FelPro one-piece oil pan gasket questions & PN's - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > Best of Drivetrain & Performance
Old 11th-April-2005, 02:53 PM   #1
70Deuce
(OP)
I think I've decided to use a one-piece oil pan gasket on my motor, SB350, but wanted to hear any comments from you guys that have used them. And I also have a question, Do you still apply gasket sealer to the corners around the front and rear mains (as I read in a magazine article)? I'm ready to install the pan so any info would be appreciated. Thanks.
70 Deuce
Old 11th-April-2005, 03:06 PM   #2
MarkM68
Used it. Works fine. I little gasket sealer in the corners won't hurt, may or may not be necissary.
Old 11th-April-2005, 04:05 PM   #3
Paul Wright
Paul Wright's Avatar
I think they are great. They come with little plastic thread in dowels. Make sure the threads are clean and chased....(no, not "chaste") or you might have trouble getting them back out.
It should have instructions, but I don't recall it needs any sealer
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 11th-April-2005, 04:06 PM   #4
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
I put a little dab of sealer in the corners to be on the safe side. No problems so far. I like the anti-crush spacers in the gasket too
Don't worship false idles
Old 11th-April-2005, 05:29 PM   #5
ryan63
ryan63's Avatar
Nova(s): gone
I like it too. I have a Milodon 7 quart pan and cloyes "quick button" timing chain cover, mine did require a little sealer on the front seal. Not too bad just a little drip after high RPM use.
63 chevy II
406
TH350
4.10's
Best ET: 11.16@119 looking for 10's with a little tuning.
Old 11th-April-2005, 07:47 PM   #6
NOGO
NOGO's Avatar
Garage
One piece is the only way to go! For piece of mind I put a little dab of silicone in each corner of the block.
Corra su coche, no su boca!
Old 11th-April-2005, 08:13 PM   #7
BOGIE
BOGIE's Avatar
I used it in the Cloner..... works great. If you are the rare breed of guy that actually reads instructions...... it states.. "do not use silicone!!!" It's a simple thing really, rubber won't stick to silicone, "bond" is the better term. I didn't use silicone (although it was tough!!).... and no leak.
good luck Ric
New Baby in the garage!!! !!!
Old 12th-April-2005, 01:08 AM   #8
teddisnoke
teddisnoke's Avatar
Just put mine in last week and it leaks from the rear. I'm kinda surprised. Re-torqued the bolts. I'm tempted to pull the thing apart and re-do it a third time. It most likely is NOT the gasket and something I've missed or not done correctly.
Old 12th-April-2005, 01:11 AM   #9
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
just don't be oilin' down the track Teddisnoke !!!
Johnny (aw heck Dale) can't ya weld it up ???
the Flyer Special
'64 411 377-Tko600-3:73's
Old 12th-April-2005, 01:28 AM   #10
1971novaSS
1971novaSS's Avatar
Hey Teddi, i pulled my motor 4 times and replaced the thilnksndifgn;laksdf thing every time due to it leeking. All and all It was because of the Summit racing 7 quart oil pan. The gauge of metal was to thin and when i would torque it down with the one piece gasket it would always leak. I tried both putting sealer in the corners and not putting it in the corners. Either way it didn't leak any differently.
Solution: Bought a 350 dollar Canton Racing 8 quart pan. Put the one piece in and put a scoche of sealer on the corners(a film with the finger). Torqued it down and doesn't drip a drop or even have a juicy fart of oil!
It is most likely your pan, check the metal thickness and if the holes cave in just a little, the slightest amount will create problems.
Good mistake to be learned by my stupidity and youngfullness. I did get real good at pulling th e motor, could get it out in 3 hours, drop tranny, wiring and pulling included. Haha
-Rennskii(have to pull it again to put her in the SS)
Old 12th-April-2005, 04:21 AM   #11
rjy
Nova(s): 1964 nova
used the one pcs twice and would never even think of going back to the old style. They are made so they can not leak unless you have other problems. No sealer needed and you can also reuse them. I wont , but they say you can. Well worth the the 25.00 bucks I paid.
Old 12th-April-2005, 08:22 AM   #12
70Deuce
(OP)
Sounds unanimous. Thanks for sharing your experiences. Bob
70 Deuce
Old 24th-April-2005, 02:34 PM   #13
teddisnoke
teddisnoke's Avatar
Fel-Pro part number
Anyone know off-hand what the Fel- Pro part number is for the one piece gasket on our pans (rear sump Moroso pan, 400 block). I'm going to try and order it along with some other small things from Summit tonight. THANK YOU in advance for the help. Dale
Old 24th-April-2005, 02:45 PM   #14
DriveWFO
DriveWFO's Avatar
This one?
http://store.summitracing.com/defaul...t=FEL-OS34510T
Old 24th-April-2005, 02:51 PM   #15
the FLYER
the FLYER's Avatar
or these ??? http://store.summitracing.com/defaul...h.asp&N=400101
FPP-1880 Fel-Pro Performance Oil Pan Gaskets
Oil Pan Gasket, 1-Piece, Rubber, Steel Core, Chevy/ GMC Small Block, Each $38.69
FPP-1885 Fel-Pro Performance Oil Pan Gaskets
Oil Pan Gasket, 1-Piece, Rubber, Steel Core, Chevy/ GMC Small Block, Driver Dipstick, Thin Front Seal, Each $37.88
my link doesn't show proper listing, but you can click to the application page from it
the Flyer Special
Oil Pressure questions + HV pumps, pump drive and collar Bucs01 Best of Drivetrain & Performance 235 12th-November-2006 05:40 PM
Oil Pan! DuDe Drivetrain & Performance 13 19th-June-2006 12:20 AM
Need a New Oil Pan for 65 w/Inline Fredsgarage Drivetrain & Performance 5 24th-May-2006 07:00 PM
Oil pump, pickup, pan DriveWFO Drivetrain & Performance 10 18th-May-2006 08:28 AM
Oil pan removal update Nova1194 3rd Generation Chevy II/Nova's 2 12th-April-2006 01:15 AM
