750 street hp - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 2nd-April-2010, 10:26 PM   #1
Manford
(OP)
750 street hp
had anybody had any luck with one of these?.finally going to break down and buy something new i think
Old 2nd-April-2010, 10:32 PM   #2
3DTim
3DTim's Avatar
Nova(s): 66 ProStreet 82 SWB C-10
One of WHAT ?????
PROSTREET FRATERNITY
Old 2nd-April-2010, 10:38 PM   #3
Manford
(OP)
a holley 750 street hp carb, my thread title isnt very good lol
Old 2nd-April-2010, 11:26 PM   #4
Ryan V64SS
Ryan V64SS's Avatar
Nova(s): 64 SS, 63 Sedan
If you have a large duration cam, with lots of overlap, i'm talking well over 230 @ .050 then you might need something not "off the shelf". That being said I have heard good things about the HP's. They don't run nearly as rich as the Demon's
Old 2nd-April-2010, 11:46 PM   #5
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Do you have the vac. sec. or mechanical? We ran the V.S. version on Dale's Dart with the 383 and my 410 and it worked great on both--I really liked the carb.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 3rd-April-2010, 01:06 AM   #6
SMLBLK66
SMLBLK66's Avatar
Nova(s): 62 2DR HARD TOP AND A 66
those carbs work great. depending on your motor, if it aint to big...i dont see you having a problem with one.
Old 3rd-April-2010, 01:10 AM   #7
SMLBLK66
SMLBLK66's Avatar
not trying to hijack or be a D-bag...but is that what a carb company has told you??? I have ran cams in the 280+ @ .050 with off the shelf cabs with no problems. Not sure why an "off the shelf" carb wouldnt work.
Old 3rd-April-2010, 09:44 AM   #8
Manford
(OP)
im going to get a double pumper, i have an old 750 double pumper that is just worn out.the idle is erratic, it leaks from the throttle shafts and now the car doesnt even want to run with it on there.the car runs fine with my vaccum carb but i dont like the way it runs with that on it.im going to try to fix my double pumper one last time, if that doesnt work im buying a new one.my carb i have now is 20 years old or so.
Old 3rd-April-2010, 11:06 AM   #9
Ryan V64SS
Ryan V64SS's Avatar
I said "might" as in it might work on might not. I also said I have heard good things about the HP's. Demons on the other hand are a pain to tune for part throttle. Sure it runs fine but the afr's on my car are in the 11/1 range while the wot are fine 13/1, and no matter what I do I cant get it to change. Dont know if the HP's have the same issues but I have heard good things about them, more tuneability. Seems that the bigger cammed motors need a different booster to meter fuel properly. Have you ever checked you air fuel ratios at cruise, is your car even a street car?
Old 3rd-April-2010, 01:44 PM   #10
chevguy65
chevguy65's Avatar
I ran a 750 street hp and really liked it.
As said it came out of the box and onto the intake and fired up and ran well.
I eventually tweaked the idle screws but just barely.
I have also ran the mighty demon 750 and did not like it, it was a good street carb but not for the strip imo.
I kept jetting it up but no difference on the top end it was a dog and laid over.
The Holley 4779 imo is the best 750dp out there aside from the exotics.
Old 3rd-April-2010, 06:13 PM   #11
testcase
testcase's Avatar
Nova(s): 66 Drag car
I agree, the 4779 is a fine all around carb for a lot of applications. I have always had better luck with the DP's rather than the Vacuum models. But then again, I am a dinsaur
Tod
Old 3rd-April-2010, 09:37 PM   #12
Manford
(OP)
this will probably be the only new carb i ever buy so i have to make it a good one
Old 5th-April-2010, 01:50 PM   #13
levisnteeshirt
Nova(s): shopping for the 6th one
saw a
street HP 750dp ,,, get replaced with a quick fuel 850 ,, didn't pick up or slow down any ,, 575 hp 355
Old 5th-April-2010, 01:52 PM   #14
levisnteeshirt
eh
put a new base plate on that carb , trick kit ,, u will have as good of a carb as u can get or better out of a box new ( except aftermarket maybe ),, put an 850 base plate on it ,,, or ,, send it to me ,,lol
Old 5th-April-2010, 03:18 PM   #15
04ctd
Nova(s): 77 BBC
i would be careful of the Proform parts if you replace the base plate,
they are bad reviews on the 'net, google leak, warped & proform.
YMMV.
i put a holley 4150 HP 950 on my 454.
bought it off craigslist for $250
needs a new bowl on one end, should be $20 off ebay
77 Nova
950 454 400 390
holley 750 vaccum secondary or 750 mech. secondary double pumper? ray homa Drivetrain & Performance 15 20th-March-2010 07:05 PM
750 eddy 1407 vs 750 Q-jet 74 hatchback Drivetrain & Performance 8 17th-November-2007 12:08 PM
750 dp tuning 71nova Drivetrain & Performance 9 29th-January-2007 11:04 PM
Jetting a HP 750 DP redlt499 Drivetrain & Performance 5 11th-January-2007 09:46 PM
750 cfm too much? 4doornova Drivetrain & Performance 7 18th-August-2006 07:53 PM
