200-R4 swap!! - Chevy Nova Forum
Old 21st-September-2010, 08:58 AM   #1
wcjames01
(OP)
wcjames01's Avatar
Nova(s): 62' 4dr sedan
200-R4 swap!!
I am looking at swaping out my 2 speed power glide for a 200-r4. Can any one tell me if this will be a 3 or a 4 speed transmission? I am needing to do this to try to get better gas milage. Will this help? I would think so because it will lower the RPM. The only other thing, is that I don't know if it is a auotmatic or a manual. I hope that it is a auto. Any feed back would be greatly appricated.
This is a used 200-R4 out of an 84 v-6 Camaro. It worked fine when it was pulled a few years ago. Comes with torque converter. $125 OR BEST OFFER!!! Call, Test, or Email. Please leave message if no answer. 864-505-0848
it's NOT ok to contact this poster with services or other commercial interests
PostingID:# 1923106861 ( It is in Greenville Sc. )
Thanks everyone,
W.C.James
62' Nova 4dr.
704) 779-3382
Old 21st-September-2010, 09:15 AM   #2
Burke
Nova(s): 1963 nova wagon
200R4 is a 4speed automatic. It should help considerably with mileage since 4th is OD. You will probably not recover the cost of the swap in fuel savings for several years though.
63 wagon L33 4L60E 12 Bolt 3.73 VA gen IV Willwood Brakes CBR front w/power rack & Watts link rear
Old 21st-September-2010, 09:23 AM   #3
wcjames01
(OP)
wcjames01's Avatar
R4 Swap
Thanks for the info. I thought that the 125.00 sounded like a very good deal, if it's in good shape. Is there any Trans mount changing or drive shaft changing? I'm just trying to get my ducks in a row
Thanks,
W.C.James
62' Nova 4dr.
704) 779-3382
Old 21st-September-2010, 09:25 AM   #4
wcjames01
(OP)
wcjames01's Avatar
R4 Swap
[QUOTE= You will probably not recover the cost of the swap in fuel savings for several years though.[/QUOTE]
Meaning what? I get about 12 miles to the gallon.
Thanks,
W.C.James
62' Nova 4dr.
704) 779-3382
Old 21st-September-2010, 09:46 AM   #5
Burke
You will need to shorten the driveshaft, get a new trans mount and crossmember, install cooling lines and a cooler, tv cable and brackets, converter lockup switch new shifter etc. you're probably looking at close to thousand dollars + the trans. by the time you get it installed and working.
I don't know what engine and trans you have now, but if you're only getting 12 mpg now you're money may be better spent on a good tune up.
Old 21st-September-2010, 09:53 AM   #6
wcjames01
(OP)
wcjames01's Avatar
Swap
I currently have a in-line 250 w/1bbl and 2 speed power glide. Might you suggest something that will give me a highway gear, lower the RPM and give a little better gas mileage. This motor was just swaped out about 2 months ago. The only thing done was machineing the head to level it back out, new plugs, new HEI cap and wire. Majority of the oil was lost during bringing the motor home, ( it turned over in the truck ) so I added 4 qts and now it reads full and the oil looks ok.
Thanks,
W.C.James
62' Nova 4dr.
704) 779-3382
Old 21st-September-2010, 10:03 AM   #7
Burke
Taller rear tires is probably the cheapest way to get a taller gear, most first gen Novas will fit up to about 26 1/4" diameter with out modification. A taller rear end gear (lower numerical ratio) if you can't get what you want from just tires.
I would expect to see freeway mileage in the high teens with your 6 in a stock aplication. You might want to try tuning the advance timing and carbeurator first to see if you can't get some better mileage first though.
Old 21st-September-2010, 10:14 AM   #8
wcjames01
(OP)
wcjames01's Avatar
Swap
I generally have to fill up about every 3 days after driving about42 miles per day. I am currently running 195/65/15 on the rear. I do know that I need to have my carb rejetted. The timming was set accurate by another Nova Guru from this site that lives local.
W.C.James
62' Nova 4dr.
704) 779-3382
Old 21st-September-2010, 10:15 AM   #9
batman09
batman09's Avatar
Nova(s): 1967 LS3 & 1962 LSX wagon
Garage
Is shortening the driveshaft a first gen thing>I did not have to do anything on my second gen driveshaft when I di my swap?thanks bm
1962 Nova wagon-----Lsx/4L60e
1967 Nova---LS3/4L70e
Old 21st-September-2010, 10:16 AM   #10
novaconv63
novaconv63's Avatar
Nova(s): 63 Convertible 64 Wagon
200r
I think that with the 200r you can use your original driveshaft, at least you can with a V8. You will need a new trans crossmember and a 200r dipstick, transcooler, TV Cable and linkage and most likely some sort of TV lockup switch. If you are trying to do this yourself, I suggest reading up on it. A good place to start is bowtie overdrives.
