V8 alternator wiring - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 9th-August-2010, 02:45 AM   #1
kirk69nova
(OP)
kirk69nova's Avatar
Nova(s): 1969 Nova
Garage
What is the proper way to run the three wires for the alternator in a 69 Nova with a V8. I am currently in the process of swapping in a V8 in favor of an I6. The I6 alternator is on the drivers side and it is on the passengers die on a V8. I do not think the wires will be long enough so I know I'll have to lengthen them but just need to know how they ultimately should route to the alternator.
Kirk
Kirk
Old 9th-August-2010, 11:00 AM   #2
patman
patman's Avatar
Title: Moderator
Depends on the brackets you are using. Since you are installing the V8, I'm assuming that originality isn't important. Given that, there are brackets that will mount the alternator in pretty much any location you want. Pick the bracket setup first, worry about routing the wiring later.
Pat -
Old 9th-August-2010, 11:14 AM   #3
kirk69nova
(OP)
kirk69nova's Avatar
Nova(s): 1969 Nova
Garage
I have the original style bracket that puts it on the passenger side but would rather have it on the drivers side. I also have power steering. Can I put both the alternator and PS pump on the drivers side?
Kirk
Kirk
Old 9th-August-2010, 12:01 PM   #4
patman
patman's Avatar
Title: Moderator
Here's some food for thought...no connection to the company, they just have a boatload of different bracket setups:
http://www.alangrovecomponents.com/
Pat -
alternator wiring southernculture Electrical 7 5th-June-2010 01:43 AM
alternator wiring? rjc1629 4th Generation Nova's 12 1st-August-2009 01:44 AM
Alternator wiring help for 71 BillsNogo Electrical 4 29th-June-2008 03:43 PM
Alternator wiring questions 270win Electrical 27 24th-February-2008 12:30 AM
alternator wiring? novaman30274 Electrical 17 17th-February-2007 01:30 AM
