1965 front end alignment specs question - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 20th-April-2010, 01:21 AM   #1
Carl Stevenson
Carl Stevenson's Avatar
I have spent about an hour searching this site for something I'm sure I've seen here... I want to get an alignment done on my 65 since I have removed the 427/TH350 and installed a 327 and a Muncie. It clearly sits higher and the camber is visibly off. It drove perfect with the 427 and I'd sure love to duplicate that steering now.
I went to the shop today where I plan to take it. He printed off his suggested specs.
Caster 1.0 degrees +- .5 degree
camber .50 degrees +- .5 degree
Toe in .63 degree +- .12 degree
How does this look?
Yes, I am aware of the CBR kit and want to do it at a later time......!
Carl (in the prairies...)
65 Canso Sport Deluxe (Sold)
67 SS 327 (Sold)
Old 23rd-April-2010, 09:21 AM   #2
67 church
67 church's Avatar
Title: Supporting Vendor
Nova(s): 67 2dr hrd top, 2-63 wags
How does this look?
For your caster I would try to get at least +1 degree and on the camber my opinion would be no more than +.25 degrees. Your toe may be a little much as well. Or you can use his specs, drive the car and note how it drives and if it wears the tires prematurely.
Chuck Church
330-442-7162
Made in the USA
Old 23rd-April-2010, 05:53 PM   #3
NOGO
NOGO's Avatar
Garage
Here is what I recommend:
1.5 deg caster
0 deg camber
.2 deg total toe in
Old 24th-April-2010, 02:06 AM   #4
Carl Stevenson
Thanks very much guys.
Hope to get it to the shop in the next couple of weeks.
67 SS 327 (Sold)
Old 6th-August-2010, 03:19 AM   #5
grooves12
Getting ready to do an alignment on my '64... also looking for advice on specs for front end.
What are the factory recommended specs, and why would we want to go a different route? What advantages are there?
Old 6th-August-2010, 05:30 PM   #6
arndog
Ive seen different specs for nylon or bias ply tires then radials, factory specs all that was available was bias ply.
arndo
Old 7th-August-2010, 01:01 PM   #7
benslick
benslick's Avatar
Nova(s): 1967 SS V8 NOVA Calif car
Here's what I use on a factory Front end,
Alignment Spec’s;
Drivers side Passenger side
Camber ˝* neg ˝* neg
Caster 1 ˝* pos 2 * pos
Toe 1/16” in 1/16” in
Old 7th-August-2010, 10:13 PM   #8
6T6NOVA
6T6NOVA's Avatar
Nova(s): 66 Nova SS
I have a stock front end. I added the 3rd Gen Nova disc brakes to the front. So the track width is wider by 3/4 of inch on each side. I am running a 15 x 6 inch steel wheel with 4 inch back spacing on the front.
Question for NOGO would the specs you recommended still be good?
Bryan
Old 7th-August-2010, 10:21 PM   #9
NOGO
NOGO's Avatar
Garage
Bryan
Yes the same specs will work. You can bump up the caster a bit if there is enough room between your tire and fender. You can also add add .2 deg or so of caster on the right if you need to compensate for road crown.
Corra su coche, no su boca!
Old 9th-August-2010, 04:09 AM   #10
6T6NOVA
6T6NOVA's Avatar
Nova(s): 66 Nova SS
NOGO
Thank you.
Bryan
Old 6th-February-2012, 01:37 AM   #11
Carl Stevenson
How does this look?
Just to bump this up.
I never did go for an alignment as I didn't finish other stuff on the car last year. Now I installed the CBR lower control arm kit a couple of weeks ago and hope to take it in soon to get aligned.
I was not detailed enough in my initial question here last year, so here goes.
Stock street driven car, stock chassis except the CBR kit, radial tires in stock size.
Still go with the specs suggested above?
67 SS 327 (Sold)
Old 31st-May-2012, 10:58 PM   #12
Carl Stevenson
This car has been on the back burner and now finally is in the shop to get aligned tomorrow morning.
Somewhere I've seen the specs for a first gen with a CBR lower arm kit only. Can anyone help with that? I am not having much luck so far.
67 SS 327 (Sold)
Old 1st-June-2012, 09:48 AM   #13
65novaken
65novaken's Avatar
Nova(s): 65 ss
i saw this on the site the other day carl.
no link tho as i printed it off.
0 camber
1/4 to 3/8 toe in,closer to 1/4 if possible
2-3 degree positive caster-closer to 3 degree for hwy driving
this was sugested for the CBR kit.
my build
Old 1st-June-2012, 10:54 AM   #14
Plowman
Plowman's Avatar
Nova(s): 1967 1969
Alignment Spec’s;
This is out of Factory Alignment specifications.
Front End Alignment Question tider66 Steering, Suspension, and Chassis 14 26th-February-2010 05:12 PM
1965 alignment specs? (cpp subframe kit) yzair Steering, Suspension, and Chassis 1 21st-January-2010 10:43 PM
Front end alignment specs. 65 Post Drag Racing Forum 4 12th-July-2009 07:57 PM
Front End Alignment Specs CHEVY2MAN Originality 2 8th-October-2007 08:48 PM
66 front end alignment specs needed BAD T. Jerman Steering, Suspension, and Chassis 5 31st-July-2006 10:43 AM
