First gen. mini tubbed to rails. Rear end width? - Chevy Nova Forum
Old 15th-September-2010, 06:54 AM   #1
acd65post
(OP)
acd65post's Avatar
Nova(s): 65 Two Door Post
Question First gen. mini tubbed to rails. Rear end width?
Hey guys,
I have mini tubbed my 65 two door post to the frame rails (the 2" mini tub) and I am wondering what the best rear end width would be. I do not want a rim with a large backspacing as I would be limited on rim selection and would have a shallow rim lip. I have a Ford nine inch. What is your overall width wheel mounting surface to whel mounting surface. The rear has drums now but I am also thinking of going with disc brakes.
The front spring perches are moved in 1.5" (Thanks to 62Civa's very nice perch design), I will be using the Church Boys rear springs and 1.5" offset shackles.
I know I willbe able to run an 8"wheel but what about a nine inch?
Thanks in advance.
Old 15th-September-2010, 03:03 PM   #2
Tuckin20s
Tuckin20s's Avatar
Nova(s): White 63 SS Ls1-4l60
Garage
I've got my 63 minitubed to the frame rail.My rear is an S10 that is 54.25 in. wide and I have a 10 in. wide wheel on it that clears.
IN GOD WE TRUST
Mike
COOL AIN"T NEVER CHEAP OR EASY
Old 15th-September-2010, 07:53 PM   #3
acd65post
(OP)
acd65post's Avatar
Thanks Tuckin20's. Your avatar drives me nuts
Anyone else?
Old 16th-September-2010, 02:38 AM   #4
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
The only way to know what will fit is to measure your wheelhouse. Build a simple tool or buy a WheelRite from Jeg's or Summit etc. It will simulate pretty much any wheel/tire combination for width, section width, backspacing etc.
I've bought wheels & tires that I wanted and put them up in the wheelwells at ride height, then measured mounting surface to mounting surface to get the overall rear end width and had the rearend narrowed to get what I needed. You can get wheels built to pretty much any reasonable backspacing if you go with a quality wheel. You have to usually call the manufacturer and tell them what you need. Distributors sometimes don't want to deal with anything that isn't off their shelves and tell you they can't get them.
Be aware also that each vendor's tires are usually not the exact size as another vendor's tires even though they have the same size stamped on them. You will need to look at the spec sheets to get the actualy physical sizes for section width, diameter, recommended rim widths etc.
This is a good reads on how to measure.
http://www.carcraft.com/techarticles...ent/index.html
http://tunertools.com/articles/Wheel-Fitment.asp
33 Ford 3 Window 468ci BBC
68 Camaro ProMod 848ci Buck Racing Engines Nitrous
Old 16th-September-2010, 12:40 PM   #5
Professor Fate
Professor Fate's Avatar
Title: Moderator
Nova(s): Between Novas now
Use Mike's advise to figure out which tires will fit your car first, buy the rims you want, place the tire wheel combination in the wheelwells where you want them to sit and measure the distance between the mounting surfaces. Instant rear end width.
Posted with two Dixie cups and a string.
Old 16th-September-2010, 05:38 PM   #6
acd65post
(OP)
acd65post's Avatar
Thanks guys,
I def. only want to do this once
Old 16th-September-2010, 05:55 PM   #7
Sales-TCI-Eng
Sales-TCI-Eng's Avatar
Title: Supporting Vendor
I'll throw this out there as well. If you go any narrower than 53" a/f to a/f you will start running into brake caliper clearance issues on the rail.
We typically run a 53" wide axle because 10" wide wheels with 5" backspacing fit and are a dime a dozen.
-J
Old 18th-September-2010, 08:43 PM   #8
acd65post
(OP)
acd65post's Avatar
^^^This is good to know. Right now I am looking at going with narrowing the rear an inch per side,maybe 1.25 per side.
I could probably go with the width I have now but I think I will be quite limited to wheel selection as I probably would be looking at a 5"back space. I also do not want a shallow lip on what ever rim I decide to run.
Old 18th-September-2010, 09:04 PM   #9
65 Post
65 Post's Avatar
Nova(s): 65 Post
I did a 2" mini tub on my 65. Except we didn't use the stock stamped sheet metal rails. We cut them out and installed a set of C/E rear frame rails and crossmember. We used the mono leafs with Cal Traks, and a 9" rear. We also moved it back 1" for tire fitment. I have a MT 296/65-15 tire on a Weld 15x8, 4 1/2 back spaced wheel in the well and can slide my hand between the body and tire. I got the rear from Moser and could tell you the exact width, but every car is different. That tire is 29.8 tall and fits. You'll also need to remount the top of your shocks because the geometry won't be correct, and they'll be hard to get in the original location. Dave
"Are you the hunter, or the prey?"
65 Post 11.59 @ 115mph
2002 GORDY 150" RED, 7.91@ 167
Old 18th-September-2010, 09:36 PM   #10
acd65post
(OP)
acd65post's Avatar
^^ more food for thought, thanks.
I will be using the Church Boys springs they are in the mail
I have thought about the shock angle- some.
Did you install the new frame rails in the original spot ?
Something tells me I have seen(admired) your 65 before.
Old 19th-September-2010, 07:31 AM   #11
65 Post
65 Post's Avatar
Nova(s): 65 Post
I think I may have sent you pics before. I finally have it all finished except for paint and the better engine. But the car is driveable and functioning well. After we moved the springs inboard, I saw that the shocks were going to be a problem going into the original holes on the top. I was going to make a flat plate to bolt in with a hole in it to kind of correct the problem. But instead we put a couple brackets on the cross tube and did it that way. Here's a pic.
This is a pic from another member on how he mounted his.
The rails are in, or within an inch of the original location. We mounted the crossmember an inch rearward from stock for tire fitment. Glass beaded and boxed in the original perches and welded them to the crossmember. It's nice to have something square for a good locator.
Hope this helps. Dave
Rear Seat Bottom 1st Gen Mini-Tub Nik_95cobra Body and Interior 2 5th-October-2009 11:15 PM
'72 Mini tubbed rear end width? racer67x Steering, Suspension, and Chassis 2 9th-May-2008 05:58 PM
Help with rear end width in 67 Mini Tub 67-CII Drag Racing Forum 13 5th-February-2008 04:24 PM
Rear seat ideas for 1st Gen mini tub 63Grocery-Getter Body and Interior 1 8th-January-2007 07:51 PM
Mini Tub Rearend Width Ox65 Drivetrain & Performance 5 15th-April-2006 06:22 AM
