4sp shifter location - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Originality
Old 18th-October-2010, 11:55 PM   #1
daven
(OP)
Title: Nova Newbie
Nova(s): 1966 Pontiac Acadian Cans
I have a 66 small block with an auto. I'd like to convert it to a manual, a Muncie would be easier but I'm thinking I'd like to go more modern like a Richmond 6 speed. Does anyone know what I can swap in to land the shifter in the factory location. I'd have no problem moving the engine forward or backward a few inches but it'd be nice to find a trans/shifter combination that would enable the use of that original 4spd center console.
Old 19th-October-2010, 06:57 PM   #2
69Camaro
Nova(s): n/a
For some ideas, Google search "chevy nova 6-speed conversion"
Looking at these links will show you where to look:
"www.hurst-drivelines.com/index.php?option=com...view..."
"www.classicchevy5speed.com/Camaro-Nova-6-speed-T56-Slect.aspx"
"www.stevesnovasite.com/forums/showthread.php?t=104713"
Read the whole stevesnovasite post and then you'll probably decide on the 5-speed or 4-speed. The 6-speed is the most expensive and hardest install with tunnel space problems. The 5-speed is in the middle on cost and ease of installation. The T-10 4-speed is the cheapest and an easy install.
Don't forget or rule out using a 200R 4-speed automatic if you want a good overdrive that is overlooked but is an easy install using the same driveshaft you have already.
Gary
Old 20th-October-2010, 12:53 AM   #3
daven
(OP)
Title: Nova Newbie
Those are good links Gary! Lots of good information there - Thanks! So it looks like shifter location is not a huge obsticle with a T56 and the Black Jack shifter. Will a T56 fit inside the tunnel? You've indicated that this may be a problem. I seen them on the shop floor and they're not a small trans but they are readily available. I've no concerns about drive shaft length, thats a cheap problem considering the overall cost of the project, but I'm not ready to cut out or bash up my nice OEM floor/tunnel.
Old 20th-October-2010, 06:07 PM   #4
69Camaro
Nova(s): n/a
I may be wrong on the 1966 tunnel space but I do know that guys with 1968-72 Novas have had problems with the 6-speed T-56, though they could be modified to fit.
I'll try to find out more about your 1966 fitting a 6-speed.
Today on Thursday, October 21. I think the complete Hurst kit with the Black Jack shifter, tunnel patch kit, new cross member and all new subframe body bushings will work.
Also be sure to read the Hurst Tech Notes and the testimonials.
Gary
Tags
4 speed, manual, shifter, transmission
T56 Install in 66 - shifter location BBPanel Drivetrain & Performance 17 13th-April-2011 06:26 PM
Shifter hump location 400nsum Member Introductions 2 15th-March-2010 11:39 PM
location of the floor shifter. canova 4th Generation Nova's 4 4th-June-2008 05:44 PM
Saganaw 4Sp shifter install Joe Buddy Drivetrain & Performance 0 21st-June-2007 11:21 PM
Shifter hole location on 3rd gen manual trans cars with bench seat Dawg Originality 14 21st-December-2006 07:19 PM
