Advantages of High Volume Long Shaft Water Pump - Chevy Nova Forum
Old 9th-July-2011, 03:10 PM   #1
YellowDNova
(OP)
Title: Nova Newbie
Nova(s): 1972 Nova
So I am looking at buying an edelbrock carb for my car, and the same guy also has a new edelbrock high volume long shaft water pump for sale. What advantages would this have over a stock one?
Old 10th-July-2011, 01:31 AM   #2
JRouche
JRouche's Avatar
Ummm... None that I can think of. If the stock water pump was providing sufficient cooling then why change.
The only beenies I see is if the pump is lighter because is aluminum. But thats small. And some folks might say its a better pump and will last longer but thats not always the case. Things fail sometimes just cause chit fails. No guarantees.
And again on the small side the high volume pump might take some HP out due to the larger impeller, but again, chump change.
My take on it? Keep it simple, if it works then well.... It works... JR
What I write is opinion, none of it is factual.
Summit High Volume Water Pump tider66 Drivetrain & Performance 2 4th-October-2010 12:44 AM
High volume oil pump shaft? 62bandwagon Drivetrain & Performance 2 25th-April-2010 09:33 PM
High volume oil pump and pan question waverous Drivetrain & Performance 1 27th-March-2010 08:30 PM
Which oil filter in a BB with a high volume oil pump? The_Dude Drivetrain & Performance 4 10th-May-2008 11:33 PM
Procomp SHORT High Volume Aluminum Water Pump for Big Block chevy. bkhotrod Drivetrain & Performance 4 9th-October-2007 03:36 PM
