Coil over spring kit ( Rear shocks ) - Chevy Nova Forum
Old 8th-August-2010, 04:21 PM   #1
Rroxon7
(OP)
Rroxon7's Avatar
Nova(s): 1964 Wagon 400. 1966 1/2
I bought a kit from pep boy's.. Wanted to see if they will help the rear suspension, and keep the car from bottoming out.....1250 Lb's.. Anyone ever use them on a 1st or 2nd gen ??? I'd like to know if they're worth the $30. Look pretty simple to install..
Old 8th-August-2010, 05:03 PM   #2
NOGO
NOGO's Avatar
Garage
They are a band-aid for sagging springs...
Corra su coche, no su boca!
Old 8th-August-2010, 05:10 PM   #3
Rroxon7
(OP)
Rroxon7's Avatar
I just bought my mono Leafs from bm... I'm sure he wouldn't have sold me junk springs...
Old 8th-August-2010, 05:25 PM   #4
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
they're still somewhat of a band-aid. either the car needs new springs due to sagging or it doesn't. if ride height is OK and you just want a stiffer rear suspension then i'd suggest a multi-leaf set up or a more aggressive shock... but stiffer shocks are a band-aid also if you're trying to compensate for a weak, worn out spring...
if the car bottoms out, i'd remove & inspect the shocks... they might be junk
the Flyer Special
'64 411 377-Tko600-3:73's
Old 8th-August-2010, 06:15 PM   #5
Rroxon7
(OP)
Rroxon7's Avatar
I just bought the monroe sensa trac gas shocks.. they're brand new.. I bought the leafs from bm not more than a few months ago.. drove up to his house to pick them up..... This is how the car is sitting now..
Old 8th-August-2010, 06:22 PM   #6
the FLYER
the FLYER's Avatar
stance looks ok to me... if the shocks are bottoming out i can guarantee ya they'll probably be blown out. they should never bottom out or be over extended or they'll break/get damaged.
i lowered my car too much a year or so ago and broke a shock... not a good thing.
check shock travel, check body travel etc to make sure you're not bottoming them out. hitting bump stops is different than bottoming out a shock... either way if you are bottoming something out... something's not right
the Flyer Special
Old 8th-August-2010, 06:51 PM   #7
David&Melissa_h
So why was BM selling the springs? are they original to his car meaning 40 plus years old?
Old 8th-August-2010, 07:03 PM   #8
Rroxon7
(OP)
Rroxon7's Avatar
He bought them from someone else and was intending to use them on the bat mobile... He said he was going to use something else.. Not sure if it was something from cpp or cbr.. can't remember right off hand.. They were still boxed up from whoever sent them to him..
Old 9th-August-2010, 08:55 PM   #9
Rroxon7
(OP)
Rroxon7's Avatar
It's looking more and more that the leaf springs may be bad.. I'm having them inspected tomorrow... The shocks are new here's a vid. they seem to be fine...
Old 9th-August-2010, 08:59 PM   #10
the FLYER
the FLYER's Avatar
looked OK ta me
might lube the bushings a little so there isn't any creaking sounds... or was that yer Ol'Bones makin' all that racket ?
with it as-is... are ya sure yer bottoming out ? 'cause like i said, it all looks OK ta me
the Flyer Special
Old 9th-August-2010, 09:18 PM   #11
Rroxon7
(OP)
Rroxon7's Avatar
looked OK ta me
Sometimes it feels like my bones are creakin... I'm a tub but the wife still thinks I'm sexy, and thats after losing 15 lb's..,, Not sure why all the squeaking.. I lubed it ( I thought pretty good with litheum grease. ) The car bottoms out going over tracks.. or just bad roads with dips.. I always slow down before going over tracks.. I have too.. I'm picking up some springs that were out of a wagon tomorrow.. They're mono leafs, but quit a bit thicker... I'm hoping they do the trick.. It shouldn't bottom out.. regardless.. I keep my trunk empty as much as possible.. but it still bottoms out.. Like I said.. I'm having them looked at tomorrow too...
Old 9th-August-2010, 09:19 PM   #12
Toxic
Toxic's Avatar
Nova(s): 67 Nova, 69 Camaro Conv
looked OK ta me
+1
my Old shop teacher said push down on it once, and if it only rebounds once it's good. if it bounces more then once it's worn.
if it's too soft, try a rear sway bar, they stiffen it up a bit.
Will aka Thread Killer
Old 9th-August-2010, 09:20 PM   #13
the FLYER
the FLYER's Avatar
i'd get it on a rack and inspect it. a bad muffler or exhaust pipe clamp/hangar can cause a clunk. don't let the guy sell you on a set of springs without a thorough inspection of underneath the car.
it looks OK ta me. if it didn't i'd say so...
the Flyer Special
Old 9th-August-2010, 09:27 PM   #14
Rroxon7
(OP)
Rroxon7's Avatar
Gotcha... I'm taking it up to Plumrats... ( Ken Wells )... He's the one with the springs... I'm going to have him look at the leafs that are on the car now as well... I trust Ken with anything that comes up concerning the Nova.. He's always been one of the best IMO...
Old 9th-August-2010, 09:30 PM   #15
the FLYER
the FLYER's Avatar
i've met Ken... i agree. let him take a look-see. he'd never steer ya wrong, top notch kinda guy
tell 'im JohnnyRotten says hello will ya ?
the Flyer Special
63 Nova Rear Coil Spring Boogie! rharveysr Steering, Suspension, and Chassis 12 23rd-May-2010 04:36 PM
Coil Spring Rate for Rear Coil Overs badass70_nova Drag Racing Forum 3 30th-September-2008 12:59 PM
coil over shocks for rear patrick Steering, Suspension, and Chassis 3 3rd-February-2008 07:56 PM
rear end coil over conversion kit youngin69nova Steering, Suspension, and Chassis 18 27th-May-2007 05:55 PM
TCI ture coil over or coil spring WhitecatD Steering, Suspension, and Chassis 6 4th-July-2006 08:55 PM
