Info on 3884520 Heads? - Chevy Nova Forum
Old 11th-July-2009, 11:55 AM   #1
RamAirZ
(OP)
Title: Nova Newbie
Nova(s): 1967 Biscayne 307/3-spd
Hey guys, I told you before that I found out that my 67' Biscayne appears to have a 307 in it (block casting number- 3970020). I found tonight that I appear to have some powerpack 283 heads on it as well lol. The numbers come as follow: 3884520 GM 4 T^-(big triangle lol) 0238-(may be 0288). These heads appear to be about 60cc chambers from what I gather online and 1.72/1.50 valves. Do you think these heads could support up to 300hp with a 1.94 intake valve? Anyone have any experience with these as I personally do not. Any help would be great!
67 Chevy Biscayne-307/3-spd
97 Isuzu Rodeo-lifted, 33's
67 Chevy K10-sold
87 Iroc-LS1/T56-sold
Old 11th-July-2009, 08:24 PM   #2
vortecpro
vortecpro's Avatar
They can support hp 300 with a good valve job, our 283 NHRA stocker held the record at 12.57 @ 104.70 in O stock automatic, which is a 65 chevelle wagon with a 283 in it, at 3570 pounds which shows about 313 HP at crank which is what I saw for observed HP on my dyno. Now intake flow was about 169 cfm @ 28 inches with the 1.720 valve unported due to rules, its seems they go in the 190s for flow with a 1.940 valve with minor porting. Hope this answers your question.
Last edited by 1quik69; 12th-July-2009 at 01:12 AM. Reason: Big Al did not want his name in this post.
Old 11th-July-2009, 10:52 PM   #3
RamAirZ
(OP)
Title: Nova Newbie
Thanks alot!! Since these heads are already on the car I was thinkign of leaving them, just swapping valve springs and camshaft. I have a 4bbl aluminum q-jet manifold and carb to go on, hoping for mid 200's or so hp wise(the closer to 300 the better) and looking for some good low end torque. I was going to get some 416 heads but I'm trying to keep the engine part of this project on a budget since the motor is in such good shape. I don't see the point in swapping it or going crazy at this time.
67 Chevy K10-sold
Old 11th-July-2009, 10:54 PM   #4
slow3oh
slow3oh's Avatar
Nova(s): 71 project 68 daily driv
416 heads are cheap man....
I got ripped off on my first set but my boss gave me my second set
Ill give you the first set if you pay shipping. but one of the valve guides is messed up and you would have to spend 30 dollars to get a false guide put in. ....
1972 SS -sold
1971 383-sold
1970 350-sold
1968 SS 383 Daily driven
Old 12th-July-2009, 12:49 AM   #5
RamAirZ
(OP)
Title: Nova Newbie
I wonder how much shipping would be lol.
67 Chevy K10-sold
Old 12th-July-2009, 12:58 AM   #6
bowtie0069
bowtie0069's Avatar
Nova(s): 69
My confuser shows about 100 h.p. more than that to run the numbers.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 12th-July-2009, 01:18 AM   #7
RamAirZ
(OP)
Title: Nova Newbie
The mph though is the real give away. I see guys in high 13's running 104. He's probably hooking like crazy and has some really high (numerically) gears. A buddy of mine was running 12.97@106mph putting down 276 at the tires in a 94' Z28
67 Chevy K10-sold
Old 12th-July-2009, 01:29 AM   #8
vortecpro
vortecpro's Avatar
Your using the wrong formulas. I know.
Old 12th-July-2009, 01:36 AM   #9
vortecpro
vortecpro's Avatar
Actually we never where able to get the car to leave like we wanted to, needed more converter testing, 60 ft was 1.72 but we were looking for 1.69 104.7 should net a mid 12.4 but the car held the O/SA record for a few years, Cal Method bought the car and raced it before building his C/SA Nova 402 375 HP car.
Old 12th-July-2009, 02:30 AM   #10
RamAirZ
(OP)
Title: Nova Newbie
sounds like a sweet set up. You think with the x4262h cam with the PP heads, q-jet aluminum intake and carb would make around 250-270 or so?
67 Chevy K10-sold
Old 12th-July-2009, 08:28 AM   #11
vortecpro
vortecpro's Avatar
I have no experiance with that type of combination so I couldnt say, but 250 dyno HP seems reasonable. I wouldnt use the 416 heads, the runners are to big for a 307 plus the heat crossover going into both exhaust ports bothers me, stick with the 520s, It was a long time ago but Ive done a 350 with 520s ported, solid flattappet, 11.1 comp, 450 dyno HP@ 6500 rpm, 70 nova ran 11.30s @ 116, car showed about 390 Hp going down the track, which tells me the car and drive line needed some work.
Old 12th-July-2009, 10:59 AM   #12
RamAirZ
(OP)
Title: Nova Newbie
Cool thanks for the info. I'll probably just clean up the 520's when I do a cam swap (valve jobs, new springs/seals etc). I'm more interested in the torque it'll make but would like t get at least 250 out of it hp wise for the time being. Of course I'm not one to leave anything alone so down the road my goal will be much higher
67 Chevy K10-sold
Summit or Edelbrock heads tehdrizzle Drivetrain & Performance 4 22nd-March-2009 10:13 PM
Santa is bringing Cylinder Heads danthegeek Drivetrain & Performance 55 25th-December-2008 09:58 PM
GREAT free head flow info!!!!! askgene Drivetrain & Performance 19 18th-December-2008 09:13 PM
options with heads that have brinelling Paulski Drivetrain & Performance 2 12th-March-2007 12:07 PM
Which heads to use? Kalamazoo72 Drivetrain & Performance 5 4th-January-2007 08:32 PM
