Crankcase Evacuation Kits - Chevy Nova Forum
Old 24th-May-2010, 05:32 AM   #1
lktna
lktna's Avatar
Nova(s): 1971 Nova SS- sold 62 Ch
I have never used one before but I am thinking about giving it a try. I just got my Nova back together and it is smoking kind of bad and I had a friend tell me that that would take care of it. It is a solid roller 360 ci sb with 12.5:1 compression, Dart Iron Eagle 230s and all forged bottom end. It runs strong as hell but just smokes. Has anyone used one and it got rid of the smoke or is it a waste of money?
Old 24th-May-2010, 01:25 PM   #2
mdw66nova
mdw66nova's Avatar
Nova(s): 66 2dr HT 327 Powerglide
I use one on my street car. No ports in the rocker covers. I have an early 327 with vent in the rear & vent/oil cap in the front. Installed the bung and valve just before the collector on the passenger side header. Welded a hose fitting to the stock vent tube assembly. Ran a hose between the two. Worked too well at first. It pulled oil up through the vent. I installed a restrictor and works well now.
It's only money!
http://i911.photobucket.com/albums/a...wWheels010.jpg
Old 24th-May-2010, 01:38 PM   #3
Paul Wright
Paul Wright's Avatar
Title: Moderator
If your engine is smoking because of excessive blowby, crankcase evacuation won't fix the root problem. Do a leak down test to determine if you have poor sealing rings.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 24th-May-2010, 05:39 PM   #4
lktna
lktna's Avatar
There isn't any blow by. When I pull the pcv valve there is no smoke what so ever. I was thinking with it being a decent size solid roller and not much vacuum that it was causing oil to be sucked into the intake.
Old 24th-May-2010, 06:02 PM   #5
D-Man
D-Man's Avatar
If that's the case, then your valve cover either doesn't have a baffle or the one it DOES have is ineffective.
If you really are sucking oil into your engine from the PCV valve, then the E-Vac system is going to do the same thing and suck the oil right into the header collector.
"Never trust a government that doesn't trust its own citizens with guns."
--Thomas Jefferson
Old 24th-May-2010, 07:10 PM   #6
lktna
lktna's Avatar
I don't have baffles in the covers. I was just wanting to know if it would help. Wasn't really looking for a smartass answer. If I wanted that then I would have as a jackass the question not fellow Nova people!!!!!
Old 24th-May-2010, 07:26 PM   #7
Paul Wright
Title: Moderator
That's not a "smart ***" answer at all. He has a very valid point. From your description the pan evac won't help you.
Old 24th-May-2010, 07:29 PM   #8
lktna
lktna's Avatar
That is the kind of answer I was looking for. Thank you.
Old 24th-May-2010, 07:33 PM   #9
The Big Al
The Big Al's Avatar
Title: Supporting Vendor
Nova(s): 68ss,70ss
How do you have the engine ventilated now?
Vent?
PCV?
Nothing?
Al
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 24th-May-2010, 07:54 PM   #10
lktna
lktna's Avatar
Pcv valve.
Old 24th-May-2010, 11:16 PM   #11
The Big Al
The Big Al's Avatar
Nova(s): 68ss,70ss
Pcv valve.
Breathers?
Or just a single PCV?
The engine must be vented.
Old 25th-May-2010, 04:05 AM   #12
lktna
lktna's Avatar
Just a single pcv and a breather. Right side pcv and left breather.
Old 25th-May-2010, 12:25 PM   #13
bbcnova
bbcnova's Avatar
Nova(s): 1974 custom 496, 1972 pro
If there are no baffles in the valve cover then it is most likely sucking the oil in through the PCV and that is causing it to smoke would be my guess.
Old 25th-May-2010, 01:03 PM   #14
theracer
theracer's Avatar
Nova(s): 64ht Pro Street 383,700r
i run my pvc through a oil/ air seperator.
THE RACER
Old 25th-May-2010, 01:42 PM   #15
D-Man
D-Man's Avatar
Not trying to be a smartazz, just giving a straight forward, no B.S. answer.
Sorry if I didn't sugar coat it enough to your liking.
You either need a baffle or an effective oil separator to keep EITHER system from sucking the oil mist out of your valve cover.
--Thomas Jefferson
Crankcase evacuation system 74novaKid Drag Racing Forum 8 21st-December-2009 12:55 AM
Crankcase Evacuation Proof! Big Al, your the man! slickman Drivetrain & Performance 2 15th-November-2009 11:07 AM
pcv and crankcase evacuation 71SS454 Drivetrain & Performance 10 2nd-April-2009 01:40 PM
Something so simple can make you feel so stupid--evacuation system related Tubbed63 Drivetrain & Performance 3 21st-October-2008 03:39 PM
crankcase evacuation 502nova Drivetrain & Performance 10 11th-July-2006 10:00 AM
