Changing Speedometer Cable - Chevy Nova Forum
Old 3rd-June-2010, 12:34 PM   #1
OnceOwned_L78
(OP)
OnceOwned_L78's Avatar
Nova(s): 1971 Nova SS, http://www.Nova-ss.com
Question Changing Speedometer Cable
I need to change the speedometer cable on my '71 Nova.
Can the cable end at the back of the speedometer be accessed without taking the dash apart and insturment/gauge panel out...? Does it screw on or is there a clip for it....?
Also....found something interesting about the big block 3rd gen cars:
....Most people do not realize that on performance manual transmission cars, the speedometer cable was routed higher up on the firewall by the distributor, and ran down the firewall, usually held by three clips, away from the clutch Z-bar. ....1968 1969 1970 1971 1972 Nova 4-speed models....
Thanks..!
Old 3rd-June-2010, 01:00 PM   #2
OldGuy 71Acadian
OldGuy 71Acadian's Avatar
Nova(s): 1971 Acadian 1972 Vega
Sure, just go upside down, reach up, stick your tongue out to the left, use a few cuss words, push down on the clip and pull out the cable. Install in reverse order. Chiropractic consultation may be required depending on your age.
Joe
1971 Acadian
1972 Vega
Old Guy Fraternity
Old 3rd-June-2010, 01:35 PM   #3
Dutch
Dutch's Avatar
Nova(s): 71 SS/74 Custom/74 Hatch
Thats about right.
I would suggest you pull the old one first and then go to the parts store and compare lengths, I had to exchange mine because the first one was 8" too long.
"Street Legal, who's really looking?"
Old 3rd-June-2010, 01:43 PM   #4
OnceOwned_L78
(OP)
Exclamation
....Sure, just go upside down, reach up, stick your tongue out to the left, use a few cuss words, push down on the clip and pull out the cable. Install in reverse order. Chiropractic consultation may be required depending on your age.
^&%#$<...you sure the heck got that right....I just tried to take a look from the underneath side....for me, at 6"4" and 63 yrs.....there is just NOT enough room. Got down there, glasses fell off, back got a cramp, and I felt lucky to be able to get out and back on my two feet again!
I need a short, young mechanic... I thinks.
Old 3rd-June-2010, 02:01 PM   #5
zman1969
zman1969's Avatar
Nova(s): 1969 Nova SS 1966 SSold!
easy job
yeah its easy if your young. also included in the name technician is contortionist - its not much fun.
One question about length is how long is a muncie speedo cable? mine was cut clean off at the firewall+4" mine is an original 4 speed muncie car 1969
thanks for any info.
69 Firebird clonification LS6/6spd
69 R/S Z28 302 4 spd 4.10 Daytona
69 Nova SS
99 Trans Am Firehawk
Old 3rd-June-2010, 07:07 PM   #6
OnceOwned_L78
(OP)
Don't know about originality, but the cable I am needing to replace was connected to a Muncie M-21 before I replaced the M-21 transmission with a 700R4 last month. It fit the 4-speed just fine as well as the 700R4. I can measure it when removed, but you likely will have replies by others before that gets done.
Old 3rd-June-2010, 08:11 PM   #7
BLYOTH
BLYOTH's Avatar
Nova(s): 1968
It is not really that hard if you don't have a radio installed. I changed mine out last week but I have the fancy radio delete. I doubt I could have got my hand up there if the radio was installed.
Old 4th-June-2010, 04:39 PM   #8
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
Your Quote is correct about BB cars, both my cars are this way.
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
speedometer cable? orange70 Drivetrain & Performance 1 27th-March-2010 10:32 PM
speedometer cable? fossilrunner 3rd Generation Chevy II/Nova's 7 16th-August-2009 01:31 AM
Speedometer cable. NovaFan63 Drivetrain & Performance 1 15th-June-2009 05:13 PM
Speedometer Cable Help!! 66novass South Western US 3 14th-February-2007 07:51 PM
