Drag slicks, what size? - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 1st-August-2009, 10:12 PM   #1
slickman
slickman's Avatar
Nova(s): 1972 Nova SS
What size slicks will fit on a stock 72 rear? I was thinking 10 inch but not sure. I have 255's on there so I figured 10inch would fit.
I have 3:73's and I was figuring on getting 26x10-15's Thoughts?
Also, what wheels would you recommend?
Old 1st-August-2009, 10:45 PM   #2
ERV JR
ERV JR's Avatar
Dude you are the slickman, whay you asking us ?
Really, you can run a 28x9 slick or a 28x11.5 et street. If you run a 10 or 10.5 the car will have be sitting high or stock heighn, as the bluge of the tire will rub if you try to lower the car, also it depends on the rim width
Old 1st-August-2009, 10:55 PM   #3
slickman
slickman's Avatar
So, if I stick with a 9 inch slick I should be fine.. So, I should also get a 8 inch wide rim correct?
Old 1st-August-2009, 11:33 PM   #4
chevyIIheavy
Nova(s): 63 nova ss
a 255/60/15 mt dragradial will fit your car like a glove ......... thats what your running anyways or a 255/60/15 is the same as a 27 x 10.5 x 15 slick on an 8'' rim
Old 1st-August-2009, 11:36 PM   #5
slickman
slickman's Avatar
Great, thats the info I was looking for. I kind of thought a 10 inch would do it.. Thanks!!
Old 1st-August-2009, 11:38 PM   #6
chevyIIheavy
Nova(s): 63 nova ss
a 10'' tire would be fine too it would give you a little more room to play with
Old 2nd-August-2009, 03:32 AM   #7
ERV JR
ERV JR's Avatar
Really a ten can fit as I said, but I will tell you a 28x9 et drag on a 8 inch rim , with the car sitting with wheel well 1/2 from the rim has no room. The thing is the tub kinda narrows toward the top, with the car higher you may have more room, I have seen cars with the buldge of the tire in the flare section of the wheel well. so yeah they fit, there are guys who use a 3 or 5 lb hammer and beat the tub to clear, but i dont care for the ways.
I put my tires up in there and measured between the 2 then built the housing to fit, I have about 1/4 on each side of the buldge, as I said thats a 28x9.
Ask aron69nova for pics of his and my car and you can see. it depends on the height
Old 2nd-August-2009, 05:39 AM   #8
bigdaddykane
Nova(s): 3rd gen Nova's
if your rear is stock length, i recomend a 15x8 rims with 5.5 backspacing and 28"x10" slick such as MT.....or MT ET street 28x12.50x15..........
Old 2nd-August-2009, 12:53 PM   #9
slickman
slickman's Avatar
5 1/2 inch BS? That sounds like way too much. I have a 4 3/8 BS now and it only has about 3/4 clearance.
Seeing there has been a varation on what others say will fit. It looks like I should stick with a 9 inch on an 8 inch wide rim with a BS of no more then 4 7/8.
what ya guys think?
I don't want to invest in rims and tires then find out I have an issue. My tire and rim setup now is; 255x60-15 on 15x7 rims with a BS of 4 3/8. The rear is all stock, no tubs.
Old 2nd-August-2009, 12:54 PM   #10
Ironman
Ironman's Avatar
NO WAY a 28X12.5-15 ET street is going to fit on my 72 with a stock rearend and 15x8x5.5. That is the rim I am using and have a 27x10.5-15 tire and it rubs the inner panel. My tire has a sidewall width of 10.6" and the 12.5" tire has a sidewall width of 12.6".....don't know where you get your info from.
26x10.5-15 ET street, 10.5 is sidewall width and a 8.3" tread width, where as a slick the middle number is sidewall width, so a 26x10-15 ET drag slick has a sidewall width of 11.6" and a tread width of 9.8"
The 28x9-15 slick is 10.8 at the sidewall and 8.6 at the tread
The 255/16-15 ET street radial is equivalent to the 27x10.5-15, 27.1" dia, 10.1 sidewall and 9" tread
10.87 at 119 on the brakes 400 SBC pump gas, flat tappet cam, small tire.
Old 2nd-August-2009, 01:02 PM   #11
Ironman
Ironman's Avatar
Tire----------------------------Section width-------Tread width
255/16-15 ET Street radial -------10.1"---------------9.0"
26x10.5-15 ET Street-------------10.5"---------------8.3"
27x10.5-15 Et Street-------------10.6"---------------8.9"
28X12.5-15 ET Street------------12.6"---------------10.0"
28x9-15 ET Drag-----------------10.8"---------------8.6"
26X10-15 ET Drag----------------11.6"---------------9.6"
28x10.5-15 ET Drag--------------11.7"---------------9.6"
Old 2nd-August-2009, 01:13 PM   #12
slickman
slickman's Avatar
Based on this with my tires being 255/60 with a section width of 10 inches, it looks like I should stick with the 28x9-15 ET Drag right? Also stick with an offset of 4 1/2..
Old 2nd-August-2009, 01:33 PM   #13
slickman
slickman's Avatar
This is what I had in mind. Slicks and Rims
Old 2nd-August-2009, 07:30 PM   #14
67SHOEBOX
67SHOEBOX's Avatar
Nova(s): 1970 Nova SS Pro-charged
Thats what I have a 28x10 slick mounted on a 15x8 rim with 5.5bs
Old 2nd-August-2009, 10:34 PM   #15
ERV JR
ERV JR's Avatar
Bingo what did I say the first time ? the 28 x11.5 et street measures the same if yoou want to drive around on them but the et drag is abetter tire.
Oh I run a 8 inch rim with 3.5 bs. looks good tucked in there and rim looks deep. narrowed 9 in
WTB: USED M/T Drag Radials and/or Slicks yenkokid Drag Racing Forum 3 20th-August-2008 07:04 PM
ET Drag Slicks agpd45 Drag Racing Forum 6 27th-March-2008 11:24 PM
Storing Drag Slicks '69Novajoe Drag Racing Forum 11 28th-February-2007 08:36 AM
What size slicks? two70Novas Drag Racing Forum 27 16th-September-2006 02:48 AM
M/T drag slicks in Oregon MELUVNOVA North Western US 0 20th-July-2006 12:27 PM
