand team g and a holley850 race carb so whats wrong with this combo??? the heads?? this is a street car that sees 150 miles a year Its a 71 nova 4spd 411 rear. What horse power do you guys think this motor will make ?? Sure I have a new set of gmpp 502 alum heads in the garage but why pull perfectly good 990 heads off what do you guys think?? It seems nobody remembers the old days when we didnot have 4000 dollar heads at our disposal. Or has anybody ever raced a ls-6 or a ls-7 chevelle or a real 427 they were smokers please all opinions needed thanks in advance
Old 4th-September-2011, 10:14 PM   #2
big dog ss
big dog ss's Avatar
Nova(s): 1970 SS
i like using the old stuff that most say is old technology and should get something new.. those heads can support 650+HP depending on whats been done to them. unless you need the weight savings i wouldnt switch them...jmo
"It is the duty of the Patriot to protect his country from it's government"...Thomas Paine
Old 5th-September-2011, 04:03 PM   #3
bracketchev1221
bracketchev1221's Avatar
Nova(s): 70 SS 350(sold)
I think those heads were over the counter replacement heads. Are they ok, yes they are. The heads are big for what you want to do. I ran the early Merlin heads which were copies of those heads with raised exhaust ports. The issue is what do you want to use the car for. If it is around town driving, then a smaller port would increase low end torque. The larger port is better for higher rpm, such as racing. Those heads are about 320cc intake ports and can handle up to about 725-750 hp. I ran Dart 325cc heads on my 509 and they were a little small on my 540. If you are around town driving and staying below 6500 rpm max, I think a good 781 casting head would do great. But if you plan on shifting it at 7000 plus than the 990 head is pretty good. The only reason that people say they are not worth using is that machine work is expensive and by the time you sink the money in 990 heads, you could buy aftermarket. Also the issue with pump gas and steel heads, 10.5-1 is about as high as anyone wants to risk running. Some won't even go past 10-1.
Ray
Old 5th-September-2011, 04:21 PM   #4
aqua750
(OP)
aqua750's Avatar
990,s
thank you for the well thought out reply.You see I got this motor from a buddy its complete from pan to carb It just seems ashame to pull off the heads ( 990) pull out the solid roller cam because people say you schould not run a solid roller on the street and put the gmpp alum 502 heads and a BIG voodoo solid flat tappet more and more money , dont get me wrong my nova is one of the nicest you will ever see BUT I only go 150 miles a year , there is no track on Long Island and I dont street race anymore. I just want the nova to sound like an animal Im starting to think Im:confused retarded but thanks ps If I take off the 990,s what do I do with them?
Old 6th-September-2011, 06:58 AM   #5
bracketchev1221
It all goes back to what you said, if they are there use them. There probably is not much of a market for those. I know everyone is using the oval port steel heads, but the rect port heads are more limited use. Basically, use good gas to not detonate it, and you are fine.
Ray
Old 6th-September-2011, 09:29 AM   #6
77xbody
77xbody's Avatar
Nova(s): 77 nova
you can still get some money for the 990 heads,there are alot of guys who cant afford alum heads.I know plenty of cars with those heads running fast
6.27@109 1.37 60'
9.95@134.5
433 BBC @ 3600lbs
Patriot heads vs AFR vs Pro filer heads 1969NOVA1 Drivetrain & Performance 42 16th-October-2011 12:58 PM
202 heads verses edelbrock heads topcop5129 Drivetrain & Performance 15 16th-October-2010 11:03 PM
Are these Dart Heads a good deal???? 63chevyII Drag Racing Forum 5 18th-November-2008 10:31 PM
IK200 heads worth the upgrade over a fully worked set of double hump heads? Tubbed63 Drivetrain & Performance 17 29th-October-2008 09:13 PM
