63 nova rear end - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 20th-January-2010, 02:42 AM   #1
nova-kid63
(OP)
Nova(s): 69 nova project
63 nova rear end
what is the best way to go with my rearend i have the stock 10 bolt in my 63 but im slowly building my car and want to know what i should do as far as the rearend?
Old 20th-January-2010, 03:30 AM   #2
63Randy
Nova(s): 63 Coupe
What are you using the car for? street strip or straight drag racing and how much money is in your budget.
Ummm I Think I Broke It
Randy
Old 20th-January-2010, 03:59 AM   #3
nova-kid63
(OP)
um i just want to use it for mostly drag but let it be street legal. but my budget is low right now cause im in college but im putting all the money into that i can at a time u know
Old 20th-January-2010, 06:40 AM   #4
VooDooII
Are you planning on running slicks? I have seen guys run low 11's with a 8.2in 10 bolt rear, you can always change it out as **** allow
Old 20th-January-2010, 01:17 PM   #5
nova-kid63
(OP)
yes i plan on running slicks
Old 20th-January-2010, 06:10 PM   #6
Manford
what kind of rear does it have now?
Old 20th-January-2010, 08:35 PM   #7
smalltire2
smalltire2's Avatar
Nova(s): 1968 used just for dragra
Your 10 bolt will last for awhile as long as you don't put down massive horsepower. Take into consideration on what suspension you are going to use such as 4 link, ladderbar, etc. since there will have to modifications made. If your planning on going fast might as well look into a Ford 9" with aftermarket axles etc. Don't scrimp on the axles I learned my lesson with my 12 bolt stock axles. If you are going to run some big tires you will prob have to have the rear end narrowed anyways. Take this into consideration for your plans. Good Luck.
Old 21st-January-2010, 04:13 PM   #8
nova-kid63
(OP)
im pretty sure its the stock 4 lug so i need to get some measurements on what lenght to use. i want to go with a 9 inch or 10 bolt
Old 21st-January-2010, 04:14 PM   #9
nova-kid63
(OP)
hey thanks for the info i was going to go with strange axles and im planning on running 450 to 550 hp not sure yet
Old 21st-January-2010, 04:41 PM   #10
kscoreusmc
Nova(s): 1963 Nova
http://www.novaresource.org/axle.htm
saves you that measuring time. Drivetrain part of the forum has plenty of rearend swap information when you are ready to go that route.
Old 21st-January-2010, 04:44 PM   #11
nova-kid63
(OP)
thank you very much
62 nova rear end ernest62 Drag Racing Forum 8 11th-February-2010 12:07 AM
62 Nova Rear End Help RobCab14 Drivetrain & Performance 17 1st-July-2009 04:32 AM
rear end for 63 nova aintnocherry Drivetrain & Performance 2 4th-May-2008 07:00 PM
63 nova rear end 63novamn Drivetrain & Performance 1 10th-December-2006 09:24 PM
