4th Generation('75 - '79) Wheel and Tire Fitment - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Wheels and Tires
Old 21st-April-2011, 12:52 AM   #1
novanutcase
(OP)
novanutcase's Avatar
Title: Moderator
I've started this section to make it easier for those that have questions about wheel and tire fitment and what others have used/done. Please post ONLY 4th generation examples of wheel/tire fitment data along with whatever other suspension modifications or not that you have that may affect other members final numbers. Data should include wheel backspace, width of wheel, tire size, etc. Also, please include any pictures you may find that would be helpful. Explanations are great but, as they say, a picture is worth a thousand words!
Please keep any questions about setups in the main wheel and tire section. I'd like to keep the banter to a minimum and just host data and pictures to make it easier to navigate the thread. If you have a specific question about someones setup you see here I encourage you to PM them any pertinent questions you may have.
Thank You!
John
Build Pics(No Comments)
Old 12th-March-2012, 02:04 PM   #2
Atrious
Atrious's Avatar
Title: Nova Newbie
Nova(s): 1976 Nova all original
Garage
1976 Original 14" rally tires.
I believe I have an original full size spare in my trunk. It is off of a 1976 Medalist package with optional 14 inch Rally wheels (as seen in pics).
Last edited by Racinfan83; 12th-March-2012 at 06:23 PM. Reason: Pics didn't load. Moderator - For Sale Ad
Old 23rd-May-2012, 03:38 PM   #3
novaboy009
novaboy009's Avatar
The largest common rear tire size for an untubbed 4th gen Novas is a 275/60 15. This size may require rolling the lip or moving the shock inboard depending on the backspacing of your wheels and the brand of the tire. Typically they slide right in with 4.25-5" of backspacing. Less than that will rub the fender lip. A 255/60 15 is a more conservative fit and plenty of tire if you're worried about it.
Fronts - I've run: 225/60 15, 235/60 15, 235/60 14, 205/70 15. Pretty much if the wheel goes over the disc brakes and you pick something around that height/aspect ratio you'll be fine. You might be able to get a little bigger tire but it will likely look stupid.
Remember that 4th gens have a wider front spacing than rear, so you're better off having more backspacing in the front than the rear, using a wheel spacer in the rear, or running a skinnier wheel/tire up front so they don't look like they're hanging out too far.
I can't speak to the larger diameter wheels. I can tell you that our cars work best with around 4 inches of backspacing with a 15 inch wheel. The 3" b/s wheels don't look or fit right.
This is 255/60 15 and 225/60 15.
235 60 14 all the way around with 3.25" b/s.
235 60 15 on the back, 215/70 front on my dad's 75.
295/60 14 on back, 195/70 14 front. They don't fit with 2.5" b/s wheels but I tried.
Same wheels fitting:
295/50 15 DR's. Don't really fit.
Hope that helps.
78 Nova - autocross/drag/street car with nitrous
Old 25th-May-2012, 08:08 AM   #4
ALLT4
ALLT4's Avatar
Nova(s): 1977 Concours ZZ383
American Racing Hopsters
15X8X4.5" rear w/ BFG Radial T/A 275/60/15 (Also fit 275/60/15 M/T ET Street)
15X7X4.25" front w/ BFG Radial T/A 235/60/15 (I would recommend 4.5" BS on these it should fit mine stick out a little at 4.25" BS)
Old 25th-May-2012, 02:22 PM   #5
racerex1
racerex1's Avatar
Nova(s): 78 SS Clone
29x9x15 Hoosier slicks,26-7.50-15 sportsman fronts Jegs pro stars 15x4 and 15x8 4.5 bs. Had to roll the lips and have slid-a-links on the rear.
Old 26th-May-2012, 09:10 PM   #6
YenkoDeuce
Thumbs up
Great job guys! Hope we get some more.
Old 12th-November-2012, 11:41 PM   #7
pastenseverb
pastenseverb's Avatar
Nova(s): 1976
I'm looking to put 17X8 wheels on my 76 this spring. I tried last summer but the front tire rubbed on the outside side of the fender well. I will have to special order a set of wheels with a 4.5" BS. The ones that didn't work had a 0 offset. Does the 4.5" work?
