rear sway bar installation (Hellwig bar) - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 6th-December-2009, 11:10 PM   #1
the FLYER
the FLYER's Avatar
Nova(s): a B Pillar of Society
Yesterday David_H cam over and we installed the 5818 Hellwig rear sway bar on my '64. excuse the dirt, my car isn't a trailer biotch, i drive this baby
as you can see the sway bar is adjustable. i'm unsure how other than testing as the instructions don't really give specifics on the settings. i'll be calling them on Monday to inquire. as far as i know i have it in the middle setting
all the parts, the bar, brackets and end links are heavy duty parts. i'm looking forward to the installation of the Heidt's front bar... then road testing.
Johnny
the Flyer Special
'64 411 377-Tko600-3:73's
Old 6th-December-2009, 11:58 PM   #2
superdude13
superdude13's Avatar
Nova(s): 1972 nova
Let us know how it feels. I have been looking at sway bars for a while wanted to know how it does.
Old 7th-December-2009, 12:58 AM   #3
lisandon95386
Nova(s): 63ss
hey john,i ran a addco bar along time ago and the brackets on the rearend would move around with spirited driveing,aka beating the you no what out of the car.ended up tack welding the brackets on the rearend.also the framerail connection needed beefing up with plates,i tore the frame brackets clean out of the rail.just a heads up,iam sure you beat on that car like i always do mine.with the addco bar it seemed to work better with the end of the bar level at the endlink mount,WITH ME SITTING IN THE CAR.i mounted mine like yours below the rearend and then on top.IT WORKED BETTER WITH THE MOUNTING BRACKETS/BAR MOUNTED ON THE TOP SIDE OF THE REAREND,hope this might help
don
norcal group
Old 7th-December-2009, 01:01 AM   #4
klean63
klean63's Avatar
Nova(s): 1963 SS-Sold
don
norcal group
Look closely at the pic's. This is a different set-up than the Addco bar.
The Addco bar is rear facing and the links mount to the rear most part of the frame.
The Hellwig is a front facing bar and the links mount to a much sturdier section of the frame. If i'm not mistaken, the Hellwig also has a peice that goes into the frame for additional reinforcement
Old 7th-December-2009, 01:21 AM   #5
lisandon95386
Nova(s): 63ss
bill that addco i had mounted on the rear just like johns and faced forward,the endlink brackets used a u bolt into the frame.i tore the framerail u bolt clean out of the driverside framerail,plumrat was wondering what happened to it,while he was putting the new qrts on my car.he is going to fix that chunk of metal that was torn out.that bar john has mounts lower in the front than the addco i had on my car,the frame bracket on johns car is much lower than the addco i had.your right bill that hellwig setup looks way better than the addco i used in the early 80.s
don
norcal group
Old 7th-December-2009, 02:27 AM   #6
the FLYER
the FLYER's Avatar
Yes, a spacer/tube fits inside the frame rail to prevent the bolt from crushing/collapsing the frame rail when tightened or (i'll suppose) when forces are put on it.
might be a good idea to weld the brackets to the differential too... i hadn't thought of that. i'll have to keep an eye on it, see how it does.
i'm hoping to have the front end pulled down this week to have the brackets welded to my lower A Arms. i might be swapping spindles too but on that i'm still undecided... also another demon reared its ugly face... a leaking intake manifold. so now i'm trying to decide on whether i'll just pull the engine so everything can be cleaned up or to do it with the engine in the car... i might be changing cams at the same time so that's another reason to consider the engine removal... sigh... and here i thought my car was done yeah yeah yeah... when are they ever done ?
Johnny (in mock up stage)
the Flyer Special
Old 7th-December-2009, 02:42 AM   #7
Shawn F.
Nova(s): 1963 Chevy II Wagon
Looks very nice. I need to add a sway bar to my 63 Chevy II wagon, do they make an application for a wagon or is it that same as any 1st Gen Chevy II?
Old 7th-December-2009, 02:47 AM   #8
the FLYER
the FLYER's Avatar
LongRoof, Coopercar or Sedan... i believe it's the same bar
just a thought though, just in case... from what i've always heard, never use a rear bar without a front bar
(just a reminder)
the Flyer Special
Old 8th-December-2009, 02:04 PM   #9
Dave@Hellwig
Title: Nova Newbie
As long as the U-bolts are torqued correctly, the saddles on the axle should not move. As far as initial setting, I reccomend using the softest setting first (longest distance from the axle) for the initial setting. It can be made stiffer after you drive the car and become familiar with its new characteristics. If you don't already have a front bar, you need one for the car to handle well. Otherwise the car will be loose and could end up being uncontrollable if pushed hard. We have our new front bar p/n 5718 that works with the stock suspension or a CPP mini-subframe. It features 7" long end link bolts to allow the suspension to freely articulate.
Old 8th-December-2009, 03:42 PM   #10
the FLYER
the FLYER's Avatar
i don't recall if you're the guy i talked to on the phone but regardless... nice sway bar, good looking product.
as far as the front bar goes, i have a Heidt's clip.
the Flyer Special
Old 8th-December-2009, 10:13 PM   #11
Duane
Duane's Avatar
Nova(s): 66 2DR POST LS1
Any idea if this will fit on a car with springs moved inboard?
66 100 series,LS1/4L60e,TCI,9" Currie,Tru-trac,4wh disc, Caltrac bars, VAir Gen IV, DDigital VHX dash.
Old 8th-December-2009, 10:17 PM   #12
the FLYER
the FLYER's Avatar
Duane, my shock plates have been modified to allow for the QA1's. the distance between the shock and the bar is approximately 3/4" per side
my springs are in the stock location... so i'll say no, it's not going to fit with relocated springs.
the Flyer Special
Old 8th-December-2009, 10:28 PM   #13
Duane
Duane's Avatar
Thats what I figured Johnny, oh well, guess I'll keep searching, trying to stay away from them 3-400 dollar adjustables.
Old 8th-December-2009, 10:35 PM   #14
the FLYER
the FLYER's Avatar
Duane, just a thought but aren't the Cal-Tracs going to operate somewhat as a sway bar ?
the Flyer Special
Old 10th-December-2009, 05:22 PM   #15
Craigert
Craigert's Avatar
Nova(s): 3 63 VERTS, 64 WGN, 64 HD
Johnny,
Just to keep you up to date, I was the test mule for the new front Hellwig sway bar and they so kindly set up the rear with one of the same sway bars you have. The Blonde convertible!
I love the way it corners.
Craig in Fresno,63 convert 283 w/TH 350, 64 wagon 350 w/overdrive, 64 hardtop with 350
New 1st/2nd Gen Hellwig Sway Bar! NOGO Steering, Suspension, and Chassis 10 13th-March-2010 02:27 PM
Rear Sway Bar nreynolds Ebay, etc. Discussion 0 14th-November-2009 08:10 PM
Another rear sway bar. nreynolds Ebay, etc. Discussion 3 25th-August-2008 09:57 PM
65 Rear Sway Bar Rat Twins Steering, Suspension, and Chassis 2 6th-August-2008 03:53 PM
rear sway bar 77black Steering, Suspension, and Chassis 3 26th-November-2007 09:54 AM
