Pilot bearing install - Chevy Nova Forum
Old 26th-October-2009, 08:34 PM   #1
RICCHIO
Title: Nova Newbie
Nova(s): 67 NOVA
Is there any special tool or way to install a new bronze pilot bushing in the back of the crank? Will using a socket be ok? Also, anyone know how much gear oil in a 10 bolt and a muncie tranny? I know you fill until it comes out of the plug hole, but i would just as soon put the correct amount in. Can i put the same oil in both the rear end and muncie trans? Thanks
Old 26th-October-2009, 09:00 PM   #2
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
go buy this.. it will answer all the typical questions you just posted and you learn something too....its a 1969 motors... it covers all American autos from 1963 to 1969
http://cgi.ebay.com/ebaymotors/1969-...sQ5fLiterature
this is a 1966 manual..
a nation of free men, shall live forever, or die by suicide
Old 27th-October-2009, 03:00 PM   #3
JIMS63s
Title: Nova Newbie
Nova(s): 63 Nove SS 63 Nova 2dr s
You can use a socket to drive in the pilot bushing just be careful not to peen the bearing over it's softer than the socket. Drive it in nice and straight until it's flush. Your muncie will take 1 quart and your 10 bolt about a quart and a half. 80W-90 gear oil will work fine in both. If you use it in real cold weather, synthetic gear oil will not get as thick and the muncie will shift a lot nicer until it warms up. Costs about three times as much though and is not needed if yours is a fair weather car.
Old 27th-October-2009, 04:04 PM   #4
6NOVA4
6NOVA4's Avatar
Nova(s): 64 SS "street car" SOLD
you can use a socket but be careful the inside diameter can change once the bushing is in the crank. Check to make sure the input shaft will fit after installing the bushing.
Old 27th-October-2009, 05:09 PM   #5
3DTim
3DTim's Avatar
Nova(s): 66 ProStreet 82 SWB C-10
Put that sucker in the freezer over night Then us a socket. I have an old kick pin out of an old ford truck I use. A 1" brass rod about 6"long is nice to use to.
PROSTREET FRATERNITY
Old 27th-October-2009, 05:12 PM   #6
Lugnut79
Lugnut79's Avatar
Nova(s): 67 Chevy II
I have an old input shaft from a manual tranny I use to pound them in and out with. Just put it on the end and tap it it in. It also works good for aligning the friction disc until you get the pressure plate tightened down.
Camel Humped 355 best, 11.55 @ 116
Old 27th-October-2009, 07:30 PM   #7
VooDooII
I was just going to recommend the same procedure but you beat me to it
Old 27th-October-2009, 09:01 PM   #8
stock z/28
I do the same as Mr. Lugnut.
Pilot bearing john67 Drivetrain & Performance 6 20th-May-2008 11:55 AM
pilot bearing davidr5610 Drivetrain & Performance 2 1st-May-2008 12:55 AM
Pilot Bearing tsimpson Drivetrain & Performance 12 26th-November-2007 01:11 PM
Pilot Bearing graymond Drivetrain & Performance 3 1st-July-2007 08:13 PM
pilot bearing GuySmiley Drivetrain & Performance 24 10th-October-2006 11:51 PM
