Carb too big?? - Chevy Nova Forum
Old 28th-March-2011, 10:23 PM   #1
Millertime
(OP)
Title: Nova Newbie
Nova(s): 72 Nova
Carb too big??
I bought my car with the 350 engine already built. I just installed a new MSD ignition setup trying to get my car to run smooth. During my research i found out the carb on my car is a Holley Part# R4781-5 or 850CFM!! Isn't a 850 carb big on a 350??
Old 28th-March-2011, 11:09 PM   #2
levisnteeshirt
Nova(s): shopping for the 6th one
yes it is ,,,, unless it has some serious compression , and is a full race engine ,, i would take it off
give us some details on the motor
Old 28th-March-2011, 11:12 PM   #3
big dog ss
big dog ss's Avatar
Nova(s): 1970 SS
depends on what has been done to the engine.. a modified 350 can handle a 850.. what are the specs on your engine?
"It is the duty of the Patriot to protect his country from it's government"...Thomas Paine
Old 29th-March-2011, 10:32 AM   #4
photoman
photoman's Avatar
That's listed as a 4150. Is it vac or mech secondary?
1969 Nova
350
TH400
8.5" 10 Bolt
Old 29th-March-2011, 11:00 AM   #5
levisnteeshirt
i had a 800 dp on a mild 350 a while ,, a 600dp or a 750 vs did way better
Old 29th-March-2011, 02:00 PM   #6
Millertime
(OP)
Title: Nova Newbie
Nova(s): 72 Nova
mechanical, im going to upgrade my spark plug wires and battery and see if i can get the spark to keep up with all the fuel.
Old 29th-March-2011, 02:22 PM   #7
levisnteeshirt
smell your oil from time to time ,, make sure it doesn't start to smell like gas
Old 29th-March-2011, 03:08 PM   #8
bracketchev1221
bracketchev1221's Avatar
Nova(s): 70 SS 350(sold)
It's too big. Plain and simple. I ran an 850 on a 615hp 383. On my 465 hp 355, a 750 killed an 850 in back to back comparison.
Ray
Old 29th-March-2011, 04:09 PM   #9
Millertime
(OP)
Title: Nova Newbie
Nova(s): 72 Nova
can you rejet the carb? or is my only safe option to just buy a smaller carb?
Old 29th-March-2011, 05:57 PM   #10
big dog ss
big dog ss's Avatar
Nova(s): 1970 SS
if you have a mild 350 sb i would get another carb..
Old 29th-March-2011, 07:10 PM   #11
Plowman
Plowman's Avatar
Nova(s): 1967 1969
Smokey Yunick Ram Intake
Smokey Yunick ram intake - Smokey said one 850 carb on a 302 is enough. I was going to run the intake on a 350 cu inch engine with an 850 cfm carb.
Old 29th-March-2011, 07:33 PM   #12
levisnteeshirt
smokey yunicks 302's were 12.5 or more compression ,, 8000 + rpm engines ,,, ran for short periods before the oil was changed ,, things like that
Old 29th-March-2011, 07:37 PM   #13
testcase
testcase's Avatar
Nova(s): 66 Drag car
Originally Posted by Plowman View Post
Smokey Yunick ram intake - Smokey said one 850 carb on a 302 is enough. .
Enough for it and the 283 sitting next to it....
It would take a BUNCH of RPM to make that work.
Tod
Old 29th-March-2011, 08:04 PM   #14
Zman
Zman's Avatar
IMO, 850 CFM Mechanical is WAAAAY to big for a mild 350.
If the car has auto trans, you would be much better off with maybe a 600-650 cfm Vacuum Secondary. DPs don't work well unless you have a built auto with higher stall converter.
Dennis
69 Nova 355/M-21/3.90 12 bolt
68 Chevelle SS 396 4 spd.
1929 Model A Coupe Stock
Old 29th-March-2011, 08:20 PM   #15
balljoint
balljoint's Avatar
Nova(s): 1978 chevy nova
There are alot of myths about carb cfm,there are small blocks that run 1000cfm domanators and love it,I have seen small blocks with high rise intakes with dual 600 cfms x2=1200 cfm ,while others cannot make a 600 1850 work right ,I have a 780 holley on a 355 and the engine loves it ,there are some guys who say you can make any size cfm carb work on a small block,and some that say 500cfm is all that is needed,some say the more air you can push through intake the better,who really knows? How does the car run with that carb? Is it the carb or igntion or a mech issue? The carb may or may not be right for that engine ,just saying.
is my carb to big? gfercaks33 Drivetrain & Performance 2 20th-September-2010 02:49 AM
Holley Carb Gurus...Big Al? Anyone? Sooner1 Drag Racing Forum 30 2nd-August-2009 09:41 PM
Am I stuck with a carb thats too big? silky63ss Drivetrain & Performance 2 16th-March-2009 05:24 PM
New carb from the big guy youngin69nova Drivetrain & Performance 12 22nd-December-2008 11:14 PM
How big of a carb? 62bandwagon Drivetrain & Performance 7 18th-June-2006 11:02 AM
