Vortec heads torque specs - Chevy Nova Forum
Old 18th-September-2009, 03:15 PM   #1
greasemonkeychef
(OP)
greasemonkeychef's Avatar
Nova(s): 1964 nova
I am looking for the torque specs for a '96 5.7 vortec cylinder head. Also the sequence would help too. I know starting from the center and working your way out. I would just like to see if anyone know where I might find a printable version.
Thxs
Old 18th-September-2009, 04:18 PM   #2
WildBillyT
WildBillyT's Avatar
Nova(s): 1968 Nova SS
Thxs
http://www.small-block-chevy.com/headtorq.jpg
Make one pass at 30 then two at 65 lb-ft
Old 18th-September-2009, 05:51 PM   #3
MarkW
When did Chevy start using torque-to-yield head bolts? Are you using standard bolts or TTY? The chart given is good for standard bolts.
Old 18th-September-2009, 06:20 PM   #4
greasemonkeychef
(OP)
Nova(s): 1964 nova
I am going with the factory bolts. I was told that you can reuse them without any problem.
Old 18th-September-2009, 07:41 PM   #5
Paul Wright
Paul Wright's Avatar
I wouldn't reuse head bolts because they fatigue over time from heat cycling. The expansion and contraction causes them to yield. Once they start to stretch the clamping force is diminished at the same torque value.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 18th-September-2009, 08:08 PM   #6
bowtie0069
bowtie0069's Avatar
Nova(s): 69
I'm guilty of re-using mine several times--even re-use head gaskets sometimes!!
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
need some torque specs jonnyc Steering, Suspension, and Chassis 3 9th-November-2008 11:51 PM
Torque Specs mist8kn Drivetrain & Performance 2 9th-October-2008 04:07 PM
I need Torque Specs, Please 63Randy Drivetrain & Performance 1 6th-September-2008 09:36 PM
Need some torque specs Irie 1st & 2nd Generation Chevy II/Nova's 2 10th-September-2007 01:36 PM
torque specs granny Drivetrain & Performance 3 19th-December-2006 10:56 PM
