Old 5th-November-2009, 05:12 PM   #1
1slow64
1slow64's Avatar
Nova(s): 64 2d sedan 400
Angry "help" oil leak!
Got an oil leak kicking my ***! It's coming from the front of the intake.
I have replaced the intake gasket twice.
Both times I didn't use the cork strips that came in the set. I just used
black RTV.
It's a 400 with a super victor intake and dart pro 1 heads.
I'm using the felpro 1206 gasket set which is what DART recommends.
jeff
1964 Chevy II 2 door sedan 406
1969 Camaro SS X66 396 #'s matching
Old 5th-November-2009, 05:19 PM   #2
69LT1Nova
69LT1Nova's Avatar
Nova(s): 1969 Nova, grandma fresh.
Yay, intake manifold problems.
First off - you sure its the intake and not the timing chain cover? Just checking.
Next, back to the basics.
  • You cleaning the intake and front China wall with wax and grease remover or acetone prior to assembly?
  • You letting the RTV set up and skin a little before assembly?
  • You running the RTV all the way up to the gaskets?
  • You being generous with your RTV application? (not a time to be stingy with it)
Build:
http://www.stevesnovasite.com/forums...d.php?t=101770
LT1 baby!
Old 5th-November-2009, 05:22 PM   #3
tbills66
tbills66's Avatar
Nova(s): 66 SS
Do you have the block drilled to help hold the rtv?
Old 5th-November-2009, 05:26 PM   #4
69LT1Nova
69LT1Nova's Avatar
This will help, but is a hair-raising experience if you really don't want to f-up your block. I've had good success using a center punch to make divots in the cast iron... its just enough to give the RTV something to catch on.
Oh... another thought - did you have your heads milled to increase compression? If so, did you have the intake milled to compensate?
Build:
LT1 baby!
Old 5th-November-2009, 05:30 PM   #5
mrdreex
mrdreex's Avatar
Nova(s): 72' Nova 383 AFR/solid
I have a bunch of oil issues as well. Did a bunch of replacing gaskets, etc, etc. Do you run any kind of crankcase ventilation? Excess will push oil out of everywhere if there is enough no matter how good your seal.
Old 5th-November-2009, 05:53 PM   #6
1slow64
1slow64's Avatar
First off - you sure its the intake and not the timing chain cover? Just checking. :yes, verified that today
  • You cleaning the intake and front China wall with wax and grease remover or acetone prior to assembly? Just brake klean
  • You letting the RTV set up and skin a little before assembly? Maybe not
  • You running the RTV all the way up to the gaskets? YES
  • You being generous with your RTV application? (not a time to be stingy with it) YES
i'm thinking i'm not cleaning it good enough and not letting the rtv skin over
Old 5th-November-2009, 05:57 PM   #7
69LT1Nova
69LT1Nova's Avatar
Been there, done that!
Had an old mechanic once tell me that he goes for a smoke & coffee, then comes back to drop the manifold on.
Build:
LT1 baby!
Old 5th-November-2009, 06:04 PM   #8
1969BlueNova
Nova(s): 1969 BB Nova
I have always just used brake kleen to wipe of the front and back and have always been fine.
69 Nova, 454/M20(4 Speed). Converted Mustang guy.
Old 6th-November-2009, 06:58 AM   #9
65 Post
65 Post's Avatar
Nova(s): 65 Post
I use laquer thinner to clean the mating surfaces and have never let the silicone skin over. Never had a leak. Are you sure it's from the manifold? Isn't there an oil galley pipe plug in front of the manifold, above the timing cover? I can't remember. Dave
"Are you the hunter, or the prey?"
65 Post
Soon to be quick, I hope.
2003 GORDY 135" RED, 8.09 @ 163
Old 6th-November-2009, 01:07 PM   #10
Glenn
Glenn's Avatar
Nova(s): 1966 Chevy II Wagon
Had an old mechanic once tell me that he goes for a smoke & coffee, then comes back to drop the manifold on.[/quote]
He is correct !
It MUST cure fully before you fire up the engine too.
Glenn
1966 Chevy II Wagon X-"Stock" -"Super/Stocker"
Old 6th-November-2009, 01:12 PM   #11
The Big Al
The Big Al's Avatar
Nova(s): 68ss,70ss,70,65 Longroof
I always let the sealer sit for about 10min.
I also take a punch or a X letter punch and make marks on the block and intake to keep the sealer in place and give it something to bond to.
Al
I know your fast!Because I was 'HALLIN A**" When I passed you!
www.cardomain.com/id/alsmith1214
Old 6th-November-2009, 10:51 PM   #12
Rbace123
Nova(s): 1966 Chevy 2 nova
You know there was another post about this not so long ago and most said to NOT let the RTV skin over and that it needed to be wet per say to stick to the parts. Assemble before skinning over and let set for a while then tighten to form a preload on the RTV.
I too am following close because I have a very small leak on my intake also, only the rear and not the front.
Old 7th-November-2009, 08:45 AM   #13
65 Post
65 Post's Avatar
Nova(s): 65 Post
If you just have a small leak on the intake, front or rear, and know that it is coming from there, clean it with carb cleaner or laquer thinner and make sure it's dry. Then squirt some silicone in the spot that's leaking. Let it dry and get on with it. It's not a high pressure spot if you run breathers. Then when you take the engine out some other time, fix it correctly. Plus, I don't start the engine for 24 hours after I used sealer. Give it time to dry. Dave
65 Post
Old 8th-November-2009, 01:21 AM   #14
JRouche
JRouche's Avatar
EXACTLY!!! For anything that I use RTV or silicon on I completely dry both surfaces. I use acetone. Then lay the bead down and set the mating part down as soon as I can. So it hits the wet bead. I dont let it compress the bead much, just a lil squeeze, just to where both surfaces are in compleate contact with the wet bead of RTV. If I need to shim a part cause its so heavy that it will totally compress the bead I used shim sticks to hold up the heavy part. I dont do just engines. Some of the stuff I seal are pretty heavy.
Once the bead of silicon (ok, RTV) is set up I clamp it all down. And when I say set up I like to give it as much time as I can afford. A day, two days, heck, a week if I have the time.
This letting it skim up for one side just doesnt make ANY sense. Why would anyone want the bead to adhere nice and solid with a wet seal on one surface but not want it to be the same on the other surface?? Never made ANY sense to me. Nope, wet bead on both sides.
If you let both surfaces get a good seal on the wet bead, then let the bead stiffen up with time you are creating a solid O ring of sealer.
You wont get any squish out of liquid sealer to contaminate the oiling system and you have a solid connection on BOTH surfaces.
Ive never had a failure doing it like that. Cant rush the silicon gaskets. Do it correctly and they will last a long time.. JR
What I write is opinion, none of it is factual.
Old 8th-November-2009, 11:48 AM   #15
the mechanic
Nova(s): 1970 Nova
Both ways will work, as will putting the sealer on and bolting manifold down right away...I prefer the slight skin method-ive worked with hundreds of people who did this hundreds of ways-
two things always remain the same, Very clean surfaces and using enough rtv.
Oil Pump "gaskets" Phil Drivetrain & Performance 7 30th-March-2009 05:24 PM
What can I use to "wash" or "flush" the metal particals out of my engine block? todsladek Drivetrain & Performance 9 30th-January-2009 12:34 PM
difference between "acetone" "paint thinner" and "mineral spirits"? Scooter Body and Interior 10 27th-April-2007 08:31 PM
