Saginaw p/s pump - Chevy Nova Forum
Old 22nd-July-2011, 01:13 PM   #1
sinister64
(OP)
Title: Nova Newbie
Nova(s): 64 ss
Saginaw p/s pump
I have a leak on my Saginaw power steering pump on the back side at the bottom where it bolts to my bracket, seems like that bolt could be a drain but lines up with my bracket. is there a special stud to use here? or should i not be using it as a mount? Any ideas?
Old 22nd-July-2011, 05:36 PM   #2
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
if the pump was removed from the can you'd see a square seal behind that and the other can to pump bolts, a seal for the pressure relief nut that the pressure hose screws into.... there's also an O ring that surrounds the outer diameter of the pump... 2 (maybe 5/8" dia) small square seals, one larger seal (maybe 1" dia) and the can to pump O ring seal (maybe 4" dia). the bolt in particular you're asking about has a flat hex head in the middle of two studs, one side screws into the can & pump, the other side the bracket slides over and is retained with a washer & nut...
there is also an oil seal (like a wheel seal for example) behind the pulley for the pump shaft to pump body...
hope i helped...
[edit]
here's an image of the proper bolt...
the Flyer Special
'64 411 377-Tko600-3:73's
Old 22nd-July-2011, 09:33 PM   #3
sinister64
(OP)
Title: Nova Newbie
Nova(s): 64 ss
Nice work Flyer!!! i def. do not have that bolt. im going to find one from the junkyard. Thanks!
Tags
power steering, saginaw
Saginaw 4 speed nova}{ Drivetrain & Performance 12 28th-December-2010 01:02 AM
What does a saginaw 825 look like Pro-touring72 Steering, Suspension, and Chassis 0 30th-January-2007 04:21 AM
saginaw voodoochikin04 Drivetrain & Performance 39 13th-January-2007 05:02 PM
Saginaw Power Steering Pump CaddyDaddy Steering, Suspension, and Chassis 3 10th-August-2006 03:33 PM
