LS exhaust for 1st gen stock front clip - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > LSx Forum
Old 18th-February-2011, 09:09 PM   #1
MTNNOVA
Nova(s): 1967 2Dr HT
I recently read a tech. article comparing the costs and installation recommendations for an LS motor versus a 1st generation SBC in a 66/67 Nova with a stock front clip. It recommended using the 03-09 Trailblazer exhaust manifolds because they hug the block and have rear dumps. Anyone tried them in a 1st or 2nd generation Nova?
Old 18th-February-2011, 10:12 PM   #2
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
From what I have read no production manifolds will fit a stock clip.You may be able to make something work if you were willing to notch the shock towers.CBR makes a nice set of headers but require the CBR rack and pinion conversion as well.A nice addition with a modern drive train upgrade.
Member of the NorCal Brotherhood!
Old 18th-February-2011, 10:17 PM   #3
novaBRO
novaBRO's Avatar
Nova(s): LS powered 64 wagon
these are stock manifolds for a 2006 trailblazer
325 (5.3)
2003-06 Envoy XL
2004-05 Envoy XUV
2005-06 Envoy (Denali)
2004-07 Rainier
2003-04 SSR
2006 Trailblazer
2003-06 Trailblazer EXT
RIGHT ON BRO!
THE LONGROOF SOCIETY
NorCal Novas Proverbs 13:3
Old 18th-February-2011, 10:56 PM   #4
Burke
Nova(s): 1963 nova wagon
I saw that article as well, I believe it is wrong. Unless you want to modify the passenger side shock tower I don't believe you will get a stock manifold in on that side
63 wagon L33 4L60E 12 Bolt 3.73 VA gen IV Willwood Brakes CBR front w/power rack & Watts link rear
Old 19th-February-2011, 02:56 PM   #5
MTNNOVA
Thanks for the replies. When I read the article I had my doubts. The $125 price tag sounded much better than $900 for a set of headers. I probably would have sacrificed a little power for the difference in ****. The next time I get to a wrecking yard I will try to check out the trailblazer manifolds. Maybe an angle mill job will tuck them in a little tighter? Probably just wishful thinking.
Old 19th-February-2011, 06:07 PM   #6
greasemonkeychef
greasemonkeychef's Avatar
Nova(s): 1964 nova
I havent heard of anyone trying these manifold out yet. Would be interestiong to see if they would fit or what mod would be needed?
Old 19th-February-2011, 10:22 PM   #7
Kryptonite
Kryptonite's Avatar
Nova(s): 1967ss with c4 suspension
i did try a set of these and the place where they interfere is at the flanges, they have a larger flange and it hits the vertical plates where the front clip bolts on, i was going to try machining the header flange on a slight angle but it wasnt enough so i got a set off the bay ,( the ls1, ls6 shorty stainless headers,)these fit but still needed a light shave of these vertical plates,i will post pics as soon as i remember how to upload them
Old 19th-February-2011, 10:29 PM   #8
Kryptonite
Kryptonite's Avatar
[IMG]http://[IMG]http://i1206.photobucket.com/albums/bb453/kryptonite1967/ls%20swap/tach006.jpg
[IMG]http://[/IMG] IMG]http://i1206.photobucket.com/albums/bb453/kryptonite1967/ls%20swap/tach005.jpg
[/IMG][IMG]http://i1206.photobucket.com/albums/bb453/kryptonite1967/ls%20swap/tach004.jpg
[IMG]http://i1206.photobucket.com/albums/bb453/kryptonite1967/ls%20swap/tach003.jpg
[IMG]http://i1206.photobucket.com/albums/bb453/kryptonite1967/ls%20swap/tach001-1.jpg
Old 19th-February-2011, 10:32 PM   #9
Kryptonite
Kryptonite's Avatar
Red face
there are 5 pics if you scroll across, need to resize them again
Old 21st-February-2011, 04:31 PM   #10
MTNNOVA
Those pictures are great Kryptonite. My initial concern was shock tower interference on the stock clip - wasn't thinking about the vertical frame/body supports. I see you have a front clip - any thoughts or experience on the stock clip/trailblazer exhaust fitment. Also, couldn't tell how much radiator clearance you have. In your opinion, would moving the motor ahead an inch help? Lastly, the shortys you have look a little wide for a stock clip - your thoughts?
MTNNOVA
Old 22nd-February-2011, 10:34 AM   #11
greasemonkeychef
Nova(s): 1964 nova
Thought this thread was about "stock" frontends??????
Old 22nd-February-2011, 05:01 PM   #12
itslow
Nova(s): '66 LSx/TKO Project
That mounting point is the same regardless of whether the car has a stock or aftermarket clip. Doesn't matter if the manifold will hit the shock tower or not.
Mike
'66 Hardtop - LSx/TKO swap in perpetual process
'67 SS - Pro-street & forever in pieces
Old 22nd-February-2011, 05:02 PM   #13
MTNNOVA
It started out about a stock front end. Hopefully, if it continues, it will focus on the stock front end. Even though the photos Kryptonite posted were in a clip, they were still very informative. I was hoping to avoid reinventing the wheel by pursuing the Trailblazer manifold when someone else has already been there. I was hoping to find a cost effective solution to the LS/stock front end issue. It's beginning to look like it's $1,000 or build your own.
Old 22nd-February-2011, 05:47 PM   #14
TomM
TomM's Avatar
Nova(s): 1966 - Coupe
Garage
First off...Krypto, can you fix the pictures, you don't need to resize, just stack them on top of each other, not side by side......makes it almost painful to read this thread...
Secondly, I have thought about getting a set of Corvette exhaust, I think they are called the "tall" ones, look sorta like a ram horn, a little past center dump and have them angle milled. They are stainless, so you could cut the collector off, if it's in the way, and reclock, and weld it back on......don't remember the body style, C4 or C5 maybe with the LS motor.......I would suspect you wouldn't need to take more than a few thousand'ths (sp?) off the bottom side to get it to lean in toward the block....if someone hasn't tried this by the time I get to setting the motor in the wagon, I am going to try it. I wouldn't wait on me though, it's going to be a few months......
T,
Old 22nd-February-2011, 07:42 PM   #15
Kryptonite
Kryptonite's Avatar
how do i stack them??
1st gen front clip 65novaken Steering, Suspension, and Chassis 12 26th-December-2010 01:04 AM
ls1 swap in 1st gen w/ stock clip? sick63novass Drivetrain & Performance 34 11th-February-2010 02:20 AM
Anyone know magic...... Blown BBC in a 1st Gen w/ stock clip Notch Johnson Drivetrain & Performance 0 30th-January-2008 11:49 PM
Racing with a stock 1st gen front clip? 65GASSER Steering, Suspension, and Chassis 3 14th-May-2006 12:03 PM
