Steering Box Adjustment - Chevy Nova Forum
Old 6th-June-2011, 03:15 PM   #1
Ashman101
(OP)
Ashman101's Avatar
Nova(s): 1967 Pontiac Acadian
Garage
I am curious as to how to adjust the steering box properly.
Do you just cinch the bolt down while turning the steering wheel and tighten the nut?
Is there a method to do it right?
'67 Acadian, manual steering box.
Sloppy straight line driving. Turns fine.
Possible time to replace?
Thinking about a flaming river piece.
Advice?
Old 7th-June-2011, 09:37 AM   #2
iroc343
iroc343's Avatar
Nova(s): 1970 SS L78
While I'm sure there is a proper procedure, all I've ever done is loosen the jam nut and run the screw down till it just contacts the sector shaft, little to no preload, and tighten the jam nut. This will take any slop out ot the gears, but it won't cure bad bearings on the sector shaft.
1966 1966 steering box adjustment rwbrlb Steering, Suspension, and Chassis 0 14th-April-2010 11:27 PM
63 steering box adjustment AGPG Steering, Suspension, and Chassis 1 16th-June-2009 05:15 PM
'66 steering box adjustment screw bleedchevyorange Steering, Suspension, and Chassis 3 10th-April-2008 12:29 PM
Steering adjustment screw?? mcarmaniac Steering, Suspension, and Chassis 3 13th-October-2007 02:42 PM
63 Steering Box Adjustment rlabla Steering, Suspension, and Chassis 3 9th-February-2007 04:07 PM
