why is my carb spitting fuel out of the top? - Chevy Nova Forum
Old 21st-March-2010, 08:12 PM   #1
chevyIIguy
Nova(s): 1967 chevy II 4door
I just got my ignition hooked up when i started my car it wont stay running but when it is it is spitting fuel out of the top of the carb. Some one told me it could be a timimg problem is there a way to set the timimg with out it running? the guy i bought the motor from says it run 38* fixed timing. PLease help!
Six in a row makes it go, REAL FAST!!
Old 21st-March-2010, 08:22 PM   #2
Lmonkey
Title: Readers Club
Float level?
Old 21st-March-2010, 08:26 PM   #3
chevyIIguy
the carb is a brand new edelbrock 600 could i have a bad pressure regulator my gauge says 4psi when the motor is trying to run but if i leave the fuel pump on it goes to 11 or 12psi.
Old 21st-March-2010, 08:34 PM   #4
firebird69racer
firebird69racer's Avatar
A lot of time trash gets stuck in the needle and seat. With it running try and pinch off the fuel line till it wants to die and then release the fuel line. Some times that will wash out the trash. Do it a couple of times. If that don't work then the float level might be to high or the float has a hole in it and it sunk.
The press. should be around 6-8 PSI tops.
Timing will have nothing to do with the fuel overflowing
Wade
Old 21st-March-2010, 08:49 PM   #5
Ryan V64SS
Ryan V64SS's Avatar
Nova(s): 64 SS, 63 Sedan
You are running too much fuel pressure, 6 to 8 at the most is ok for a carb. 11-12 can easily blow past the needle and seat and over fill the bowls
Old 21st-March-2010, 09:54 PM   #6
bp626indamix
Title: Nova Newbie
Nova(s): 1966 w/67 front clip
your needle and seat need to be cleaned.
Old 21st-March-2010, 10:00 PM   #7
chevyIIguy
How do I lower the fule pressure do I turn the screw down or up and how do I clean the needle and seat ( I've never had a carb before I'm a reformed ricer)
Old 21st-March-2010, 10:27 PM   #8
chevyIIguy
Old 21st-March-2010, 10:33 PM   #9
Ryan V64SS
Ryan V64SS's Avatar
loosen the jam nut and un-screw the allen head, try 1/2 turn at a time, re-tighten the jam nut. If your fuel press was really at 12# then I can assure you that was the cause and no need to clean your needle and seat.
Old 21st-March-2010, 11:06 PM   #10
infotom
infotom's Avatar
Nova(s): 1963 vert, 1963 wagon
Exactly as Ryan says..... get the pressure down, if still acts up then think about dirt in the needle and seat.
Old 22nd-March-2010, 11:59 AM   #11
chevyIIguy
Lowered the pressure and no more fuel fountian but now it won't start at all maybe I went to low when the car is not running the fuel pressure is at 8 while cranking it drops to 5 1/2 but that should still let it fire right?
Old 22nd-March-2010, 03:09 PM   #12
Ignitrous
Ignitrous's Avatar
Nova(s): 1973 Nova Custom
Sounds like a problem im having.
I started looking into my spark more. After checking my fuel lines/filter/bypass I have come to the conclusion that it must be spark. With full bowls and the fuel pump turned off the car should start and run until the bowls are empty.
I doubt its a fuel problem. Get your car started with the fuel in the bowls then work around the fuel pressure.
Old 22nd-March-2010, 03:19 PM   #13
Dutch
Dutch's Avatar
Nova(s): 71 SS/74 Custom/74 Hatch
What type of ignition do you have? If you have the point type, you may need to look at your points they may be bad. Like a few said, it sounds like the carb needs a closer look, your pressure sounds good if its around 8 psi.
A car needs two things to fire.....
1. Fuel (which you have)
2. Spark (look a little closer, or upgrade)
"Street Legal, who's really looking?"
Old 22nd-March-2010, 03:24 PM   #14
chevyIIguy
I have a msd 6al box and the car tries to fire and it pops thru the exhaust with a pretty blue flame ( I still have open headers) would it matter that I have no module in my distributor its hooked right up to the box the guy I got the motor from said that's how he ran it.
Old 22nd-March-2010, 03:46 PM   #15
Novahead
Novahead's Avatar
Nova(s): 1970 SS 396 four speed
If your running a MSD Dist it should have a green and purple wire coming out of it. This is the magnetic pick up, keep in mind that the longer these two wires are the more problems you will incounter will a bad signal. This can cause your back firing. Also these two wire MUST be twisted this will eliminate any bad signal, Basiacly its a choke in eletronic terms.
Holley 4150 - 650 spitting fuel after shutoff.. 1meanchevy Drivetrain & Performance 9 18th-February-2010 02:38 PM
Edelbrock top end with rockers and carb tnblkc230wz Ebay, etc. Discussion 0 13th-April-2009 08:30 PM
Optima Red Top spitting battery fluid! Dreuski Electrical 12 18th-February-2008 09:38 PM
Top fuel Hemis Nova_Guy Drivetrain & Performance 3 12th-May-2006 03:49 PM
