Rear shock mount...help - Chevy Nova Forum
Old 7th-April-2011, 11:59 PM   #1
nick72nova
(OP)
nick72nova's Avatar
Nova(s): 72 nova,406,4spd,12bolt
ok when i was removing the old shocks and bolts on my 72, 3 of the bolts came out and of course the last one was seized in and the head broke off...is there a way i can remove the rear shock mount? and remove the broken stud or buy a new mount?
thanks
Old 8th-April-2011, 10:18 AM   #2
zman1969
zman1969's Avatar
Nova(s): 1969 Nova SS 1966 SSold!
shock bolt
I'm assuming its one of the upper bolts It may require center punching it and drilling it out to like 1/4" and retapping the threads(or whatever size is correct to retap to 5/16"). When I put rear shocks on my 69 I retapped all my upper holes since I had no idea how long it sat w/o shocks on it and I'm glad I did it
edit: - delete this statement- see 1320quicks note below
"or little larger and use a longer bolt with a nut on top - should be accessable thru the trunk"
please disregard I know on my camaro its accessable
69 Firebird clonification LS6/6spd
69 R/S Z28 302 4 spd 4.10 Daytona
69 Nova SS
99 Trans Am Firehawk
Old 8th-April-2011, 11:30 AM   #3
iroc343
iroc343's Avatar
Nova(s): 1970 SS L78
Your best bet is to drill out the bolt and retap it to 5/16-18. The key is to get the drill as close to centered as possible. I usually start with an 1/8 inch drill and work my way up. Your going to want to end up with a letter F drill (.257). Take your time, you'll get it.
Old 8th-April-2011, 11:43 AM   #4
1320quick
Nova(s): 1971 Nova 1968 Chevy II
There is no access to the top side of the shock mount. I just did a mini-tub on my 68 and I cut all that stuff out so I know how it is put together. The upper shock mount is a 1/4" steel plate that is spot welded to the heavy rear support area sandwitched between the trunk floor sheet metal the bottom sheet metal. The easiest way to resolve this issue is as others have mentioned. Drill out the broken bolt and re-tap the threads. Anything else is going to be a MAJOR project.
Old 8th-April-2011, 05:11 PM   #5
graymond
graymond's Avatar
Nova(s): 1970 Acadian SS350
Garage
I had the same problem with the right rear shock mount.
In my case, the floor of the trunk had been badly repaired with fiberglass. We cut some of that out and fabed up a new mount with the correct threads etc. Bought some body bolts and away we go. The mount had been heli coiled by a previous owner. Did not last removing the shock.
Will have to repair the trunk at some point.
Ray
1970 Acadian SS 350 355ci four speed
1967 Chevy C10 502 Turbo 350
Old 8th-April-2011, 06:30 PM   #6
nick72nova
(OP)
nick72nova's Avatar
ok thank you guys
Lower rear shock mount plate BLYOTH 3rd Generation Chevy II/Nova's 4 17th-January-2011 03:26 PM
Rear upper shock mount zboggs 4th Generation Nova's 3 18th-September-2010 06:32 PM
rear shock upper mount evan67ss Steering, Suspension, and Chassis 2 18th-July-2009 12:10 AM
Rear Shock Mount Problems Citypol86 Steering, Suspension, and Chassis 4 7th-March-2009 11:01 AM
