Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
StevesNovaSite.com is the premier Chevrolet Nova forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 18th-October-2009, 07:47 AM   #1
L79
L79's Avatar
Title: Nova Newbie
Nova(s): 1966 Chevy II SS
66 CA clip LS and Muncie
Does anyone have the part number to the pilot bushing thats supposed to be used with muncie and LS motors? also i have seen some pretty clean ls installs in a 66 with headers, wheres the best place to go to get headers without spending 1K or so. Thanks
Old 18th-October-2009, 09:10 AM   #2
67 church
67 church's Avatar
Title: Supporting Vendor
Nova(s): 67 2dr hrd top, 2-63 wags
At the present time there are no off the shelf headers available............at this time.
I see I need to read a little better you are using an aftermarket clip, I was referring to a stock clip.
Chuck Church
330-442-7162
Made in the USA
Old 18th-October-2009, 10:39 AM   #3
Nova 404
Nova 404's Avatar
Nova(s): 1967 Nova SS
What does this mean?Do you know someting we don't????????
http://s165.photobucket.com/albums/u55/nova404/\
Member of the NorCal Brotherhood!
Old 18th-October-2009, 12:21 PM   #4
TomM
TomM's Avatar
Nova(s): 66-SS, 66-Wagon,
Street and Performance makes a nice set of coated mid length for about 550.00 that work for CA, TCI and Heidt's. Do a search on LS1Tech....some there have done the Muncie mod....
Hmm...let's see, Chuck figured out solutions for the rack and pinion deal, a-arms etc......I don't know, but I would bet you a dollar he is either working on some already, or has a set about finished....
My money's on Chuck for sure......
T,
Old 18th-October-2009, 02:19 PM   #5
L79
L79's Avatar
Title: Nova Newbie
Thanks for the info TomM, your 66 is really nice, looks like you took alot of time with the wiring among other details.
Old 19th-October-2009, 09:26 AM   #6
TomM
TomM's Avatar
Thanks, it's a work in progress......
T,
Old 20th-October-2009, 03:00 PM   #7
kcmocarguy
kcmocarguy's Avatar
Nova(s): 1962 2 dr hdtp
A member here worked with TCI on developing LSx long tube headers for aftermarker clips. They look very nice and are reasonably priced. Try calling TCI about them.
I have a Muncie behind my LS1 in my '62 and used a GM pilot bearing recommended over on LS1tech.com. I would use the extended bushing next time, I think it just fits better. Do a search over at LS1 tech.com or contact Ram or another clutch manufacturer, one of them has the bushing you are looking for.
By being on both Steve's and LS1 tech I had a fairly easy time getting mine runnng. It started right up too..
'62 Chevy II, TCI front clip, '98 Camaro LS1, Muncie 4 speed, Classic Air, black and red, coming together
Old 20th-October-2009, 05:37 PM   #8
stangs4sale
stangs4sale's Avatar
headers
I have a set of TRUE long tubes for 62-67 nova. Pm if interested
LS1's will rule the world!!!!!!!!!!!!!!
Old 30th-October-2009, 07:41 AM   #9
L79
L79's Avatar
Title: Nova Newbie
Thanks for all the help, greatly appreciated, in case anyone else is looking the pilot bearing GM part no. is 12557583. Now for the long tubes , KCmocarguy, did you use the slave throw out bearing or external slave? i have to mount the master on fire wall with 67' 9" brake booster.....its a challenge and the last one before motor goes in, everything else is good to go.
Old 30th-October-2009, 12:02 PM   #10
kcmocarguy
kcmocarguy's Avatar
I have mechanical clutch linkage in my car, no hydraulics. If it doesn't work out I will go with a slave and master cylinder. Are you sure the 9" booster will work? Even a 6" dual would be really tight on mine. I went with no power, Corvette master cylinder.
Old 31st-October-2009, 07:16 AM   #11
L79
L79's Avatar
Title: Nova Newbie
yeah, i'm thinking its gonna be snug but it should clear, but i cannot confirm this yet, if i can get out thier today i was going to drop it in so i can check that and the pan, which i suspect will needed to be changed to the h3 pan.
what are you running as far as front end? and do that make a bracket for block side z bar or was it fabbed? i considered mechanical but i figured one day i would want the tremec and so i went with hydraulic now.
Old 31st-October-2009, 04:43 PM   #12
L79
L79's Avatar
Title: Nova Newbie
the 9" power booster does clear by about 1/2"-3/4"
Old 2nd-November-2009, 02:48 PM   #13
John65ss
Any good detail shots of how you mounted the clutch master w/ a 9" booster? How did you reinforce the firewall? What's the pedal connection look like?
1965 SS 327 White w/ red interior
Old 3rd-November-2009, 12:24 PM   #14
kcmocarguy
kcmocarguy's Avatar
I have a TCI clip. I am really surprised that a 9" booster fits. I custom made all of my mechanical clutch link except the pedal.
Old 7th-November-2009, 06:02 AM   #15
L79
L79's Avatar
Title: Nova Newbie
I still have to mount the hydraulic master, taking my time on this one because everything is pretty tight but i have the muncie trans bracket done, using a wilwood slave cylinder, machine shop water jetted the parts for a reasonable price. what ever brackets i make i have in Pro/E with drawings but i want to make sure everything works right first.
I want to run 2x4 frame rails from the back clip to the front clip. Where do I brace Liljimsrodragz Steering, Suspension, and Chassis 0 14th-September-2009 05:17 PM
M 20 Muncie tsimpson Parts for Chevy II/Nova/Acadian 8 27th-December-2008 12:29 PM
Muncie id help 1quik69 Drivetrain & Performance 2 17th-April-2008 09:21 PM
65 Tci Front Clip W/4speed Muncie AILDASANI12 Drivetrain & Performance 1 16th-March-2008 09:50 PM
front clip help... can you ID Mfg. of clip ??? the FLYER 1st & 2nd Generation Chevy II/Nova's 10 15th-October-2007 11:12 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
