th350 front pump - Chevy Nova Forum
Old 8th-May-2010, 12:36 PM   #1
blugras
(OP)
Title: Nova Newbie
Nova(s): 1964 Chevy 2 4door
th350 front pump
I think I screwed my front pump up on install. The converter wasn't fully seated when we tried to bolt it up. My buddy said he heard a pop. We dropped it back down but it didn't look like there was any damage so we went ahead and finished the install.
Well today I filled it with fluid, backed out, and drove around the block. The tranny didn't feel right to me. When I pulled back in the driveway I saw this
I had a small leak at the radiator where the line wasn't tight enough but it wasn't that bad. My stepdad thinks it could be the converter but I'm afraid its the pump.
I have a spare th350 but it has a buick bolt pattern. Is the front pump interchangeable? How difficult would it be for a first timer? I'm pretty mechanical inclined although sometimes I do have my head in my ***, which is how i got to this point.
Old 8th-May-2010, 12:53 PM   #2
badaznova70
Nova(s): 1970 nova ss clone
Im pretty positive that the only differance between your 2 trannys IS the bolt pattern Im about 99.99999% sure that the internals are the same
Old 8th-May-2010, 03:54 PM   #3
blugras
(OP)
Title: Nova Newbie
Thanks for the reply man. Turns out I didn't put the kickdown cable back in and fluid was coming out the hole. Live and learn. Thank God the pump isn't screwed up.
Old 8th-May-2010, 05:31 PM   #4
badaznova70
Good deal hey somedays your the dog,somedays your the hydrantGuess today your the dog
Old 8th-May-2010, 05:52 PM   #5
george 66
george 66's Avatar
Did you check to see what kind of fluid was on the ground? Hard tell by a photo, but that doenst look like atf to me. get a little of it on your fingers and smell it. Wait, before you do that, do you have a dog?
ChevyII, old-style block, to modern block Front Sump oil pump pickup modifications jjj5757 Best of the 1st & 2nd Generation 11 18th-January-2015 12:37 PM
383 rod hits front sump oil pump, please help quigman Drivetrain & Performance 14 20th-August-2009 11:33 PM
Converting th350 to powerglide? Blew up my th350 gr8ride_71 Drag Racing Forum 9 14th-October-2008 09:39 PM
Dumb question about the front sump pump drive shaft John65ss Drivetrain & Performance 2 30th-September-2008 10:34 AM
Front sump oil pump laser-red-nova Drivetrain & Performance 5 25th-November-2006 09:09 PM
