StevesNovaSite.com is the premier Chevrolet Nova forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 7th-October-2009, 05:47 PM   #1
Nwayne
Nwayne's Avatar
Nova(s): 64 2dr Coupe The Money P
Brake help needed
Well, I'm not sure where I'm screwing up but something isn't right. I'm trying to install the front brake calipers and there seems to be a huge problem. There's no way these are going over the rotors. The front pads won't go over the rotor, and even if it does, or was forced, the rotor isn't going to turn. Maybe I have the wrong kit, I don't know since i purchased these almost 2 years ago and have since lost the receipt. Anyway, here's some pics. Maybe somebody can tell me what the heck is wrong.
thanks
Click the image to open in full size.
Old 7th-October-2009, 05:49 PM   #2
Nwayne
Nwayne's Avatar
I guess I should add, these are Heidts 2" drop spindles on a Checkered Racing front clip.
Old 7th-October-2009, 05:51 PM   #3
1slow64
1slow64's Avatar
Nova(s): 64 2d sedan 400
If i'm looking at the pics right your saying the pads are to thick? If so you could grind them down.
1987 BUICK GRAND NATIONAL
1964 2 door sedan 400 series GONE
1969 Camaro SS X66 396 #'s matching
Old 7th-October-2009, 06:03 PM   #4
Nwayne
Nwayne's Avatar
I'd have to grind quite a bit off, and the rear pad isn't even close to touching the rotor.
Old 7th-October-2009, 06:08 PM   #5
NOGO
NOGO's Avatar
Nova(s): 67 Chevy II Nova HT
I wouldnt go there...
Can the caliper anchor be positioned differently (flipped)? Are the RF and LF anchors the same?
Old 7th-October-2009, 06:29 PM   #6
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Do you have the recommended brake kit for the Heidt's spindle or just some generic Nova kit? Some of the aftermarket spindles require a particular caliper.
69 Nova 410" small block-Driven to track; new bests 6.51 E.T./104.40 MPH
http://bowtie0069.fotki.com/
Old 7th-October-2009, 06:31 PM   #7
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Old 7th-October-2009, 06:46 PM   #8
Nwayne
Nwayne's Avatar
Could be, but they were marked driver/ passanger so I assumed they were correct. Also I have a piture to look at and they look the same as the pic. I'll have to check them when I get back home.
Old 7th-October-2009, 06:50 PM   #9
Nwayne
Nwayne's Avatar
I believe so, I told the place I ordered them from what spindles I have.
Old 7th-October-2009, 07:00 PM   #10
the mechanic
Nova(s): 1970 Nova
Looks to me like the whole caliper is too far inboard- which leads me to think its an issue with the spindles being wrong...or the anchors-but im un-familler with dropped spindles and 1st/2nd gens so take it FWIW....
Old 7th-October-2009, 07:05 PM   #11
NOGO
NOGO's Avatar
It may be the picture angle but it looks as though even if the caliper fit over the rotor the mouth of the caliper would not cover the rotor enough for sufficient pad contact. Take out the pads, mount the caliper, and take another photo.
Old 7th-October-2009, 07:08 PM   #12
Nwayne
Nwayne's Avatar
That's the way it looks to me as well. Looks as though the calipers are too far back. I'll mount the empty calipers and take another pic when I get home.
Old 7th-October-2009, 07:09 PM   #13
NovatoriusRex
NovatoriusRex's Avatar
Title: Moderator
Nova(s): 67 Chevy II Nova Hardtop
Can the caliper be mounted on the outside of the caliper bracket rather than the inside?
It seems like it might be off by the width of the bracket, so mounting the caliper outboard may fix it.
Be who you are & say what you feel; one who minds doesn't matter, one who matters doesn't mind
Old 7th-October-2009, 07:14 PM   #14
Nwayne
Nwayne's Avatar
It does appear to be off about the width of the bracket,but the calipers will only go on one way.
But as Bryan said, even if they go on, the mouth of the caliper looks to be to big and wouldn't provide sufficent pad contact. I'm thinking theses are the wrong calipers?
Old 7th-October-2009, 07:36 PM   #15
OldGuy 71Acadian
OldGuy 71Acadian's Avatar
Nova(s): 1971 Acadian
The brackets don't look correct or maybe the bracket and rotor ***'y. The pictures show the caliper to far inboard but also to far away from the rotor as if the rotor should be a larger diameter. What ever the case your combo is definitely wrong.
Stock brake clevis needed! dahoof 1st & 2nd Generation Chevy II/Nova's 1 1st-August-2007 04:39 PM
brake help needed KEITH'S75CUSTOM Drivetrain & Performance 10 1st-July-2007 02:34 PM
Disc brake clarification needed 63moredoor Steering, Suspension, and Chassis 2 25th-March-2007 12:33 PM
Disk brake HELP needed 2novacars 3rd Generation Chevy II/Nova's 9 14th-May-2006 09:24 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
