Old 3rd-November-2009, 05:15 PM   #1
dave's 62
dave's 62's Avatar
cpp brake kit problem
Well heres my prob. I ordered a 5 lug front disc conversion kit for my 62HT 1 year ago and i just pulled them out of the box to install them. problem is the upper left side caliper hold down pin is rubbing the rotor causing the rotor not to spin. These are pre-assembled spindle out to caliper. it looks as if the hole in the caliper brakect was drilled and tapped in the wrong place.The lower pin seems to have good clearance and the right side assembly is fine.I think all i would need is a new caliper bracket. I'm afraid they will not warrenty this since it has been so long. still have the reseit dated 9-3-08. Has anyone ever ran into this problem? I remember a thread started by the cpp rep. for any problems but i can't find the thread. HELP ME PLEASE.
Thank you Dave.
Old 3rd-November-2009, 05:29 PM   #2
Nova 404
Nova 404's Avatar
Nova(s): 1967 Nova SS
From what I have seen try loosening the two bolts that hold the caliper bracket to the spindle and see if you can gain clearance you need by repositioning the bracket.Once you have the clearance you need tighten the bolts back down.One of the problems has been the holes in the bracket at the spindle are 1/2 and the bolts that are used are 7/16 this leaves room for some movement
http://s165.photobucket.com/albums/u55/nova404/\
Member of the NorCal Brotherhood!
Old 3rd-November-2009, 05:39 PM   #3
dave's 62
dave's 62's Avatar
Thanks for the reply. Well i'll give the a shot.
Old 3rd-November-2009, 06:36 PM   #4
NOGO
NOGO's Avatar
Nova(s): 67 Chevy II Nova HT
Some cars had 1/2" holes in the steering arms and spindles (like mine). Most kits are made with 1/2" holes so they fit all the cars and the slop is not an issue. I would prefer not to have the slop and drill the holes to 1/2".
www.JollyRodder.com
114photography.com
Nothing better than NPHNP!
Old 3rd-November-2009, 07:39 PM   #5
dave's 62
dave's 62's Avatar
These were a full kit spindles,arms,drilled/slotted rotors,calipers,w/b,and flexlines all preassembled.I'm really not diggin the slop ether. i'm at work right now so i'm not sure if the slop in the bolt holes is there. will check tonight.
Old 3rd-November-2009, 11:11 PM   #6
Sooner1
Sooner1's Avatar
here is the link...
http://www.stevesnovasite.com/forums...d.php?t=130655
I would call them.
I got in trouble by the mods for "ranting" on previous posts but it is what it is: sometimes you get someone good to talk to on the other line sometimes you dont. I called and asked for jeff and danny both were not in- so a "sales" guy fielded my questions. he was worthless... (okay, okay...Im done mods).
I hope you have better luck- just be honest with them Id bet they might understand. Im like you, I had my disc kit for over 9 months before we put it on this weekend.
best wishes
steve
72Nova
Getting faster...slowly.
Old 4th-November-2009, 12:10 AM   #7
dave's 62
dave's 62's Avatar
Well i loosend the caliper bracket and moved it around and gained some clearance so the rotor will spin freely now. But i'm really not happy with the amount of play there is in the bracket.It seems a little on the hokky side if you ask me. I would think it would move over time, theres a lot of force on those 2 bolts when applying the brakes to have that amount of slop.I will give them a call and see if i get the run around or not. for a 700$ bones kit there should be a little more QC i would think. Thanks for all the help guys.
Old 4th-November-2009, 12:42 AM   #8
NOGO
NOGO's Avatar
Use 1/2" bolts and drill your steering arms if necessary.
www.JollyRodder.com
114photography.com
Old 4th-November-2009, 10:50 AM   #9
67 church
67 church's Avatar
Nova(s): 67 2dr hrd top
For what it is worth, our experience with this situation was not resolved with drilling the steering arms and or spindle for a 1/2" bolt. With the smaller bolt in the bigger hole the brakes on the old "Test" wagon worked fine. Once we drilled the holes to accept the 1/2" bolts everything became centered properly, however we had the rotor and caliper bolt issue at that point. Prior to drilling the 1/2 inch holes the slop was used to allow for the extra needed clearance.
At this point CPP was contacted and revised parts were installed to make for the needed improvements. I was not present when the new parts were installed nor do I know what the revision was. There is a fix for the issue it is just a matter of a phone call and explaining the problem.
Chuck Church
330-442-7162
www.churchboysracing.com
Old 4th-November-2009, 11:43 AM   #10
383Nova
383Nova's Avatar
Just one more thing that does not work out of the box. Hope they correct the issue based on how they made them that way.
Old 4th-November-2009, 12:02 PM   #11
aron69nova
aron69nova's Avatar
Nova(s): 69 Race Car, 66 Longroof
My experience with CPP is that they will go over the top to make sure that their customers are taken care of. If you ever have the opportunity you should go down there and bs with them. Great bunch of guys.
1969 Nova
383/TKO/12 bolt
6.984 at 100.48mph
"Because Three Pedals are Better Than Two!"
Old 4th-November-2009, 12:14 PM   #12
Cador
Nova(s): 1973 Nova 4 Door 350
See this thread
Old 4th-November-2009, 02:44 PM   #13
Motoboy
Motoboy's Avatar
Nova(s): 63 Nova Wagon
I wonder if the slop is causing the sound I hear when I apply my brakes. It's an initial click sound if I'm on and off the brakes.
Also anyone have issues with squealing brake pads?
Home of the "DirtyII"
Old 4th-November-2009, 02:49 PM   #14
Nova 404
Nova 404's Avatar
Mine squeaked like hell,I used some MOC brake noise stuff on friction surface and lubed all of the contact points with PBC grease and they have been quiet since September.I do not know if it will be a long term fix.I think it is caused by poor quality(cheap) pads.
Old 4th-November-2009, 03:01 PM   #15
tbills66
tbills66's Avatar
Nova(s): 66 SS
Stories like these make me glad I went with who I did for my brake kit. I was real close to ordering the CPP kit but didn't. No brake system should have to be modified to fit, especially when bought as one unit. Modifying brakes is a bad thing.
cpp disc brake kit Sooner1 Steering, Suspension, and Chassis 18 20th-February-2009 03:40 AM
CPP brake kit problem nova_rookie Steering, Suspension, and Chassis 8 20th-January-2009 06:17 PM
Cpp Big Brake Kit justsomeguy Steering, Suspension, and Chassis 3 27th-March-2008 07:45 AM
CPP brake kit? 72RallyNovaRon Steering, Suspension, and Chassis 4 18th-September-2007 04:48 PM
CPP brake kit TRoberts207 Steering, Suspension, and Chassis 1 24th-April-2007 04:52 AM
