fuel pressure regulator,edelbrock carb? - Chevy Nova Forum
Old 11th-September-2010, 01:04 PM   #1
oreo615
(OP)
Nova(s): 1967 nova
I'm changing from a 43 year old carter AFB to a new edelbrock 600 performer series carb on a mild 350.My question ..has anyone experienced having to use a fuel pressure regulator to make it work properly? I believe my fuel pump is stock ... when I install the new carb, it starts and runs and when putting it in gear {automatic} it stalls right away. the car seems to like the new carb and it brings the motor to life over the old one. When I called edelbrock tech support they tell me I need a regulator...I'm looking for all the advice I can get...THANKS !
Old 11th-September-2010, 01:42 PM   #2
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
i had a Holley 12-327 (6.5-8psi) on my '65, 350 w/Eddy 650cfm, and didn't use one. never had a problem... i also have that same pump on my '64, 377w/750dbl-pmpr Holley, and i need one... but gauge shows 9psi so it'll depend on pressure of pump.
a stock fuel pump is generally in the 6.5psi range.
i'd think you'd be OK
if it dies when putting it in drive/reverse i'd check idle speed (RPM's) and adjust if needed...
the Flyer Special
'64 411 377-Tko600-3:73's
Old 11th-September-2010, 07:51 PM   #3
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Why the step down? A rebuild would have been cheaper and you'd have a better carb.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 11th-September-2010, 09:12 PM   #4
oreo615
(OP)
Nova(s): 1967 nova
I just figured it was time to get rid of the relic..but I might switch the metering rods and the jets from the new one {625 cfm} into the old one to see what happens.
fuel pressure regulator gfercaks33 Drivetrain & Performance 5 13th-August-2010 12:29 AM
fuel pressure regulator jo3y1nf4nt3 Drivetrain & Performance 5 28th-March-2008 06:43 PM
Return fuel pressure regulator? bbcnova Drivetrain & Performance 12 15th-June-2007 12:59 AM
No Fuel Pressure Regulator- Leaky Carb 76NovaSS Drivetrain & Performance 1 22nd-November-2006 10:05 PM
Fuel Pressure Regulator Pick Drag Racing Forum 22 9th-July-2006 10:26 PM