Old 13th-March-2013, 06:54 PM   #8
YenkoDeuce
Originally Posted by NOVAGEDDON View Post
Hey guys I dont know what took me so long to join this forum but here I am. I figured Id post here first since I figured ya'll could most appreciate it. Anyways a little background. Ive owned this car about 11 years and it was my first car that I drove to highscool. It was a stock 305 and factory 4 speed car and was blue with racing stripes and light blue interior. Now a 489 BBC with a th400 trans. Havent touched the car since 2005. But Im going to redo some things and bring it back out as soon as i can.
Rear tires are 275/60/15 15 x 8 weld wheels with i believe 4.5'' backspacing. again I would double check all that if its a factor for you ever placing an order yourself. I rolled the rear wheel lips only because if i got sideways on the street they would rub, or cut I should say. If you just drove it around it didnt but that wasnt the case with how i used to hotrod it around town. I also lightly banged in the inner side of the wheel well cause they were starting to rub/cut there too on the inside of the rear tire. Nothing touches now. And they fill the wheel wells up nice.
Novageddon responded to wheel and tire size questions I asked in the 4th Gen section.
Old 13th-March-2013, 07:27 PM   #9
RedDirt
RedDirt's Avatar
Nova(s): 1977 Nova
Here is my '77. Wheel/tire combo fits great with no rubbing issues. The rear will drop 3/4-1" when I put the interior back in, but I do not foresee any issues.
Rear: 15x8 4.50" BS BFG Radial T/A 255/60R15
Front: 15x7 4.125" BS BFG Radial T/A 235/60R15
Old 18th-March-2013, 01:53 PM   #10
polar_bowtie
polar_bowtie's Avatar
Title: Nova Newbie
Nova(s): 1977
Nice
Nice Car I have a 1977 myself and yellow as well.
I was wanting to change to the same size back tires as you, do you have nay issues of them rubbing is your suspension stock?
Old 19th-March-2013, 04:38 PM   #11
YenkoDeuce
This is excellent. Thanks for posting it in this section, also!
For those interested check out RedDirt's '77 project here: http://www.stevesnovasite.com/forums...d.php?t=214876
Old 4th-April-2013, 08:10 PM   #12
carbon_x
Nova(s): 1976 Nova Base Model
Yes, this is great. I'm looking for new tires on mine since they're dry-rotted and separating. This combo looks great.
1976 Nova with a 400 Small Block Chevy. Currently being restored.
Old 4th-April-2013, 08:32 PM   #13
DPack77
DPack77's Avatar
Nova(s): 1977 350/700r4/3.42
Garage
215/70R14 on 14x6 front (stock rally wheel)
255/60R15 on 15x8 rear w/ 4.5" BS (Wheel Vintiques 29 series)
Old 5th-August-2013, 08:05 PM   #14
Nova1978
Nova1978's Avatar
Nova(s): 1978
Wheels are centerline lazer IIs, tires are NITTO NT555s. 245/45R17s on 17x8 with 5" BS up front and 275/40R17s on 17x9.5 with 6" BS out back. So far only a small rub on the inner portion of the rear passenger wheel well. It has about 0.5-0.625" of clearance on the inside, so this was from either articulation or axle movement. I'm thinking articulation is more likely since I was going only on straight roads. I know it isn't the best thing to do, but I'm ordering a 1/8" spacer that should take care of this. I verified I will still have 1/2" of threads engaged in the lug nuts even with the spacer.
1978 Pro-Touring, 383 200-4r
Old 8th-August-2013, 01:40 PM   #15
YenkoDeuce
Thanks for posting your set up.
1st Generation('62 - '65) Wheel and Tire Fitment novanutcase Wheels and Tires 239 10th-March-2017 07:55 AM
2nd Generation('66 - '67) Wheel and Tire Fitment novanutcase Wheels and Tires 97 18th-January-2017 09:47 PM
Wheel/Tire Fitment novaracer1 Drag Racing Forum 2 17th-August-2010 09:21 PM
Wheel/ tire fitment... tdbutler Steering, Suspension, and Chassis 3 3rd-November-2009 10:56 AM
