Spark Plug Wire Routing Under the Headers? - Chevy Nova Forum
Old 13th-June-2010, 07:04 PM   #1
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Who here routes their spark plug wires under their headers on their sbc's? Any one have any photos of your setup? What are you using for wire seperators? I just finished doing most of my engine compartment wiring (all most all of it hiden) and I would like to route the plug wires behind the valve covers and under the headers rather than just across the tops of the valve covers. Any ideas would be appreciated!
thanks
Ron
My 62:
Old 13th-June-2010, 07:24 PM   #2
wreckrunner
wreckrunner's Avatar
Title: Nova Newbie
Nova(s): 1 67s 1 71
i ran mine under the headers used separators heres a pic
Old 13th-June-2010, 07:27 PM   #3
David&Melissa_h
You should of checked out mine yesterday Ron I ran them under my headers.
Old 13th-June-2010, 07:31 PM   #4
David&Melissa_h
I have 90* boots pointed down. ran the wires tucked to the block and used a Large metal wire tie bolted to the block on both sides. was real easy and looks clean...
Old 13th-June-2010, 08:53 PM   #5
1qwikss
1qwikss's Avatar
Nova(s): 1969 Nova SS
hard to see in pictures but i ran mine down under the headers also.
it's a little bit more work but a lot cleaner.
R.C.,CA
1969 Nova SS, 355 ,2004-R,12 bolt posi
Old 13th-June-2010, 09:20 PM   #6
Simms
Simms's Avatar
Title: Nova Newbie
Nova(s): 1968 Chevy II Coupe
Doesnt running the wires under the headers heat up the wires and melt them? What are the wires heat resistance rating at? I would assume doing that you run the risk of them pressing against the headers?? ( I have never tried it, so I dont know, im asking )
Old 13th-June-2010, 09:54 PM   #7
bowtie0069
bowtie0069's Avatar
Nova(s): 69
The way I had mine kept them far away from any tubes--they dropped straight down and looped back behind the engine, away from most exhaust heat. Some headers make it very difficult to run the wires down--on one set, I could only do it to one side.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 13th-June-2010, 09:58 PM   #8
mdw66nova
mdw66nova's Avatar
Nova(s): 66 2dr HT 327 Powerglide
A couple of tricks to do this and not burn wires. Buy a roll of wire protective sleeve. I use DEI. For the tough wires that never stay were you want them, I used lashing wire. (Wire used to wrap telephone lines from pole to pole) Tape the wire to you spark plug wires with electrical or wire loom tape and then cover with protective sleeve. This way the wire stays in what ever configuration you put them in. I am sure there are many others ways but this one looks good and you don't have to use a bunch of ties etc. to hold them off the headers. I have also modified a set of wire holders (The ones that bolt on with the valve cover) and bolted them to the block were the original shield bolted on under the headers.
It's only money!
Old 13th-June-2010, 10:46 PM   #9
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
Not headers,
this is Innovative63's 65 I did.
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 13th-June-2010, 10:49 PM   #10
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
just make sure you can remove the distributor cap after all wires are loomed. be a PITA if the wires all need to be removed from cap to get cap off...
the Flyer Special
'64 411 377-Tko600-3:73's
Old 14th-June-2010, 12:04 AM   #11
383NOVASS
383NOVASS's Avatar
Nova(s): '70 Nova SS
i didn't route mine under the headers, but i did use a separator that organizes them and put them along the valve cover and it looks fairly clean. i know the picture doesnt show both sides, but you can use your imagination.
Old 14th-June-2010, 09:41 AM   #12
Fast Eddie
Fast Eddie's Avatar
Nova(s): 1966 Nova
Had them running under the headers from the beginning and had no problems. Used separators to keep it organized.
Attachment 19646
Fast Eddie
1966 Nova
408 cu in SBC
Aqua
Old 14th-June-2010, 02:40 PM   #13
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Thanks everyone for the ideas. Big AL, thanks for including that last photo. I never would have thought of using the motor mount to keep the wires in place. I have to make a trip to my local auto parts store and see what they have for seprator clips. I think I am about a month away from firing the engine
Ron
My 62:
Old 14th-June-2010, 04:12 PM   #14
1qwikss
1qwikss's Avatar
yes, i went down through the motor mount also.
R.C.,CA
Old 14th-June-2010, 04:19 PM   #15
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Hey Jim,
Hope you are doing well. Thanks again for the those crimp tools. I use one of them every week at work
Ron
My 62:
Plug wire routing hawk7745 Show and Shine 4 22nd-November-2009 03:26 PM
Spark Plug Wire Suggestions greasemonkeychef Electrical 7 9th-April-2009 10:32 PM
Spark plug wire routing ideas? batman09 Drivetrain & Performance 22 15th-January-2009 12:35 AM
Plug Wire Routing klean63 Drivetrain & Performance 5 6th-January-2008 12:58 PM
Spark plug wire question. Borrelli's65SS Drivetrain & Performance 11 14th-September-2007 10:26 PM
