487 X head info - Chevy Nova Forum
Old 9th-May-2011, 11:42 PM   #1
luepke75
(OP)
luepke75's Avatar
Nova(s): 63SS,63LR,68
Garage
487 X head info
I'm putting my daugters 68 together and the 350 I have has the 3973487X heads. They look to be 2.02 and when I looked them up its 1971 high performance app. or truck and pass. car. I was planning on have a set of the "hump heads" gone through for $400 but these look to be in great shape. Any idea how the two compare. Its going to be a mild 350 with performer cam, 600 holley, headers, stock converter with the 3.08 posi. Its a 2bolt main 350 and has some flattops in it. Thanks
Nor-Cal Classics
Old 10th-May-2011, 04:04 PM   #2
luepke75
(OP)
luepke75's Avatar
Garage
Bttt................
Nor-Cal Classics
Old 10th-May-2011, 04:20 PM   #3
Lugnut79
Lugnut79's Avatar
Nova(s): 67 Chevy II
Camel humps would be better. Those 487x's are 76cc but I think the runner is @10cc larger than a regular 487's. Pretty rare head you have. If you do use them make sure they have hardened seats in them.
Camel Humped 355 best, 11.55 @ 116
Old 10th-May-2011, 04:42 PM   #4
luepke75
(OP)
luepke75's Avatar
Garage
They do have hardened seats. How much better is worth the $400 bucks to switch over?
Nor-Cal Classics
Old 10th-May-2011, 04:46 PM   #5
Lugnut79
Lugnut79's Avatar
A lot of guys on here will tell you to ditch the old heads all together and switch to Vortec's. It all depends on what kind of outcome you are looking for. The 487's will work fine on a daily driver.
Old 10th-May-2011, 05:24 PM   #6
luepke75
(OP)
luepke75's Avatar
Garage
Yea Ive been told that. I have these heads (487's) and the camel humps (3 sets) so I would like to use something off of my shelf for a change. Its just a mild 350 for my daughter. So I was more looking to compare between the two.
Nor-Cal Classics
Old 10th-May-2011, 05:31 PM   #7
pxtx
pxtx's Avatar
I agree, it's a pretty rare head. I think my ego would tell me to run the old dogs rather than the Vortecs which seem like belly-buttons around here.
All things being equal the Vortec might make more HP, but that might actually be a funciton of the cc volume than the port design in your case.
Real world Dollars and Cents, I don't knwo what a new set of Vortecs cost with all of the extra items you need to install them, like intake or re-drill, rockers, valve covers, it all adds up. You kinda know your cost ong the old dogs.
I will conceed that the new Aluminum Vortec heads seem to be even more attractive. They take either intake AND either Valve cover AND are aluminum!
http://www.jegs.com/i/GM-Performance...oductId=749898
Paul
1965 Malibu SS | 1987 4000CS 20vt | 2000 323ci Cabrio | 2000 Yukon | 2001 Crew Cab 8.1/Allison
Old 10th-May-2011, 05:54 PM   #8
luepke75
(OP)
luepke75's Avatar
Garage
Yea I have everything to build the motor so it wont be cost effective to switch to the Vortec's. Im leaning towards have the camels built and ussing those.
Nor-Cal Classics
Old 10th-May-2011, 06:50 PM   #9
Lugnut79
Lugnut79's Avatar
What work do the camels need? If it's just a car for your daughter to putt around in I wouldn't spend the cash. If the 487's are in good working order, use those. That's my 2 cents at least.
Old 10th-May-2011, 09:09 PM   #10
stock z/28
Hi guys
Just my opinions, but I would be very surprised if the 487x had any meaureable difference with a regular 487.
Personally I dont think they are all rare either.
The "X" head that I have seen that is better or rare are the 461xs.
I would say (for what its worth) that either of the 487s are probably my favorite of the early tapered seat spark plug heads.
If they are in good shape I think they make reasonably good low compression street head. I think they have induction hardened ex seats and I would look at those carefully for cracks.
Good luck
Jeff
Old 10th-May-2011, 09:21 PM   #11
luepke75
(OP)
luepke75's Avatar
Garage
Everthing shop next to me will do it all for $400 since I send business their way.
Nor-Cal Classics
Old 10th-May-2011, 09:28 PM   #12
d64nova
d64nova's Avatar
Nova(s): 67protouring/drag car 63
jeff if those are good use them youre girl wont noitce the difference and your pocket will will stay fuller of ********$
Old 10th-May-2011, 09:41 PM   #13
luepke75
(OP)
luepke75's Avatar
Garage
I think your right Denny. I'll have the shop go over them and make sure there good to go. Hmmmm now what do I spend the money I dont have on?
Nor-Cal Classics
Old 10th-May-2011, 09:44 PM   #14
d64nova
d64nova's Avatar
jeff im sure you have an idea
Old 11th-May-2011, 01:03 AM   #15
fasteddie
fasteddie's Avatar
Nova(s): 1968
Bolt them suckers on and dont look back!
Head info carjai Drivetrain & Performance 6 10th-January-2009 12:35 AM
GREAT free head flow info!!!!! askgene Drivetrain & Performance 19 18th-December-2008 10:13 PM
041X Chevy cylinder head info 1974_SS Drivetrain & Performance 16 1st-October-2008 02:20 AM
Aluminum head info? USMCNOVA Drivetrain & Performance 5 8th-January-2008 03:17 PM
