ZZ4 with hot cam install fuel pump push rod - Chevy Nova Forum
Old 1st-September-2011, 02:23 PM   #1
wango-tango
(OP)
Title: Nova Newbie
Nova(s): 1972 Nova
I have a brand new ZZ4 short block and I have installed the GM hot cam in it. I want to use an Edelbrock mechanical fuel pump, but I'm a little confused on which fuel pump push rod to use in it. I've read that the stock GM push rod part# 3704817 will work just fine. I have also read that ARP's # 134-8701 and Moroso # 65750 are both lightened fuel pump push rods that help prevent fuel pump float above 6000 rpms will also work on this roller camshaft. Then I have also read about using a bronze tip fuel pump pushrod. Can someone help me in selecting the proper fuel pump push rod to use? I don't want to wipe out this new camshaft by using the wrong one!
Old 1st-September-2011, 03:01 PM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
If roller contains eccentric for mechanical fuel pump.
The cam shaft is designed to work with a stock fuel pump push rod.
nothing special needed.
FYI
Al
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 1st-September-2011, 03:33 PM   #3
wango-tango
(OP)
Title: Nova Newbie
Nova(s): 1972 Nova
The Gm Hot cam has the fuel pump lobe on it. Is there any advantage with going with the ARP, or Moroso light weight ones and will they work with that camshaft?
Old 1st-September-2011, 07:20 PM   #4
onecarnut
onecarnut's Avatar
Nova(s): 1968 Chevy II
Some blocks have the outward appearance for a mechanical pump, but were not machined/drilled for a pushrod.
I have no idea if this is a concern for the ZZ4 engines.
Gone but not forgotten
Old 1st-September-2011, 08:42 PM   #5
wango-tango
(OP)
Title: Nova Newbie
Nova(s): 1972 Nova
The ZZ4 short block is drilled for a fuel pump push rod. I still woul like some feed back on if anyone has used an ARP or Moroso lightened fuel pump rod either on the stock ZZ4 roller cam or the GM roller Hot Cam and what kind of results they got with as far as wear on the cam and or fuel pump push rod. Any feedback would be greatly appreciated.
Lets See Your Fuel Filter/Electric Fuel Pump Mounting Locations 62civa Drivetrain & Performance 11 4th-October-2015 09:16 PM
Fuel cell & pump & filter install....? SSN2OVA Drivetrain & Performance 24 21st-September-2011 12:16 PM
Help with Mechanical Fuel Pump Install gonzalezllg Drivetrain & Performance 10 7th-November-2009 07:52 AM
connecting Fuel pump, water pump and fan Arts70nova Electrical 6 8th-December-2008 12:19 AM
Fuel Pump install 70oneNova Drivetrain & Performance 3 19th-April-2006 01:14 AM
