oil pump primer tool - Chevy Nova Forum
Old 12th-February-2011, 06:57 PM   #1
car_man602
(OP)
Nova(s): 1972
Trying to find pics or directions on how to make a oil priming tool from an HEI dist. I have a old HEI dist that I would like to make a priming tool out of. Getting ready to start motor for the first time ,adjusted valves and installed header gaskets today all I need now is my new engine harness to arrive from AAW and to prime motor.
Old 12th-February-2011, 09:21 PM   #2
Paul Wright
Paul Wright's Avatar
You just need the shaft and the housing. Remove the gear and everything else.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 13th-February-2011, 12:52 AM   #3
chillipepper
Nova(s): '75 Nova Custom
I made one out of a length of round bar with a slit cut to fit the oil pump, then added a piece of rubber tubing over the end to keep it centered on the oil pump.
Much easier than cannibalizing a distributor.
Old 13th-February-2011, 06:35 AM   #4
frogman68
frogman68's Avatar
Nova(s): 69 Nova 63 Wagon
Not sure where your at in MD but I got one sitting in the garage (oil priming tool) I am in Elkton PM if you are close and want to borrow it
Old 13th-February-2011, 07:21 AM   #5
awes
awes's Avatar
Nova(s): -65
What I learnt is to prime the engine until you see oil coming out of each of the rockers. (Which takes a while)
How do you fixed so you get oil to the lifter gallery and up to the heads with that?
Anders
Spånga, Sweden
5.77/126 1/8
8.92/154 1/4
Old 13th-February-2011, 09:40 AM   #6
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): To be determined...
I don't think it will come out of the rockers unless the engine is rotating. It will only pump oil up to the lifter valley.
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 13th-February-2011, 09:54 AM   #7
62 NovaWagon
62 NovaWagon's Avatar
Nova(s): 62 LongRoof with Inline 6
Made this one out of an old wore out junker!..
Old 13th-February-2011, 10:53 AM   #8
Philip
Philip's Avatar
Title: Moderator
Here is mine, I need to take it to Art so he can machine off the point housing. I cut the toothed gear off which gave a longer shaft to get the drill on.
64 Nova 400 series 4 door
SOLD 01/15
Old 13th-February-2011, 10:53 AM   #9
woodnmetal
woodnmetal's Avatar
Nova(s): 67 coupe
Yeah I made one out of an old distributor, I was told to do so, because there is a journal on the distributor shaft that blocks off a passage, allowing oil to make it through the engine and will eventually come out the rockers,,, You may only get oil coming out some of the rockers, when you do, then turn motor 90 or 180 degrees and prime again, keep doing it until all the rockers get oil.
This is how I did it. hope this helps out somehow.
Old 13th-February-2011, 11:04 AM   #10
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
Priming engine.
If on a engine stand rotate the engine while priming.
Will take 2 people.
Priming engine in car.
Get oil pressure and then crank the engine over while priming.
Name:	Oil primer tool.jpg
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 13th-February-2011, 11:21 AM   #11
woodnmetal
woodnmetal's Avatar
Nova(s): 67 coupe
Originally Posted by The Big Al View Post
Priming engine.
Will take 2 people.
I am wondering,, I have heard different ideas on this subject,
I did get all the rockers to get oil doing what I did,(post#9) but it probably took me 15 to 20 Min's,not sure , I was not watching the time.It took a little.
I have never been told to use two people.
Old 13th-February-2011, 12:25 PM   #12
The Big Al
The Big Al's Avatar
Ok, then hold the drill and rotate the engine!
Old 13th-February-2011, 12:39 PM   #13
woodnmetal
woodnmetal's Avatar
Nova(s): 67 coupe
LOL I didn't mean it that way.
why do you have to turn the engine constantly while priming?????? BIG AL huh?
Old 13th-February-2011, 07:35 PM   #14
Rbace123
Nova(s): 1966 Chevy 2 nova
If you don't turn the engine while priming you can run the drill all day and never get oil out all of the rockers. At least i Couldn't. Gave up after a few minutes and started rotating the engine. The rotating engine moves the oil passages around so you can get oil everywhere. You need a good drill and patience.
Old 13th-February-2011, 07:57 PM   #15
I8IMPORTS
Title: Nova Newbie
Nova(s): 73 hatchback
just made mine out of an old msd it was easy like it is stated 5 minutes or less
oil primer gfercaks33 Drivetrain & Performance 6 1st-June-2010 02:18 AM
Gear chatter noise from primer tool Greg_R_63 Drivetrain & Performance 47 18th-December-2009 02:19 PM
1st gen. 383 oil pan & oil pump?? 62bandwagon Drivetrain & Performance 3 31st-March-2008 09:37 AM
Oil Pump Primer novaboy009 Drivetrain & Performance 24 20th-July-2006 12:41 PM
