Best Coil for MSD 6A/6AL box - Chevy Nova Forum
Old 27th-August-2010, 11:12 AM   #1
levisnteeshirt
(OP)
Nova(s): shopping for the 6th one
lemme know what ya think
i had better luck with the old , big yellow Accel coil
Old 27th-August-2010, 11:36 AM   #2
Plowman
Plowman's Avatar
Nova(s): 1967 1969
MSD has a list of campatible coils. I found the big yellow Accel works good,also on MSD7a. But check the list to see what you like.
Old 28th-August-2010, 12:46 AM   #3
nc76novass
nc76novass's Avatar
Nova(s): 76 nova ss
I went to the blaster 3 becasue of hei style connection on coil. was using same blaster 2 for 15 years with no problem
Old 28th-August-2010, 09:47 AM   #4
68ctnovabb
68ctnovabb's Avatar
Nova(s): 1968 SS
I recently went with the blasterSS coil. When I talked to MSD they said the SS has a higher current/temp spark than the other blaster coils, although it is a shorter duration spark. According to my tech the higher temp helps combustion slightly more than the longer duration. I have no way of verifying that but I'm happy with my SS.
Old 28th-August-2010, 02:01 PM   #5
levisnteeshirt
(OP)
i
took off a blaster 2 , and went to the Accel ,, i don't know if the blaster 2 was weak ,, but it was a noticeable difference,, i had to sell the car not much longer after that ,, but it sounded alot better , it would not crank with the ignition on after that ,, had to hit the starter then hit the ignition , it started instantly ,, just had alot stronger attitude ,,
might be a dumb MSD 6al box? 70nova383 Drivetrain & Performance 2 7th-June-2010 11:46 AM
Unilite+MSD 6AL+ProPower Coil???? Baddbob Drivetrain & Performance 3 8th-June-2009 12:11 AM
MSD 6AL Box Installation novavetteguy Electrical 10 21st-January-2007 11:42 AM
MSD-6AL box and ACCELL HEI coil ovrdrive Drivetrain & Performance 3 16th-January-2007 09:24 PM
MSD 6AL box wiring rjy Electrical 7 16th-April-2006 08:29 PM
