New Posi rearend with 3.73's.... Break in tips? - Chevy Nova Forum
Old 19th-November-2009, 12:19 AM   #1
$Piker
(OP)
$Piker's Avatar
Nova(s): 1969 Nova 385 stroker
Well I just got my car off of the lift with all the new bushings and new rearend bolted up and I cant wait to stomp all over it! Before I do I read that I should let it have a few heat cycles? Suggestions?
Old 19th-November-2009, 01:32 AM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
Per Richmond gear!
BREAK IN
A new ring and pinion installation, especially a high numeric ratio with new bearings, can cause an excessive heat buildup in the rear end and cause softening of the gear teeth and bearings if a break in is not performed.
Street vehicles should be driven at normal street driving speed for approximately 10 miles, then stop and let cool for 30 minutes. Do this 2 to 3 times. Towing vehicles need approximately 200-300 miles of normal street driving before being used for towing.
On circle track race cars make approximately 6 to 8 laps at slow speed, then let cool for 30 minutes. Make 6 to 8 more laps at slow speed, then 2 to 3 laps at full speed, the let cool again for 30 minutes.
Drag cars need only an initial run-in since they are driven short distances and heat is not normally a problem with proper lube and backlash allowance.
NOTE: If after the above break in is performed, overheating of the rear end is suspected, repeat the final portion of the break in procedures.
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 19th-November-2009, 08:02 AM   #3
epfatboy
epfatboy's Avatar
Nova(s): 1964 Chevy Nova SS
Don't forget the final step, the 4-way intersection manuver complete with cell phone pictures
'64 Nova
2015 Transformation
Old 19th-November-2009, 08:58 PM   #4
$Piker
(OP)
$Piker's Avatar
Haha Will do. Thanks Big Al. Right after I posted this I double checked my Richmond gear box and found the exact instructions. I also saw your run on pass time last night!
Posi Rearend ? NeoNova Drivetrain & Performance 20 25th-November-2008 06:11 PM
Posi rearend failure symptoms? Rik Drivetrain & Performance 14 9th-July-2008 01:17 AM
Rear Axel coming out for posi swap - any tips? Luke Shaheen Drivetrain & Performance 6 23rd-July-2007 01:15 PM
Posi Rearends, Rearend Series? Luke Shaheen Drivetrain & Performance 2 8th-June-2007 11:03 AM
Posi Rearend in LA 67 Nova 1000$ 64chevyII Ebay, etc. Discussion 1 3rd-April-2007 04:17 PM