Old 21st-September-2010, 10:27 AM   #11
Burke
My bad on driveshaft length, it looks like the powerglide and 200r4 are close enough in length.
Old 21st-September-2010, 11:00 AM   #12
wcjames01
(OP)
wcjames01's Avatar
Swap
But I will still have to do all of the other stuff though? Why wouldn't it just hook and go? I just need a highway gear so I don't put so much strain on my little motor.
Thanks,
W.C.James
62' Nova 4dr.
704) 779-3382
Old 21st-September-2010, 12:00 PM   #13
ChevyBelly
ChevyBelly's Avatar
Nova(s): 1978
if you do your homework you should do ok. I would start at montecarloss.com. those cars came factory with 200-4r. if the p glide is close in length to the th 350, then your driveshaf will be ok. before you buy a crossmember I would see if yours would fit. ive heard of guys removing the tab where the mount bolts to and rewelding it. All I did was spin mine around and move it back. the subframe already had a few sets of holes and I only had to drill 2 new holes for everything to fit. After that, you will need TV cable, dipstick, geometry corrector bracket, overdrive tv cable bracket, trans cooler ( a must) and cooler lines.
I think most 200-4rs are lock up converters so its like it has 5 gears....4th is OD and you can activate the torque converter to lock up which drops the rpms another 500. You do not NEED the lock up function, the nit will shift fine through 1-4 and rpms will be really low.
You might be better off uprading to a th 350. They are a dime a dozen and are less headaches, stronger and cheaper.
drop the pan on any used tranny you buy. inspect the amount of debris present and the color of the fluid. also the smell of the fluid. if it smells burnt, dark red or tons of debris, run as fast as you can. a tranny swap is a lot of work to gamble on a used unit.
my monte carlo ss 200-4R swap
Old 21st-September-2010, 12:37 PM   #14
Rotorbolt
Nova(s): 1964 Chevy II 400 4dr sed
glad to see you got the engine up and running fine. More than likely you have a 3:08 gear. A 2004r might not be compatable with this gear ratio. I would suggest finding out for sure what rear gear you have. Do you have a tach installed? What rpms are you running on the highway?
I've got a TH350 in mine right now, which was way eaisier and inexpensive to swap over too..However, I do find myself also wanting to change over to a 2004r whenever I'm buzzing down the highway.
But you will have to get the crossmember or make your own if you do change over. The stock driveshaft will work fine and you don't need to shorten it. You would if you were installing a 700r4 transmission.
The most important part of the swap is the tv cabel and its adustment.
Old 21st-September-2010, 04:00 PM   #15
rhorne12
Nova(s): 1962 Nova
You need to check if the trans came from a 2.8 or a 4.3 engine Camaro. The 4.3 is 6 cylinders of a 350 but the 2.8 has a different bell pattern and will not bolt to your engine.
I have seen people do this on the cheap and carefully adjust your current shifter to properly operate park, reverse, neutral, and drive. You can do this but you cannot get the lower gears manually.
The TV cable should come with the trans and most junk yards around here will give you the dipstick tube with the trans.
The drive shaft will work as is.
The cooler is very important but you can get one locally for cheap. It doesn't have to be very big.
All you need for the lock up converter is a toggle switch and a wiring diagram and connector as the trans connector is special. Pull-a-part is a good source for that.
Whatever rear gear you have, the engine rpm with the converter locked will be reduced to 67%(I think) of the rpm it now turns at any given speed.
You also need to fix your problem with your current set up as you should be getting much more than 12mpg!!!
TH350 to 200 4R swap questions Pro-touring72 Best of Drivetrain & Performance 32 10th-March-2011 12:43 PM
looking to swap my th350 for a 200-4r askgene Drivetrain & Performance 7 27th-August-2009 09:28 PM
200-4r BareProductions Drivetrain & Performance 4 15th-January-2009 08:51 PM
$200 '62 in SF Scott210 Ebay, etc. Discussion 3 5th-June-2008 01:13 PM
200-4r 77black Drivetrain & Performance 1 11th-November-2007 08:34 PM
