What Ford 9 inch rear axles/brakes fit Novas? - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > Best of Drivetrain & Performance
Closed Thread
Old 11th-May-2006, 01:27 AM   #1
Mike Goble
(OP)
Mike Goble's Avatar
Nova(s): 67 wagon project
Exclamation What Ford 9 inch rear axles/brakes fit Novas?
Originally Posted by super_davecars
I have a 57 ford 9 inch rear with 11 inch brakes.I have the drums but no shoes or hardware.I'm having trouble finding shoes,local parts store did not have a number in there wagner book.The drums measure a little over 2 inchs wide so I put some 2 inch by 11 shoes off an old full size chevy car and they fit fine on the ford backing plates but the drums rubbed the shoes it liked about an 1/8 inch or less to seat on the axle.Does anyone have any ford brake info or sources and/or part #s for a 57/59 9 inch rear. Thanks
I had the same problem with an early Ford rear on the Durango Deuce so I went to the boneyard and got some 11x2.5's off a 70's Merc Marauder. I was told I had to send in the early shoes to have them re-built since there aren't any readily available at the store. I may still have the original drums and shoes.
My parts guy at Orielly's found some brake shoes for me.They are Brake Best brand part # 55. He had them in stock for $14 and no core charge they are 1 3/4 x 11 inch shoes.
I'm Mike Goble and I approve this message.
Old 14th-August-2006, 12:23 PM   #2
novamike
novamike's Avatar
Nova(s): 66 ht
Thumbs up Bronco rear
While out yesterday afternoon fishing at a private lake,I saw a early model Bronco(like a 1966?) in a field that had been gutted however,it still had the rear end under it.It was across the fence line and I couldn't get to it to crawl under.
Isn't it ture that a early model Bronco 9 inch is the same wigth as a 66 10.2 rear?If this is true,I guess I had better check it out.
Mike
406.th400.9 inch,lots of Duct tape.
Superglue is my friend
Home of the famous "Bubba" burger
Old 14th-August-2006, 01:10 PM   #3
Brett
Nova(s): 65 2 door post
I've heard they are, Brett.
Old 14th-August-2006, 01:26 PM   #4
Bruce
Bruce's Avatar
Nova(s): 6 cylindersssssss
They will drop right in. The down side is they are a 5x5.5 bolt pattern.
Old 14th-August-2006, 03:06 PM   #5
novamike
novamike's Avatar
Nova(s): 66 ht
Thumbs up Bronco
I didn't have a single bite fishing in this lake,but maybe it wasn't a total lose after all!
I'll check into this!
Mike
Old 14th-August-2006, 08:19 PM   #6
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Don't they have more offset than normal? It seems to me the center was way off to the passenger side; or was that just the vans? They are pretty narrow though.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 14th-August-2006, 10:37 PM   #7
62Deuce400
62Deuce400's Avatar
I thought most 9" housings offset the pinion gear to the passenger side quite a bit, more so than the 12bolt, Dana 60, etc...
05 Dodge 2500 4wd
'62 Chevy II 400
Old 14th-August-2006, 11:42 PM   #8
bowtie0069
bowtie0069's Avatar
Nova(s): 69
That's not what I mean, if you look at an earlier Ford van, the axles are like WAY shorter on one side--some guys used to just buy a second drivers side axle, and narrow the other side to match. It's been a long time since I was around a Bronco, maybe I'm mistaken.
Old 14th-August-2006, 11:47 PM   #9
62Deuce400
62Deuce400's Avatar
Offset to clear the transfer case on the bronco?
just so theres room for the front and rear driveshaft...?
05 Dodge 2500 4wd
'62 Chevy II 400
Old 15th-August-2006, 01:06 PM   #10
bilede
bilede's Avatar
66 bronco rear.
the bronco 9 inches are centered and will work but the 66 is a small bearing very lite duty axle and not sure its worth the hassle to put it in a nova. I have owned a few and always traded out the axle for a 76-77 large bearing heavy duty unit or a dana 60 cut down.
Bill.
Old 23rd-August-2006, 12:53 PM   #11
62SportCoupe
62SportCoupe's Avatar
5 lug rearend for '62 Nova
Is there a "bolt on" 5 lug rear end to fit a '62 Nova (other than a early Nova rearend) ? Relocating spring perches shouldn't be too hard.
It's not a Chevy II... It's a Nova
Old 23rd-August-2006, 05:20 PM   #12
Greg_R_63
Greg_R_63's Avatar
Nova(s): 1963 2-dr hardtop
I don't think so. Hopefully, someone will come along presently to say otherwise.
Great, then making a detailed tutorial for us should be a snap, hint, hint.
1963 400 Series Hardtop
Old 23rd-August-2006, 05:57 PM   #13
62SportCoupe
just grind em off and reweld them where ya need em
Old 23rd-August-2006, 08:12 PM   #14
63AKDN
Nova(s): 63 Acadian Beaumont
I've heard that Maverick/Comet rears bolt in. Some even came with 9".
1963 Acadian Beaumont
355/700R4/Auburn Pro Series posi and 3.73's
Old 23rd-August-2006, 08:14 PM   #15
nova65ss
nova65ss's Avatar
Nova(s): 63 SS Convertible
Garage
A Granada 9" is supposed to be a bolt in right down to the emergency brake. Some of them had disc brakes.
Jimmy
Jimmy
Closed Thread
Nova's Ark 1964 Chevy Nova Nova's Ark Car Profiles 35 26th-April-2012 09:20 PM
Did 1st gen novas come with a Ford 9" type rear? 66 BADBOY Drivetrain & Performance 13 10th-November-2009 06:40 PM
What GM or Ford rear end housing fits a 66?? 1meanchevy Drivetrain & Performance 6 6th-March-2009 08:55 PM
Did any year novas come with rear deffogger? 74-NOVA-GUY Body and Interior 8 1st-December-2006 09:07 PM
What rear ends came in 6 cyl Novas in '65 Jarrett Drivetrain & Performance 9 26th-October-2006 05:55 PM
