fuel tank to efi - Chevy Nova Forum
Old 24th-January-2010, 09:50 AM   #1
marks LT
(OP)
marks LT's Avatar
fuel tank to efi
I have a 74 nova that I want to install a 6.2 into and in my research I cannot find a tank.I find them for 68-72 and 75-79.I thought the tanks from 73-79 were the same.Am I wrong?If u know of a reasonable solution please let me know.Thanks,Mark
Old 24th-January-2010, 12:34 PM   #2
tnblkc230wz
tnblkc230wz's Avatar
Nova(s): 1971 Nova
I've been toying with the idea of EFI too. The best solution I've come up with is a surge tank. It is a small tank (1 - 2 quarts) that goes between the main tank and engine. The high pressure pump pulls fuel from it and a low pressure pump fills it from the tank. The only drawback is it requires a second low pressure pump to keep it filled
These are used in road racing and autocrossing ensure to engine always has fuel
71 Nova, Pro-Touring/Autocross
LS3 eRod, 6 speed.
Old 24th-January-2010, 01:38 PM   #3
marks LT
(OP)
marks LT's Avatar
I installed a tank on my camaro that was aftermarket and works well and it was $499. and that is what I was really wanting to do but can only find them in the 68-72 or 75-79 models.I just dont want to make to many modifications or dead head the line with an external pump.Noise and cost efective play a big part Thanks,Mark
Old 24th-January-2010, 02:24 PM   #4
ChrisBorsheim
ChrisBorsheim's Avatar
Nova(s): 63 SS
http://www.ls1tech.com/forums/conver...ial-shape.html
the application shown on this thread is actually from a SNS members build, but I can't find the SNS link.
63SS/LS1 - Working on it.
Old 24th-January-2010, 10:33 PM   #5
tnblkc230wz
Nova(s): 1971 Nova
Select the proper pump and you will not hear it. I can barely hear my Mallory pump when the engine is off and I don't hear it at all when the engine is on. It is just like the factory cars. Turn the key and you hear the pump build preasure. Start the car and you can't hear it.
LS3 eRod, 6 speed.
Old 25th-January-2010, 01:39 PM   #6
marks LT
(OP)
marks LT's Avatar
what model # is that Mallory pump?I had a aeromotive pump on the camaro but the buzzing was driving me crazy.Thanks,Mark
Old 27th-January-2010, 02:02 PM   #7
tnblkc230wz
Nova(s): 1971 Nova
It is a Comp 70 pump. Ive heard there larger pumps where just as quiet.
Edit:
The pump has rubber washers between it and the bracket and the bracket has rubber washers between it and the car.
If I do it, I'll remake the bracket to be a 1 - 2 quart surge tank that I can mount both pumps too.
LS3 eRod, 6 speed.
Old 27th-January-2010, 06:04 PM   #8
marks LT
(OP)
marks LT's Avatar
Is that for EFI?I can find the pro comp 70's but not for fuel injection.Thanks,Mark
Old 27th-January-2010, 09:30 PM   #9
tnblkc230wz
Nova(s): 1971 Nova
The Comp 60 is for fuel injection. Sorry I thought you were looking for a lift lift pump. Walbro makes several that are suppose to be pretty quiet as well.
LS3 eRod, 6 speed.
Old 28th-January-2010, 10:47 AM   #10
slickman
slickman's Avatar
Nova(s): 1972 Nova SS
I just moved to EFI. Here's what I did, if you need more pics, PM me.
Old 2nd-February-2010, 09:39 PM   #11
dsw12387
Title: Registered User
Nova(s): 71 nova
I am running efi but out of the stock pick up and am having problems out of it.. how does the sump work for you?? Have you had any starvation runing around turns, when the tank gets low, or when you get on the gas hard?
efi fuel line fittings kennys64 Drivetrain & Performance 5 25th-March-2009 10:53 PM
EFI with Fuel Cell siderman Drivetrain & Performance 7 26th-December-2008 01:33 AM
Got my new gas tank! (in tank fuel pump) novaBRO Drivetrain & Performance 3 5th-May-2008 10:53 PM
EFI fuel delivery plans tpinovaII Drivetrain & Performance 18 11th-September-2006 12:11 PM
Surge Tank For EFI Revisited tpinovaII Drivetrain & Performance 5 26th-May-2006 02:16 AM
