Old 14th-September-2009, 04:12 PM   #1
mrdreex
mrdreex's Avatar
Nova(s): 72' Nova 383 AFR/solid
Mini-tubbing tire size?
I am curious to see if anybody has been successfully able to stuff a MT ET Street 325/50 - 15 with a mini-tub underneath the back of their car, with leaf springs. I have called several places and they do not know. I test-fitted the tire underneath the car with the leaf spring hanging loose, and it looked like it may rub, but the tire has yet to be mounted on the rim.
The section width is a bit smaller on the 325/50 than a 315/60 (approx. .4" according to summit) and should have a little better fit inside the wheel well. It is also 2" shorter, but obtains the same tread width.
I am hoping to see if I can take the cheaper way out and just move the leaf springs in/offset hangers and not have to 4-link it. Thanks for any help.
Old 14th-September-2009, 04:43 PM   #2
BBC71Nova
I sure as heck hope so . I'm in the middle of a minitub and the tire/wheel fits into the wheelwheel fine. I haven't tried the leaf yet. If it is too tight I'll try and offset the bushings in the front some by trimming one side and shimming the other to help move them over some.
John
Old 14th-September-2009, 04:59 PM   #3
mrdreex
mrdreex's Avatar
Yea, I'm just trying to see if anybody has had to offset the front hangers any. If so, where would you find something like this?
Old 14th-September-2009, 11:06 PM   #4
mrdreex
mrdreex's Avatar
No one? Anybody?
Old 15th-September-2009, 12:45 AM   #5
johnh
johnh's Avatar
Nova(s): 73 Nova BBC
No offset fronts on mine. These fit on my 73......BFG G Force T/A Drag Radials P325-50R-15
Mounted once and used for 3 pass's , then installed the slicks.
Just another Blue Nova
1.350 6.319 @ 106.73
Old 15th-September-2009, 08:44 AM   #6
mrdreex
mrdreex's Avatar
Are these them?
http://www.summitracing.com/parts/BFG-53931/
Old 15th-September-2009, 11:37 AM   #7
johnh
johnh's Avatar
yes... But I didnt pay that MUCH for them...
Old 15th-September-2009, 11:58 AM   #8
mrdreex
mrdreex's Avatar
Do you mind me asking how much clearance you have in between your tire and the front of the leaf spring? Are your tires right up against the fender lip? Did you narrow your rear any?
Old 15th-September-2009, 12:33 PM   #9
johnh
johnh's Avatar
yes the rear was narrowed during the mini tub. I never measured the clearance issues..
Here is an older pic that was taken right after we re did the suspension, with a wider tire, I now run on a 9 inch slick . We have since installed an Anti roll bar and relocated the shock again
Click the image to open in full size.
Old 15th-September-2009, 01:53 PM   #10
mrdreex
mrdreex's Avatar
Hmm, doesn't look like any kind of clearance issue at all. What is the tire size in this, the 325/50?
Old 15th-September-2009, 02:37 PM   #11
johnh
johnh's Avatar
http://www.mandhtires.com/store.php?...on=show_detail
That tire was a M&H Racemaster N50-15
Tread Width: 11.0"
Section Width: 12.8"
Diameter: 28.2"
Old 15th-September-2009, 03:22 PM   #12
mrdreex
mrdreex's Avatar
Tread Width: 11.0"
Diameter: 28.2"
Awesome, thanks for the help johnh. Those are only .2" smaller in section width than mine. I'm really hoping my mockup was way off. I'd love to save about $2k on the suspension.
If you don't mind me asking, did you narrow the housing yourself?
Old 15th-September-2009, 03:27 PM   #13
johnh
johnh's Avatar
No I did not. It was narrowed already when I purchaced the car.
Old 15th-September-2009, 05:12 PM   #14
mrdreex
mrdreex's Avatar
Thanks again. One more question, what kind of shocks are you using? I was thinking of just using the shocks that I had before as they are fairly new, but am unsure of the rate, or anything else about them.
Old 15th-September-2009, 05:34 PM   #15
johnh
johnh's Avatar
Those are Rancho's from Calvert racing. www.calvertracing.com
What are your plans with the car?
What size tire can I run with a mini tub? onephatz28 Drag Racing Forum 30 10th-November-2009 11:05 PM
Tire size with mini tub latteboost Drag Racing Forum 18 9th-August-2009 08:59 AM
mini-tub tire size GoFast Steering, Suspension, and Chassis 7 13th-February-2008 02:01 AM
tire size mini-tub 66 DHill Drag Racing Forum 2 2nd-October-2007 10:49 AM
mini tubbing youngin69nova 3rd Generation Chevy II/Nova's 8 7th-August-2007 05:14 PM
