Rotor phasing & high speed retard????? - Chevy Nova Forum
Old 10th-June-2009, 01:02 AM   #1
Baddbob
(OP)
Two things I don't have any clue about, can someone explain the how and why's of rotor phasing and also what and how a high speed retard works and why? I assume the high speed timing retard helps with the extra load placed on the engine in high gear? Bob
Old 10th-June-2009, 02:04 AM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
Rotor phasing can only be achieved when running a crank trigger.
High gear retard. In high gear if you can have a retard it allows you to run more timing in the low gears for better acceleration. In high gear under heavy WOT load is when the most cylinder pressure and chance of detonation possibilities.
Al
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 10th-June-2009, 05:05 AM   #3
SlickVic107
SlickVic107's Avatar
Nova(s): 72 Nova 355 9.91@134
You should always rotor phase, even if you don't use a crank trigger. Drill a hole in an old cap next to the number one socket. Shine the timing light in the hole and make sure that the rotor is dead on the socket. Not just before it or after it. Thats when you see rotor tips burned on one end or the other. If you phase it you won't have that burning because the spark is not leaving that small of an area (the corner). Now, your cap must be adjustable in order to correct this or very soft hands. I have not been able to really do it without an adjustable cap, like the MSD pro cap. It has two set screws that allow you to turn the cap and not the distributor.
As for high speed retard, never has never worked on my cars. Higher timing produces power in the low power band and in the high power end if you retard the timing it supposedly allows the motor to produce more power because your not fighting the turn of the crank by firing so advanced before TDC. Tried it on several of them. I have friends with 7.50 dragsters that have the 7al3's with it built in and they all run zero chips in them so it won't retard. Only time ive really seen it work is in forced induction and they start retarding due to boost not rpms.
Parts listed in For Sale/Misc section!
87 Cavalier, 383 9.27@142
Old 10th-June-2009, 07:45 AM   #4
Baddbob
(OP)
This all makes sense- Thanks!!! An adjustable rotor sounds like it would be the easiest or if the pickup could be repositioned appropriately I bet that would also work. I bet some of the cheap import distributors may be way off. Good information, thanks again, Bob
Old 10th-June-2009, 01:19 PM   #5
levisnteeshirt
Nova(s): shopping for the 6th one
seems like to me
high speed retards were more popular with small cube motors turning some real RPM ,, 8000 +
seems like it might be worth checking though ,, just as a safety to make sure you don't hurt a piston
Old 10th-June-2009, 01:27 PM   #6
69LT1Nova
69LT1Nova's Avatar
Nova(s): 1969 Nova, grandma fresh.
Wow... sounds a lot like this...
Build:
LT1 baby!
Old 10th-June-2009, 02:28 PM   #7
dave's 62
dave's 62's Avatar
what the hell did thet guy say?
Old 10th-June-2009, 02:35 PM   #8
69LT1Nova
69LT1Nova's Avatar
Exactly.
Build:
LT1 baby!
Old 10th-June-2009, 03:23 PM   #9
The Big Al
The Big Al's Avatar
Running a glide? 2 speed transmission!
Engine load when using a glide is very even.
When using multiple gears the use of more timing in those lower gears works.
Al
Old 10th-June-2009, 04:33 PM   #10
PldBryan
PldBryan's Avatar
Nova(s): 1963 Nova SS 383
Garage
HA! I work for Rockwell Automation/Allen Bradley, that is the Retroencabulator.
That thing gets brought out all of the time. What is amazing is if you watch how much of that the guy is able to get through without a cut!
PLDbryan
1963 SS
383 Forged Bottom/AFR top/Solid Bullet Cam in the middle
Muncie 4spd
F@&^ 9" Rearend
Old 10th-June-2009, 08:18 PM   #11
Baddbob
(OP)
Thinking about rotor phasing.... I guess it would only work on a distributor with no mechanical advance or one that has been locked. Phasing the rotor when you lock the weight setup might be the easiest way. Change the timing and the rotor phaseing will need to be adjusted again. Am I right?
Or.... do you dial in your mechanical advance curve then just make sure when the advance is all in that the phase is correct??? I bet a person could use a small solenoid to make a high speed retard using the same principal that vacume advance uses to rotate the breaker plate? The switch would need to throw current to it through a window switch maybe so higher rpm isn't affected??? Interesting stuff...
Old 10th-June-2009, 08:35 PM   #12
SlickVic107
Al
Never thought of it that way Al. Good point!
Old 10th-June-2009, 08:37 PM   #13
SlickVic107
HA! Bad thing is I actually understand some of what he said! I work with AB PLC's all the time in my company's electrical switchgear.
Old 11th-June-2009, 07:50 AM   #14
Baddbob
(OP)
back to the top in hopes for more info
Old 11th-June-2009, 08:30 PM   #15
SlickVic107
im not sure if you could phase the rotor with a mech or vaccum advance. Never tried as all my distributors are locked.
What's the deal with the Taurus / Mk VIII fan? T. Jerman Best of Drivetrain & Performance 105 27th-April-2009 04:38 PM
Anyone Have a 5 Speed Trans in Their Nova? sadsack 3rd Generation Chevy II/Nova's 13 26th-May-2008 08:15 PM
High Volume vs. Stock Oil Pump BBC Street Motor leejoy Drivetrain & Performance 51 9th-February-2008 07:23 PM
Holley Idle speed issues (4150 - 650DP) NovatoriusRex Drivetrain & Performance 29 25th-June-2006 07:54 PM
Big flooding problem w/fuel psi at high speed why-me Drivetrain & Performance 5 2nd-April-2006 06:01 PM
