4L60E transmission Low1 won't hold my truck back going down hill, why? - Chevy Nova Forum
Old 17th-July-2010, 12:03 PM   #1
bigdaddykane
(OP)
Nova(s): 3rd gen Nova's
Hey guys, this question is actually for my truck, i hope some one can shed some light for me...When i put in Low 1 and gas it, it goes normal. but if i go down hill in Low 1 with out my my foot on the throttle the truck rolls like as if its in neutral without trying to bring the RPM's up and slowing down the truck and i hear some rattling,skipping noise, why? the motor used hold me back in low 1 if i didnt give any gas in the past.... also, i dont know if its because the warmer temperature outside but after driving for 20-30 minutes i hear some noise from under the truck recently and it increases and decreases with RPM....and if i turn the truck off and restart it after 30 seconds and doesnt do the noise until after 5 minutes of using it. anyone got any ideas on whats going on? my truck is a 4.3 automatic 4x4 with 62k miles on it.......
Old 17th-July-2010, 02:43 PM   #2
mdw66nova
mdw66nova's Avatar
Nova(s): 66 2dr HT 327 Powerglide
Your transmission has a lockup converter. It disengages when you put on the brake. It sounds like it is now disengaging when you go downhill. The noise I have no idea but it may be related. Is the transmission stock or custom?
It's only money!
Old 17th-July-2010, 03:17 PM   #3
bigdaddykane
(OP)
its all stock...im familiar with the lock up but thats not what im checking because the lock up works great. so lets say your at a top of a hill and you pull the gear lever all the way down until it bottoms and its now in 1st gear. the selector in the dash reads low1, not drive or overdrive but rather 1 . so now i let off the brake and i start rolling down this steep hill and im not giving any gas at all. the engine should hold me back and the RPM's should be going up as my speed increases. but the rpm's are not...the rpm's are staying at idle and the truck rolls free like as if its in neutral. why?
Old 17th-July-2010, 04:28 PM   #4
Ryan V64SS
Ryan V64SS's Avatar
Nova(s): 64 SS, 63 Sedan
Might be a low gear sprag, or a band/ clutch is not applying. Sounds like it will need to be pulled.
Old 20th-July-2010, 12:39 PM   #5
bigdaddykane
(OP)
do you think it could be slightly lower line pressure from a clogged tranny filter maybe? where can i get a line pressure gauge?
4L60E in a '67 67CheeseWgn Drivetrain & Performance 6 22nd-August-2007 05:21 PM
"The Hill" opens back up tonight Gota66 Drag Racing Forum 0 3rd-April-2007 04:40 PM
Couldn't hold first transmission update. MuscleDreams Drivetrain & Performance 0 25th-February-2007 07:49 PM
