69 396 Fuel line - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Originality
Old 22nd-January-2010, 01:30 PM   #1
waynew
(OP)
waynew's Avatar
69 396 Fuel line
I'm still in the process of getting my Nova back on the road in
fairly correct condition.
The fuel line stops about mid-passenger door and previously
continued with a rubber hose.
Does this look to be original to the car?
I was assuming that it came with one single continuous line?
Thanks for your help.
Name:	Fuel line 2.jpg
ID:	18680   Click image for larger version
Name:	Fuel line 1A.JPG
Wayne Weaver
1969 Nova SS396/375, M22
Old 22nd-January-2010, 02:06 PM   #2
bigdaddykane
Nova(s): 3rd gen Nova's
nope that is all original! the factory put a small piece of rubber line there to absorb any movement between the subframe and the body of the car...its supposed to have a short piece of rubber there.... by the way your line looks to be in very good shape too!
Old 22nd-January-2010, 11:14 PM   #3
1968 nova ss
Title: Nova Newbie
Nova(s): 1968 nova ss 396, 1968 nova ss 350
that is correct ,it should have a two piece line ;with the rubber hose right near ther back of the front clip.chris
Old 23rd-January-2010, 03:34 PM   #4
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
This is how all my 69's are.
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 24th-January-2010, 12:26 AM   #5
my69rat
my69rat's Avatar
Nova(s): 1969 L78 M22
Garage
Gas Line
My 69 L78 is the same, a good place to put a filter.
Old 6th-May-2010, 09:00 AM   #6
MI396SS
More Questions
So let me get this straight, is there rubber hose from there to the fuel pump then? Can anyone post a picture of the way the line is then routed from the pump to the carb? Thanks.
Old 6th-May-2010, 11:21 AM   #7
Schonyenko2
Routing from pump to carb and distribution depends if it's an L78, or L34 application. You can get either in kit form pre formed with distribution Y block for L78 from classic, Right stuff, etc.,
It appears you're runnung a 3/8 fuel line which would be correct for the L78 app.
Old 6th-May-2010, 11:31 AM   #8
waynew
(OP)
waynew's Avatar
From the Factory Assembly Manual...
Wayne Weaver
Old 8th-July-2010, 02:13 AM   #9
RStephen
RStephen's Avatar
Title: Nova Newbie
Nova(s): 72 SS 496
Garage
72 fuel lines
I have a 72 and am replacing my stock small fuel lines and sending unit to larger diameter line/sending unit. The original sending unit had one small fuel line coming out and the replacement with larger fuel line has an extra smaller line coming out which i think would be a return line. What is necessary to do with this line? Also... Located behind the back passenger seat is a canister that has 4 lines coming from it. Does anyone have a diagram of where these lines go and if they are all necessary?
Old 8th-July-2010, 09:43 AM   #10
kwhizz
Nova(s): 66 SS 66 Sport Cpe 70 SS
Pic's
Fuel Line yzair Drivetrain & Performance 6 26th-November-2009 10:59 AM
fuel line thefloyd1973 Drivetrain & Performance 2 1st-October-2009 10:35 PM
Fuel Line ? novas4life Drag Racing Forum 33 27th-August-2009 04:39 AM
1970 396 fuel pump question Novahead Originality 4 28th-December-2008 09:51 PM
3/8 or 5/16 fuel line? DeuceWagon Drivetrain & Performance 7 24th-March-2007 09:18 AM
