Performer vs. Performer RPM - Chevy Nova Forum
Old 2nd-November-2009, 06:50 PM   #1
epfatboy
epfatboy's Avatar
Nova(s): 1964 Chevy Nova SS
What is the fundemental difference between the Performer and Performer RPM intake?
I'm wondering if I'm going to lose or give up anything with either selection given the application.
Street Toy
327 +.030
10.5 compression
xe268 cam
RHS Vortec heads (1.94/1.50)
TH350
2200-2800 stall
3:73 gears
'64 Nova, 72 GMC Jimmy, 84 FLH, 96 Fatboy, 36 Ford pickup, 08 Charger SRT.... nothing is stock
Old 2nd-November-2009, 06:55 PM   #2
photoman
photoman's Avatar
The Performer is essentially an aluminum version of a factory cast iron manifold. Use the Performer RPM.
1969 Nova
350
TH400
8.5" 10 Bolt
Old 2nd-November-2009, 07:19 PM   #3
epfatboy
epfatboy's Avatar
Yeah but what is the difference between them? They are both dual plane so is it the added height only?
Old 2nd-November-2009, 07:24 PM   #4
photoman
photoman's Avatar
Smaller ports, smaller plenum, etc.
1969 Nova
350
TH400
8.5" 10 Bolt
Old 2nd-November-2009, 08:31 PM   #5
elvera
I just got an Edelbrock catalouge and it seems they have a new manfold called Performer EPS and a New chambered "straight" through muffler.
Old 2nd-November-2009, 08:52 PM   #6
Bipolar4U
Title: Readers Club
Nova(s): '64 2dr. SEDAN
Elucidation
I think you'll find this article helpful. There are some real differences between the several Edelbrock manifolds makes for the small block Chevy.
http://www.popularhotrodding.com/tec...ech/index.html
Old 2nd-November-2009, 08:55 PM   #7
Cory
Cory's Avatar
Nova(s): 1965 Coupe/327/th350/3.73
It's a matter of matching parts. Your cam grind lists the power band from 1600 to 5800 RPM's. An Eddy Performer lists power gains from idle to 5500 RPM's, with the Performer RPM power gains at 1500-6500 RPM's. The Performer RPM would match your specific cam grind and give you the most performance available. Combined with your stall, you would have a great package with your cam and the Performer RPM. I would probably top off the combo with a Holley 650cfm double pumper. One thing I've learned from this site is you can have all cool parts but if they don't jive with each other, you've got an expensive hunk of metal weighing down your front end
By the way, what brand is your converter? I'm currently looking for a 2200 to 2800 stall.
Old 2nd-November-2009, 09:08 PM   #8
epfatboy
epfatboy's Avatar
Boss Hog, I have had a few of there converters even back when they were Alabama Converters and they have been the balls. $200 with free shipping!
Old 2nd-November-2009, 09:17 PM   #9
MarkW
Remember 2 things here. 1- Your cam was designed for a 350 so it will act a little bigger in a 327. 2- A Performer manifold will act bigger on a 327. A Performer RPM will act bigger yet. They were both designed for 350s. If you were doing 4.56 gears and winding to 7000 rpm you would pick parts for a 350 doing 6700 rpm with 4.10 gears. An old Chevy Z/28 high rise would be perfect.
Old 2nd-November-2009, 09:43 PM   #10
Cory
Cory's Avatar
Awesome. Thanks. I'm looking at buying their brand and I found a 2200 to 2600. I'll look again for a little higher stall. They're not to far from me in Madison.
Old 2nd-November-2009, 09:53 PM   #11
epfatboy
epfatboy's Avatar
Yep The plan is to move bigger in unison and not over do it at the same time. The reason I went with 10.5 compression is so I could fully utilize the head/cam combo I picked out. What I want now is to match the carb which is math and we seem to be discussing on another thread. The manifold is another story, too much rise and I lose bottom end but gain velocity/high end. Not enough rise/crappy runner design and I lose atomization/velocity and don't fill the chamber... I'm leaning towrds the Performer, I can always add a spacer if needed.
Old 2nd-November-2009, 11:03 PM   #12
6NOVA4
6NOVA4's Avatar
Nova(s): 64 SS "street car"
The Z/28 intake is a good one. But the perfomer RPM has been proven to be better across the whole power curve.
IMO running the RPM or a Z/28 intake would be about the same as running a performer with a 1" spacer. Personally I like the look of the RPM. I had a 383 with a 268 cam and 10.5 to 1 comp and I had called Edelbrock and asked them which manifold to use. The recommended me to use the performer to make more torque off idle to 3200 RPM vs the RPM given my particular combination. It was going in a truck not a street car.
Old 3rd-November-2009, 07:13 AM   #13
onecarnut
onecarnut's Avatar
Nova(s): 1968 Chevy II
I wrote Edelbrock to ask for their advise on an intake for my 330 HP crate engine.
They recommended the performer; not the RPM.
In simple terms, the RPM is better suited for higher revs.
Gone but not forgotten
edelbrock performer rpm heads chevyIIheavy Drivetrain & Performance 2 19th-October-2009 11:05 PM
Edelbrock Performer RPM intake jlowery78 Drivetrain & Performance 2 4th-June-2009 09:44 PM
SBC Performer RPM heads carjai Drivetrain & Performance 8 18th-November-2008 08:56 PM
Performer vs. RPM danthegeek Drivetrain & Performance 2 28th-December-2007 04:16 PM
Performer RPM Air Gap intake cleaning ovrdrive Show and Shine 19 19th-April-2007 02:44 PM
