4th gear pressure switch part number? 200-4r lockup - Chevy Nova Forum
Old 20th-February-2010, 02:18 PM   #1
Greg_R_63
(OP)
Greg_R_63's Avatar
Nova(s): 1963 2-dr hardtop
I want to wire my 200-4r lockup in the same way as this Painless kit, with 4th gear lockup that can be cut off with the brake switch. I have a new solenoid, new connectors and wires, but I am uncertain of the 4th gear pressure switch. The one in the trans now has one terminal. I bought the trans rebuilt, and have not run it yet.
Mike Rowand has a good page on lockup wiring with a parts list, but his 700r4 setup is considerably more complicated than what I need. He does however have an extensive parts list, I just don't know which switch I need:
Pressure Switch (NO, Self-Grounding) 8642473 or 8627332
Pressure Switch (NC, Self-Grounding) 8642569 or 8634475
Any suggestions? Ideally, I'd just like to know which $5 switch Painless uses in their $145 kit.
1963 400 Series Hardtop
Old 21st-February-2010, 10:49 AM   #2
Dan_Lebherz
Dan_Lebherz's Avatar
Nova(s): 1964 Chevy II Wagon
YOu might also check out the BTO web site for some information on this.
64 Wagon
383, TH200-4R, 3.73s
11.683 @ 114.70 MPH 1.580 60'
Old 21st-February-2010, 11:21 AM   #3
Greg_R_63
(OP)
Greg_R_63's Avatar
This page answered my question
. I ended up getting the 8642473 from GM Parts Direct.
BTO uses a 2 pronged pressure switch in their setup, so the diagram is a little different.
Old 21st-February-2010, 12:04 PM   #4
Professor Fate
Professor Fate's Avatar
Title: Moderator
Nova(s): Between Novas now
Are you going to run this through the brake light switch? I used an 86 Monte brake light switch (without cruise) to give me the extra NC switch to run power to the lockup solenoid.
Posted with two Dixie cups and a string.
Old 21st-February-2010, 12:15 PM   #5
Greg_R_63
(OP)
Greg_R_63's Avatar
Yes I am. BTO sells a kit that is just a brake switch, a transmission connector at the case, a fuse, and the wires.
1967 turn signal part number,problem switch? blwnova Electrical 3 24th-February-2009 06:29 PM
200-4r lockup wiring and speedometer gear questions Greg_R_63 Drivetrain & Performance 4 21st-September-2008 09:48 PM
700r lockup convertor switch theracer Drivetrain & Performance 14 26th-August-2007 06:40 PM
200-4r pressure readings (need help) FunkyNova66 Drivetrain & Performance 9 3rd-March-2007 11:55 PM
Part number help novamaniac Drivetrain & Performance 1 5th-September-2006 07:09 AM
